Question about KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher
Touch pad/control board not working?
About 6 months ago, touch pad stopped working. I replaced the electronic control board and the console (with the touch pad). It worked until now, once again I replaced the control board but not the console (touch pad), but it is still not working.
What can I check with multimeter to determine what causing this electrical problem?
I've read some stuff about the thermal fuses, could that be the problem.
The dishwasher is about 4 years old.
    Scholar:
  • 126 Answers
PART NUMER 8193762 IS WHAT YOU WANT TO CHECK. YOU CAN SEE THE PICTURE OF THE PART AT REPAIRCLINIC.COM
Posted on Apr 24, 2010
My oven pad show out F2:E1
For Whirlpool (and associated brands), the F2 E1 error indicates a communication problem between the touch pad and the electronic control board. The oven's control thinks that the touch pad wiring is unplugged. This could be due to damaged wires, a loose wiring harness or a problem with the touch pad. First check that the wires aren't loose. Press Cancel to see if the signal is sent to the control board and clears the error. Wait 60 seconds for a response.
If the error persists, you need to replace the touch pad. On some models, you'll have to replace the touch pad and control board since they are sold as a single unit. For the units where the touch pad is a separate unit, you may still need to replace the control board. If the F2 E1 error persists after replacing the touch pad, then the control board is also faulty.
If you post a comment with the oven's make and model number, I may be able to give you the appropriate replacement part numbers. If your oven is still under warranty, contact the manufacturer for the repairs.
I hope this helps.
Jun 28, 2016 | Ovens
I have power going into my fridge freezer but the lights inside the fridge are not coming on and the compressor is not running and the items in the freezer are thawing out. Is there a trip switch?
sounds like possible inline fuse or electronic board is fried ,kif power to unit will have to check for power at electronic {control} board
Jun 09, 2016 | Refrigerators
Kitchenaid superba kgsc308lssc keypad not working
Hello Ron,
On that touch pad not working do any button at all work?? its not a uncommon thing for the touch pad to quit working,in some case its just a matter of making sure the plug on it has a good connection where it plugs into the control board. If certain button work while others don't its a sign that the control board itself is good and the problem lies within the touch pad and it would need to be replaced. It may possible as to clean the connection of the ribbon cable on the touch pad by using a pencil eraser and try cleaning the ends of the ribbon cable,again if that doesn't work the touch pad would need need to be replaced . On that model the touch pad is integrated onto the control console and the part number for it is 9782418CB just so ya know its pricey (over $200 )
Good luck,GENE
Oct 06, 2011 | KitchenAid KESC307 Electric Kitchen Range
F-7 code has been flashing, along with constant beeping. This has happened about 5 times over the past 2 months. Eventually it stops but now we resort to flipping the fuse off to get rid of the noise. ...
Hello Marylou,
The F7 code means the same thing on all domestic (USA) brand ovens.What is means is that a button on the touch pad is shorted (welded together) out. Since you did not include brand or model#
i will give you the following advice, if your touch pad is a seperate part that plugs in clock (also called the oven control,or eoc..electronic oven control) then just the touch pad can be replaced,on certain brands or even some models within a brand the touch pad is integrated into the clock/oven control or eoc in that case the complete touch pad/control asm. is what needs to be replaced
Hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Ovens
I am getting the E0 -F2- error code on my stove. I have unplugged for several hours; when plugged back in it worked for a couple of hours and the error code is back. What should we do. The burners work any...
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@!@
Jan 18, 2010 | Whirlpool GR450 Electric Kitchen Range
My GE XL44 Gas Range just started beeping and has F-1 on the screen. How do I get it to stop beeping?
Hi ......A f1 code indicate a stuck or faulty touch pad or button?Sometimes moisture or a spill will cause this problem,Unplug 12 -24 hrs and reset.If this does not cure your problem turn off power unplug touch pad from control board and turn back on. F1 still there? If yes replace control board if not replace touch pad.If components are not separate electronic control will have to be replace, Hope this helps .Please rate my answer/response :)
Dec 13, 2009 | GE JGBP24 Gas Kitchen Range
My touch pad will not work thus rendering the oven useless. It will not respond to touch. Is there anything I can do sans a new processor pad?
HI. Unfortunately, the touch/key pad is not repairable. Once the circuitry is damaged, the entire board must be replaced. Most units will have an Incorporated control board, that will have the touch/key pad integrated into the main board assembly. If this is the case, simply replace the entire oven control board. If the touch pad is separate from the main control board, replace the touch pad board.
NOTE_ This may be a simple control fault. In this case, simply unplug the unit, or shut down the appropriate circuit breaker for five minutes. This will reset the control. If the issue's persist, replace the failed component.
Dec 03, 2009 | Jenn-Air JGR8775QD Gas Kitchen Range
Electronic control touch pad not working
This is your electronic control board that needs to be repalced on this unit. GE Profile is a great brand and it is easy to repair, also.
We provide part removal/installation instructions for our customers when you purchase your parts from us.We also ship parts overnight to assure that you get your oven repaired right away.
Please contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 9 PM CST. We look forward to getting you cooking again soon.
Thanks, Ella
Nov 17, 2009 | GE Profile JGS968 Gas Kitchen Range
FO error message. Oven light stuck on. No buttons work.
The F0 is a Function Key Stuck error - Replace touch pad or touch pad and control board if it is one assembly. Refer to F1 Test for more information.
How To Perform A F1 Touch Pad / ERC Test
This test is easy to perform and will help you determine whether the Electronic Range Control (ERC, control board) or touch pad is defective when the F1 code is displayed.
Note: With some models, the ERC and the touch pad are one single unit and therefore this test is not necessary. The entire assembly must be replaced.
Warning: If you have any doubts in your ability or safety of the repair, please contact a qualified appliance repair technician.
1. Disconnect the power to the range by either unplugging the power cord, or turning the power off at the circuit breaker. Always make sure the power as been disconnected properly before beginning this test.
2. Access the control panel.
3. Disconnect the touch pad ribbon from the ERC.
4. Reassemble the control panel. Make sure to check for any additional defects such as frayed or lose wires that could be causing the problem.
5. Turn the power back on.
6. Wait up to an hour for the F1 code to reappear. This could be accompanied by an alert such as a beeping sound.
7. If the F1 code reappears, replace the ERC. If it does not, replace the touch pad.
Nov 06, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
One year old window heat pump unit will not power
Is it not coming on? If it isn't, is the control pad lighting up? Is any of the electronics lighting up? If not, then the control board is probably bad. You will need to check voltages to the control board.
Apr 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
KitchenAid 24 in. KUDP01IL - Multiple Color Built-In Dishwasher Logo
638 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
