Question about Intermatic & Indoor/Outdoor Rain Tight Timer
I have a Tork timer that is not working properly. Actually the timer part is not moving at all on it's own but that doesn't matter as I can just turn it on manually at night when I get home. My problem is that I can not figure out how to get the different zones to work. There are 4 zones coming out of the pump of which two are used, one for the front and one for the back. Sometimes the front will turn on and sometimes the back but not in any consistent matter. From what I can still read inside the box the model number is 12/76/5902. Please help. Thanks! http://img.photobucket.com/albums/v618/chucky_vs_alf/IMG_1557.jpg http://img.photobucket.com/albums/v618/chucky_vs_alf/IMG_1554.jpg [IMG]http://img.photobucket.com/albums/v618/chucky_vs_alf/IMG_1557.jpg[/IMG] [IMG]http://img.photobucket.com/albums/v618/chucky_vs_alf/IMG_1554.jpg[/IMG]
  • 110 Answers
Dude take a breath #1 kill the power #2 loosen and mark all the wires on the bottom L1 , L2, L3,L4 look at the top you will see clips that will remove the timer circut if the caseing of your old unit is still good than all you have to do is replace the guts real easy dont freek out go slo just make sure you have same conifg ps if your not safe with it just ask sprinkler man electrican , some pool dudes none the less you can do it your self just replace the guts leave the houseing they will match sparks fla
Posted on Apr 24, 2010
TORK 1101 Timer will not keep proper time?
Clean up the timer with compressed air and WD40.
If problem persists, then bad #101 120 volt clock motor probably
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
http://www.amazon.com/dp/B00AQZ78TU/?tag=waterheaterti-20
Clock motors and trippers can be replaced on Tork series timers.
Gene
Oct 27, 2014 | Hardware & Accessories
I have a tork 651a . that only works at knight and its a photo cell,go figure....can you help???????????????
Tork 651 timer is dawn-dusk that automatically turns on at dusk.
Open following link to identify timer and download instructions:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html#651
If you want ordinary 24-hour on-off timer for outdoors, instead of dawn-dusk timer, then select Tork 611A or Tork 601, or Tork 611 timer shown on same link above.
http://waterheatertimer.org/How-to-set-timers.html
Jul 25, 2011 | TORK 651A Photocell Controlled Mechanical...
I have a Tork 1101 timer and up until now has worked fine. Now it won't shut off. The mechanical on/off tabs are set correctly. It turns on and as the timing wheel comes around, the shut off tab...
If clock is rotating on time, next suspect is P47 trippers have worn down. Trippers are made of softer metal so they wear down instead wearing down the on-off lever, and that way the timer lasts longer.
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
New replacement Tork 1101 120Volt timer can be purchased on-line at Amazon etc.
Home Depot sells the 120V GE 15306 indoor-outdoor version of Tork 1101 timer.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
Replacement timer in Intermatic is T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Jul 24, 2011 | Kitchen Ranges
When pool pump stops at various times when it should be running and not everyday, but sometimes twice a day, if I tap the Tork timer dial it turns on. Only the timer dial, tapping anything else does not...
Could be loose wiring, or bad clock motor.
Check if wires are connected, and make sure only the copper part of wire and no insulation is under the screw plate.
Make sure all wires are same gauge so that screw plate clamps down on wires.
Open following link to identify timer and then add a comment with model number and voltage for possible help. Tork T1100 series has replacement clock motor.
Jun 29, 2011 | York Hardware & Accessories
I do not know how to set timer have tork 1011 24 hour timer
Open following link to identify timer, with information for trippers and replacement clock motor:
The clock motor rotates analog timer dial clockwise as time passes.
Trippers on the dial move lever that rotates a cam that opens and closes electric circuit.
To set current time, manually rotate timer dial until current time lines up with the word Timer located near the 5 o'clock position.
If the dial is not rotating oe keeping good time, then clock motor is bad.
If trippers don't move the lever, then trippers are worn down.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 06, 2011 | TORK Timer 1 Channel Signal Timer Dgs100
My Tork 1101 24 hr timer has stopped working. I hear it running, but the clock will not turn. I have to turn it on and off manually for my pool pump. This happened 2 years ago, then the following year...
You might need $45 clock motor for for Tork 1101 120Volt.
http://www.frontierlighting.com/product.jsp?part=10431&process=search&show=&&gdftrk=gdfV22514_a_7c834_a_7c3267_a_7c10431
Open following link to identify timer and see replacement clock motor and trippers:
Intermatic crossover shows T101 timer replaces 120Volt Tork 1101.
Amazon sells new Intermatic timer for $45 with super shipping
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
Crossover wiring from Tork to Intermatic:
Black wire on Tork L and 1 connect to Intermatic terminal 1
White wires on Tork X connect to Intermatic terminal A
Black wire on Tork 2 connects to Intermatic terminal 2
http://waterheatertimer.org/How-to-wire-T104-Intermatuic-timer.html#T101
Upvote the help.
Jun 04, 2011 | Vacuums
I noticed the Tork 1104 timer box was not working. It does not make a sound. And the clock does not move. I measured the incoming and outgoing wires with a multimeter and both measure at 240V. I'm...
13 years is good run for clock motor. Timer will last longer than clock motor.
Tork 1104 has 240Volt clock motor
Frontier lighting sells the >> 120V Tork motor: List price 40.33/ your price 45.49
So 120Volt replacement motor costs as much as new replacement timer
Intermatic replacement is240 volt T104 timer for $49.62 with 'free' shipping:
Also Intermatic trippers and clock motors are cheap and easily available
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88
Crossover wiring from 1104 to T104.
Tork L goes to Intermatic 1
Tork 1 goes to Intermatic 3
Tork x goes to Intermatic 2
Tork 2 goes to Intermatic 4
Intermatic A is not used unless you have neutral wire or 277V
GE sells the same 240Volt Tork timer under GE model 15307 in indoor-outdoor enclosure available at Home Depot for $59.00. Year 2011, GE does not pay US income tax, but takes US profits and pays tax in foreign nations. No replacement clock motor is available, but crossover wiring is same.
Upvote the help.
May 09, 2011 | TORK Variable Cycling Timer 8601
How to set times
You posted under Tork 8000 series cycling timer
Open following link to identify timer for sure and download wiring and instruction manuals.
http://waterheatertimer.org/Tork-timers-and-manuals.html#8000
Cycling timers have built-in trippers (or tabs) located on outer edge of dial
Lift each tripper up and rotate it toward center of dial to set on-off times.
The dial rotates as time passes, and the trippers move lever that turns load on-off.
For example if you have 8601 timer, the dial cycles every 60 minutes or once per hour.
Each tripper represents 1 minute.
So if you want NO terminals turned ON for 2 minutes each hour, then move 2 successive trippers up.
If you want NC terminals turned ON for 58 minutes, then leave 58 successive trippers down.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 01, 2011 | TORK Variable Cycling Timer 8601
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
202 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
