Question about Philips Televison & Video
I am unable to upgrade my firmware on a Philips 42pf7321d
Firstly, my display continues to go black on the bottom half only. This usually only lasts for a few seconds up to 30 seconds. The Philips web site states that this can be corrected by a firmware upgrade. I found the firmware upgrade for my TV. I followed the instructions in the firmware release notes to the ''T''. I reformatted my thumb drive to FAT. I renamed the file to firmware_autorun.upg. I tried the manual install and the TV tells me there is no software on the device. So I reformatted the drive to FAT32 (just to be silly). Same issue. I have called Philips. They have no advice and no information as my TV is over 2 years old... Any suggestions?
    Sergeant:
  • 380 Answers
Most likely you have the latest firmware on your tv. You can check the version somewhere in the menus but your problem most like can only be fixed by replacing the y-up and y-down buffers.
Posted on Apr 24, 2010
Command disk not foud while operating
My suspect is your DVD player has aborted a previous firmware upgrade process. Usually DVD players use firmwares burned on a DVD/CD, the complete process takes a couple of attempts to successfully flash the firmware.
The best way to get the command disk or ROM disks is to check the Philips website's support section for your particular DVD player model. Unfortunately, Philips does not offer command disk / firmware patches for all models.
Last but not least.. take your DVD player to the nearest Philips Customer care. They should be able to fix it.
Mar 04, 2011 | Philips Televison & Video
There is unable 46 written
The error message Unable 46 is an indication that the machines ink absorbers are almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
There is a possibility that this message may have occurred in error. Upgrading the firmware of the Brother machine may resolve the issue. Follow the procedure below to determine if a firmware update is required:
-if the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
-press the # and * key at the same time. The first 2 characters on the top row will determine the ROM version.
If the ROM version is OE or greater (example: OF, OG, OH, etc), the firmware does NOT need to be upgraded. If the ROM version is OA, OB, OC or OD, follow the procedure on this link to upgrade the firmware.
If the message "Print Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
Jan 21, 2011 | Brother DCP 130C All-In-One InkJet Printer
I am facing the problem of clean unable 46 and clean unable Af please give me solution
The error message "Clean Unable 46" is an indication that the machines ink absorbers are full or almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
If the message "Clean Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
Dec 17, 2010 | Brother MFC-290C Printer
Error message of clean unable 46
The error message "Print Unable 46" is an indication that the machines ink absorbers are almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
Nov 08, 2010 | Brother MFC 240C All-In-One InkJet Printer
Error code 46 -- Display indicates "Unable to clean 46"
Oct 20, 2010 | Brother MFC-845CW multi-function...
42 PHILIPS PLASMA HDTV 42PF7220A37 Hello, The top half and sometimes the bottom half of the screen would go black now and then, now the bottom half is distorted and theres some issues in the upper half...
Download philips latest firmware here: Click sometimes glitches can be cleared with their firmware. Also this could be a sign that your vertical buffer drivers are over-heating due to a faulty Y-sustain problem. The best way to check is to remove the back cover turn the TV on and see which buffer IC is getting red hot by touching it. Be careful as the voltage levels are dangerous, get someone who's technically proficient to do that little test for you....
http://tvtechwork.webs.com/
Oct 18, 2010 | Televison & Video
Error unable to print 46
Aug 26, 2010 | Brother MFC 490cw Color Inkjet...
Bottom half of the screen goes black frequently.
You can start here: http://www.support.philips.com/support/catalog/catalog.jsp;jsessionid=87CE21B6A8264B83B8D00501ADACA8BF.app107-drp1?_dyncharset=UTF-8&country=&categoryid=FLAT_TV_CA_US_CARE&userLanguage=en&navCount=1&groupId=TV_GR_US_CARE&catalogType=&navAction=push&userCountry=us&title=Flat+TV+(plasma%2C+LCD)
Enter the exact Model Numbere in the search text field.
First verify the exact Model Number of your TV. Mine is a 42PF7220A/37.
go to:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7220A/37&scy=us&slg=en
On this page I found listed under "Software2.gif & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
I downloaded the compressed file and extracted it to a USB Flash Drive2.gif.
After you extract the file you will have 2 files...."autorun.upg" and a "readme.txt".
Make sure the USB Flash Drive2.gif has only one file on it (autorun.upg)
Make sure the TV is turned off.
Put the USB Flash Drive in any of the USB ports on the TV.
Turn the TV power on with the Power Button on the righthand side of the TV.
The TV will display an Update screen.
Let the TV run through all 3 processes.
Turn the TV off and remove the USB Flash Drive.
Power the TV back up.
Hopefully the Updates fixed the problem.....
Jul 27, 2009 | Philips 42PF7220A 42 in. Plasma Television
Black Screen
It is possible that the backplane lamps and lamp supply has failed. It is also possible that there is a failure in the power supply or on one of the circuit boards. Without doing some tests it is impossible to accurately determine the areas of fault.
Jerry G.
Aug 26, 2008 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
131 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
