Question about LG LFX25960ST Stainless Steel French Door Refrigerator
The refrigerator section has stopped cooling but the freezer is still working
  • LG Master
  • 8,220 Answers
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
Bgillespie
  • 89 Answers
SOURCE: Both the Freezer and the Refridgerator quit working...
Do you have ice build up on the back wall in the freezer? If so you have whats called a defrost problem. (can be timmer, adc, heating element or thermostat)... All cold air in you fridge side come from the freezer, therefore if you have ice build up behind back wall in freezer it is blocking air flow....
Posted on Dec 21, 2007
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
SOURCE: Profile refrigerator section not cooling
We are not sure what precipitated the temperature swing up; however, within about an hour of emptying quite a lot of foodstuffs from top and bottom sections of the unit, I felt the cold air start to flow out of the rear vent. Within two hours, the upper section had dropped to about 50 degrees and by the next morning to 36. The freezer seemed to recoved on its own too, having risen to almost 8 degrees and then recovering to 0. Just patience and a smaller food payload?
Posted on Oct 02, 2008
  • 31 Answers
SOURCE: Kenmore Elite model 73503201- FRIDGE DOES NOT COOL, FREEZER WORKS
Look in the back of the freezer, there will probably be a metal panel with a plastic vent on top.
Look through the vents in the metal panel, and you should see the shiny metal fins of the evaporator. If the fins or the vents are plugged with frost, that is your problem. The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. If either one of the parts fails, the freezer will plug up with frost every few weeks. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Posted on Jan 07, 2009
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
My RJ 523V-R refrigerator has worked perfectly for 8 years, but suddenly stopped cooling the fridge properly while the freezer seems ok. how can I fix this?
Often times their is a fan from the freezer section to the refrigerator section, of some brands of boxes. If the fan goes out, the refrigerator sections no longer cools.
May 23, 2014 | Electrolux Refrigerators
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
Aug 19, 2011 | Refrigerators
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
The freezer is not freezing. Is cold only.
The problem which you mentioned is related to faulty/ weak compressor.--------- I will explain with more detail.------
Jun 28, 2011 | Refrigerators
Frig stopped working but freezer is good? Help... I am handy.
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Feb 24, 2011 | Maytag MFD2561HE Bottom Freezer French...
My samsung fridge section stops cooling but freezer is working
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Samsung Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Top refrigerator section will not cool
Check the evaporator fan , freezer must have a fan to avoid ice formation, if evaporator does not work, thermic sensor jams up and freezer stop working. The fan is located behind the panel in the freezer.
Check the back of your freezer, If there is frost or ice, then the unit is not defrosting.
This is often caused by problems with evaporator system.
Sometimes you also need to check the defrost timer, located at the top of the FFC on the Top freezer.
Check also the defrost thermostat, which is on the evaporator inside the freezer.
If it isnt defrosting, change both.
Sep 02, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
100 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
