Question about Dishwashers
Vulcan Dishlex Executive 14-10 Dishwasher leaking onto floor from right hand side when it was filling at start of cycle. Husband has checked the following: both pumps (main and waste) hoses, solenoid switch (inlet). Where can we find the float/level valve? Could this be the problem? What else to check? This is the second time it's happened - I don't use it that much. The previous time my husband replaced the inlet and outlet hoses. What is the proper level for water fill - never above the base of the door level? When I opened it, it appeared to be almost too high
  • 3 more comments
  • Sharron Woolley Apr 24, 2010
    Thanks for the info, taken on board. I don't think it would be too much suds, I've only ever used the amount nominated by maker. I DO think the door seal may need to be replaced as well, but even AFTER I had stopped the machine with door open, water was still leaking out on the bottom right. What is it that ensures the water level is never too high and where can this be found to be checked?
    Due to the time differences around the world (I'm in Australia), perhaps Rylee has signed off for the night - I however, have had the dishwasher in parts on it's side on the kitchen floor for days so I would appreciate others comments too please
    Thanks for reply Rylee. I use hot water straight from tap and do not use the element heat up facility.
    I'm having trouble making up my mind about all this 'water temp' talk as to having relevance for fixing leaks (?)
    Is there a water level adjuster that needs to be looked at? I AM interested in making sure this is clear and has not been clogged up. I think I have found something like it UNDER the machine but I cannot see where it takes the water from.
    I am loath to turn the dishwasher on again to try it out without finding anything wrong with it, because it's a bl**dy nuisance cleaning up after it!!
    Also Rylee, (by way of explanation)
    The flooding appears to have occurred at the very beginning of the cycle when it was filling. As it was filling the spray arm was working I could hear it. We're pretty sure the outlet pump and solenoids are all working OK (my husband is electronics engineer).
    The solution was partially helpful - don't know so much about the water temp and suds being a problem though. More likely than not there is a problem with (perished) seals and since we don't have those (and my husband has not long been out of hospital - painful bending) I have called a service repairman who will have the seals and could check the water levels for me. It's a bit unfortunate that he can't get here for another 5 days, but as I said my husband didn't really find anything wrong and being loath to try it out again is a pain (water spillage) will have to put it all back together again to make room in the kitchen meanwhile. Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If you have water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference. Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. You should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear). Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson. An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Apr 24, 2010
  • Rylee Smith
    Rylee Smith Apr 24, 2010
    Sorry for the late reply. check the Water temperature by using a thermometer inside
    the dishwasher to measure the water temp. It should be as close to 125 degree F
    to 140 degree F as possible. Now try using the temperature boost feature if
    your dishwasher is equipped with this cycle feature and check if this will help
    your wash ability issues.
    Now check the Powder soap by making sure that you store
    your soap in a dry environment and it is not stale and clumping together.
    Possibly try a different detergent like a liquid or gel. Also, make sure the
    dishes are loaded properly, or dishwasher is not overloaded.
    To check the proper filling dishwasher will fill with
    water up to and around the heating element. If water is more below the heating
    element, you may have low water pressure or a problem with the fill valve. Try
    & listen if it sounds like it is spraying the water around with enough
    pressure.
    For low water pressure, try to clean the screen at the
    entrance of the fill valve, sometimes the fill valve can fail and not allow the
    proper water into the dishwasher and may need to be replaced. And, check
    the spray arm and pump cover for splits or leaks. Also make sure that the water
    is draining and is not accumulated in the dishwasher, if it is in
    dishwasher then check for clogged drain hoses and drain pump.
Float switch dripping water onto floor while dishwaser running
You will find that the flood switch will be operating due to the leak, it will most likely be from one of 2 places:
1. Around the door seal, Give it a clean and check for splits/damage, and make sure screws on door hinges are tight.
2. Check the rollers that screw onto the inside of the dishwasher cabinet, The screws on these can come loose and cause water to run down into the base, check they are tight.
Hopefully this helps.
Mar 04, 2012 | Dishwashers
How do i switch on the volcan dishlex 100s dishwasher
Hi just read your posting.Do you mean Vulcan Dishlex 100s?Have you got 1 big timer knob on the front right and 1 small knob to the left of the big timer knob?Or have you only 1 big timer knob?Please reply with additional information and I can help you solve this problem.
Jul 23, 2010 | Dishwashers
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
I have a Dishlex Global 500 dishwasher (DX500lWW*b). Woke up the other night to find water all over my kitchen floor. The hot water hose connector to the hot water tap split (bursted). The dishwater was...
I found this
"Hi - answer I was given by Electrolux Help was: pull machine out from under bench onto old towel, tip GENTLY onto left hand side (your left as you face the front of the machine) after it has drained, stand up gently, put back & turn on. Apparently it is the overflow trough reading as full ('oF' Overflow). Then run through some dishwasher descaler or Finish dishwasher cleaner. Worked for me."
http://www.howtomendit.com/answers.php?id=79783
Oct 05, 2009 | Dishwashers
Dishlex 500 dishwasher doesn't fill.
The cup looking device shoud be a switch that turns the solonoid off if water leaks there ,Try bypassing the switch to see if it works,Also check the door switch to see if it is making,Hope this helps Cheers.
Jul 30, 2009 | Dishwashers
Vulcan Dishlex 160 Diswasher
Hello Ranjan_MYD Welcome
You said, You have Vulcan Dishlex 160 Dishwasher which was kept in good conditionafter using for few years, then it was NOT used for few years. When itis installed again in a newly constructed house having 3 phase powersupply, the dishwasher functions well, does the job, but only just atthe end of the drying cycle before completion of the washing job itmakes some click noise and the power trip occurs. When intended to useagain the same event recurs. Any clue please? I can't recall the nameof the manufacturer. Also would it be possible to get an user manualprint out from the web please?
Your machine is and Electrolux Dishwasher.
Here is a site you can get a manual from:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man&cmpid=RegEmail
Let me know how you do!
Huuum
Please remember to leave a rating!
Oct 22, 2008 | Dishwashers
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Leaking dishwasher
what sort of soap powder do you use
some soap powders foam a lot in machine causing dishwasher to leak through seals
also check that the machine is square that is the door is closing parallel with cabinet
do not use power balls in machine just standard dishwasher detergent and separate rinse aid
Feb 02, 2008 | Dishwashers
Vulcan dishlex mark 8 leaking water from bottom front door in wash cycle.
try adjusting the feet at the front of your dishwasher so it leans back slightly to keep the water towards the back of the washer
Dec 07, 2007 | Dishwashers
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Dishwashers Logo
77 people viewed this question
Top Dishwashers Experts
