Question about Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
I forgot my password to my lnksy router - Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point
  • 3,866 Answers
What you need to do is locate the reset button on the back, stick a paper clip in there hold it down for 15 secounds to all the lights flash or come on, let go then once its booted back up the router will be at its defualt password.
Should be admin/admin
or admin then password
This defualt password can be found at www.linksys.com along with the same instructions I am telling you.
thanks please do be respectful and leave a rating and some feedback.
Posted on Apr 24, 2010
Forgot pass word
Press the little recessed Reset button in the rear. You press it with the tip of a pen. Have you checked for a label under the unit?
Once resetting, you will have to set it up again.
Dec 16, 2015 | Belkin Computers & Internet
I forgot my username and password Can you please help me? my number is 0435215262
If you are ask router user name or password related then i share a informative links visit and read it.
Forgot router username and password or need to reset router and Linksys Phone Number
Thanks,
Sep 18, 2014 | Computers & Internet
D-Link wireless router forgot password how may I recover or assign a new one
A wireless router password wont be recovered unless you still have the password you can enter or if the router is unmanaged without an admin password.
another option would be resetting your router to be able to get through the router and assign a new password.
here's how: you need to directly connect your computer or laptop wired going to your router not using a wireless one. then reset, make a new network configuration and put your admin password later. dont forget to backup your router config. in a folder together with your password so the nextime you forgot any thing or change anything. just look back to your folder where you put your backup config. and password.
Jun 24, 2012 | D-Link Computers & Internet
I want to set up my sicuirity (lnksy) model WRT546WB
Connect a LAN cable from the Linksys to the LAN port on yourcomputer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 27, 2012 | Linksys WRT54G2 Wireless Router
Unable to connect my tv to the router because i forgot the password
You forgot password to router or password for connection? you can check for the password by getting into router, or can you reset it?
Jul 14, 2011 | Zyxel NBG-415N Router
I forgot my password i have a sheet that says router username and router password but they are not working
Hi Friend,
If you have forgot the password then we have to reset the router to its factory default settings so that you can re-configure the settings (since the password of your choice is not working)
In order to reset the password please follow the steps:
1. At the back of the router there is a small/tiny button (red/black), this is the reset button.
2. Push and hold this button for 30 seconds(make sure the router is turned on).
3.After 30 seconds turn the router off and wait for another 30 seconds.
4.Turn it on and reconfigure the router as per your requirements.
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Linksys WRT120N Router
Forgot my password
If you forgot your wireless password you can log into the web interface and click wireless, then wireless security. If you forgot the router password, the best solution, and this goes for all routers is to locate the reset button (usually a small pin hole on the back of the router). Unplug the router from the power supply and press and hold in the reset button with a paperclip or pen tip. While holding the reset button, plug the power back into the rear of the router and continue holding for 10-15 seconds then release. This ensures that the router is reset to factory defaults and then you can login with default username and password. Hint: usually admin is the username and the password is left blank.
Mar 14, 2010 | Belkin (F5D7230-4) Router (587009)
Lost my password.
Unfortunately you will have to reset your router and re-set it up all again, this time write down your password & WEP/WAP key. Look for a hole at back of router remove from power and push the little button for a few seconds.
Feb 19, 2010 | Linksys Wireless-G Broadband Router
Forgot my network key password
For wireless or to manage the router?
If you forgot the wireless key password, you should be able to get into the router through a web interface and get or reset the wireless password.
If you don't remember the password to manage the router itself, it should have a "Reset" or "Go Local" button the back of the unit. Press and hold that for about 5-10 seconds. This will set the unit back to factory defaults and you should be able to log in again to set up your wireless settings.
Aug 09, 2009 | Belkin My Essential (ME1004-R) Wireless...
I forgot my password for my encore router
If you are referring to the password to get in to the router page, it is admin for both username and password field.
Dec 23, 2008 | Encore 802.11G WIRELESS LAN ROUTER...
Linksys Wireless-G WAP54G 802.11g/b Wireless Access Point Logo
98 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
