Question about DeLonghi DEBIGE 2440 Electric Double Oven
Cda double oven
My oven fan sounds like its vibrating when reaching tempreture once started will not stop untill switched off when restarted buzzing sound stays off till oven has been on for some time
  • gameon Jun 17, 2008
    have the same vibration problem. Not the fan as the vibration noise occurs even without the fan on. took fan cover off, no observable vibrating parts. Noise seems to be coming from the back of the oven, not in the oven cavity.
    noise occurs with just the oven light on, very strange.
SOURCE:
SOURCE: CDA double electric double oven user manual model snr 99
I have had installed a CDA electric double oven. Its been in approximately 3 years but my main oven looks like the thermostqt has gone. The on/off lightdoes not go off. The Model No. is CDA 708 I can't find the Serial No. Can it be renewed I live in Nottingham.
My email address is - [email protected]
Posted on Jul 24, 2008
heatman101
  • 43501 Answers
SOURCE: Temperature in Kenmore double oven will not reach
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on Apr 11, 2010
  • 523 Answers
SOURCE: oven not reaching tempreture
check to see if both the broil and bake element work
check for proper power
Posted on May 06, 2010
  • 52 Answers
SOURCE: How do I replace the
ISOLATE MAINS POWER BEFORE WORKING ON THIS APPLIANCE
Remove the back of the oven check temp controller before replacing or buying element, as this can often stop any heat being produced. The element is in front of the fan, if this model is fan assisted, remove fan, after removing element inspect to see any small hole in metal, if you see a large hole more than 10mm , this could be a sign that the fan needs cleaning. Clean fan with WD40, do not switch oven on untill fan has dried off. Then replace element, switch oven on low with door open, if you feel slight heat, go for a full test, gradually build up heat, keep on for at least 30 mins, make sure the oven reaches temp, you can expect some smell from a new element, this is protective oil, and considered normal.
Posted on May 17, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have not had any problems with the double oven
Hello Kathi,
The F3 code means the oven sensor(electronic thermostat has shorted out) if it happened using the upper the uppen oven sensor is bad and if the lower oven that one is bad,it only affects that oven and the other one can be used, if it something you think that you could repalce the part number is 74010385, seeing the new one you would know where it goes if you chose it to repair yourself a google search using the part number should be very easy to find the part
Posted on Jul 26, 2011
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
How do I replace the bottom oven element in a CDA CD 907 double oven
May 10, 2011 | Ovens
BOTTOM OVEN GOES OFF AFTER TEN MINUTES THEN TURNS ON WHEN IT COOLS DOWN
you have to be able to check the ignitor in the lower oven sounds like you have a weak ignitor when this happens it is taking to long for the oven to light and when it reaches to a tempreture it shuts off the ignitor in which case when it trys to reach to the tempreture that you have set it trys to ingnite again look to buy a new ignitor
Apr 28, 2010 | Stoves Premier 720GRa Gas Double Oven
Oven stopped working halfway through cooking. grill still works but top oven also stopped working
Sounds like to overheat device(s) kicked in. Is the background cooling fan still operating? i.e. that is the fan that continues to run for about 10 mins once everything on the device is switched off.
As well as hearing it, you should be able to feel a gentle draft of air coming out of the gap between the top and bottom doors.
Oct 04, 2009 | Stoves 720EF Electric Double Oven
Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
Aug 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Loud, vibrating noise when turned on that lasts until it reaches 350 degress
Sounds like the oven fan is loose or there is a large build up of burt material on the fan making unbalanced
Jun 09, 2009 | Ovens
I have an electrolux icon double wall oven. I turned on the self-clean function for 3hrs and it making a very loud noise during the cleaning process. Is that normal?
yes, if the humming is not the loud sound then the fan may need some lubrication or if it is tripping the circuit it will need replacing , but if it seems like it is a viberating noise from the fan , then it could be that its bearings are bad , but the whole fan motor would still need to be replaced , but if it sounds like it just may be a loose fan motor , then tightening up the screws on the motor would stop the vibrating sound and or the fan blades from scraping metal( another sound you may be hearing )
Dec 24, 2008 | Electrolux ICON 30 in. Double Wall Oven
Won't heat
theres a oven control/ dislay kit that needs to be replaced to fix both of thoughs problems at the same time
Nov 24, 2007 | Thermador SMW272 Electric Double Oven
Bosch HBN 455 Oven Cooling-Fan Issue
After the oven is switched off, the after-run of the cooling fan is controlled by an electromechanical thermostat switch. The fan can switch back on, due to residual oven heat that accumulates within the oven's outer case and reactivates the cooling fan temperature switch. Considering yours is making buzzing sounds and activates on and off, the fan's thermal switch may have dirty contacts or just be defective and require replacement.
Sep 12, 2007 | Bosch HBN 455 Stainless Steel Electric...
DeLonghi DEBIGE 2440 Electric Double Oven Logo
151 people viewed this question
Top DeLonghi Ovens Experts
Jason Harris
Jason Harris
Lollo Pop
Anthony Ward
Anthony Ward
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
