Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
How do you re assembly brake handle poulan 2150
How do you re assembly brake handle unit on Poulan 2150 after cleaning, which way does spring sit in handle
  • dontbother10
    dontbother10 May 11, 2010
    A Poulan "2150 Predator Gas Type 6" IPL follows (may not be your saw)(the LE suffix is a Wood Shark)http://www.ordertree.com/modelinfo/PWE/2... There is no breakdown, they want you to order a new cover $20±. The cover appears on different print names with different models (Handle & External Assembly) above. Poulan.com (all)http://www.ordertree.com/modelinfo/POULA... The dash number of your serial number is the type. 2 - Do you have a friend with a cover you can look at?
    President:
  • 2,220 Answers
Hello Larsens;
A Poulan "2150 Predator Gas Type 6" IPL follows (may not be your saw)(the LE suffix is a Wood Shark) http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
Poulan.com (all)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Do you have a friend with a cover you can look at? The brake will need to be lached open (enlarged) to refit the clutch cover on your saw.
Detail A here is a good representation of a Husky chain brake, they are all similar and this may be helpful.
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601077.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
How to fix the throttle trigger lock on my poulan 2150
You will need to replace the trigger and throttle lock lever, they come as a pair part no. 530071305, to replace them you will need to drive out the two pins securing them in the back handle, you will also need to remove the throttle rod from the trigger.
Feb 24, 2012 | Poulan Garden
Poulan chainsaw 2150 How do you put the round spring back into the opening at the end of the bar
Not sure what spring we are talking about, is this the anti vib spring? or the chain brake band? there is no spring on the end of the guide bar.
Apr 30, 2011 | Poulan Garden
Unable to release chain brake on Poulan 2150 2.1c.i. Unable to reassemble the chain brake cover.
You should have released the chain brake before removing the side cover. Try using a wide, heavy, flat-blade screwdriver to release the toggle mechanism for the brake in the outer cover which should expand the brake ring to allow it to go over the clutch drum. Hope this helps!
Nov 03, 2010 | Poulan Garden
Poulan 550 Series push mower won't pull start
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
May 28, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
How do I reinstall the chain brake on my Poulan Wild Thing??
Find your model number add a LE suffix (i.e. if 2375 make it 2375LE) the "Handle, Chassis, and Bar Assembly" shows what detail is available. If not enough detail tell Poulan! Maybe it will improve for the next guy. If not happy with Poulan answer tell Husqvarna (parent company).
An entire new clutch cover (2375LE Type 2) item 36 pn545139903 is $19.43.
Poulan.com
Sorry to not be more helpful but this is all we can do. HTH
Lou
Oct 04, 2009 | Poulan Garden
Installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Sep 14, 2009 | Poulan Garden
I have a poulan 18" chain saw. The safety band that goes around the clutch came off. Need info on how to put it back on
You don't list your model; There are probably over 100 to choose from. Find your model here:
Poulan.com
Open the IPL. find the "Handle,Chasis and Bar Assembly" or similar page. That is the only drawing showing the chain brake parts. If you aren't able to repair it using that your options are to find your friendly neighborhood chainsaw shop or a new saw. HTH
Lou
Sep 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain brake Assembly
A drawing of a Poulan Wildthing can be found here:
http://www.ordertree.com/modelinfo/PWE/2375-Gas-Saw-Type-1/75.2375-Gas-Saw-Type-1.1.59.1.html
Click "
View the illustrated parts list [Go]"
There are multiple drawings, this one may not be the correct one. The detail isn't very good but this is the best illustration for your saw. The "Handle, Chassis, and Bar Assembly" shows what is available. GL
Lou
May 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan P3314 Automatic Oiler
Go to Poulanpro.com and look at a parts explosion and they also have a toll free number that might help. let me know if not and I will research more.
Jan 10, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
337 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
