Question about Whirlpool LER4634J Electric Dryer
Dryer runs but does not heat
The dryer seems to be running but there is no heat, when I open the door it is cool inside.
  • 578 Answers
Probably the heating coil has failed.
It is a simple, plug-in replacement.
To locate it, unplug the main power cord then remove the lower back panel. The heating coil is located in the air intake path and secured by 2 screws. Remove the 2 screws, remove the 2 power wires. Take it to the local appliance repair parts shop and get a replacement. Should be up and running for under 35 dollars.
Posted on Apr 24, 2010
I have a Garland Mater 200 electric oven and the fan continues to run even with the door open. Is there a switch / sensor that controls that?
https://www.manualslib.com/manual/55869/Garland-200.html?page=103#manual
This web site had a manual that may answer you question. It seems that here is a heat/cool switch. The cool switch is designed to function to cool the oven down by running the fan with the door open. If you close the door, it will heat so the door has to stay open.
Aug 20, 2017 | Garland Ovens
My Whirlpool duet sport dryer got hot and shut off after running 20 minutes.
Sounds like you may have a bad heating element that has grounded. You should have this looked at to make sure if you aren ot handy to open the dryer up and inspect the heating element your self. make sure the element wire has not broken and fused itself to metal inside the dryer heater housing.
Feb 02, 2017 | Whirlpool Dryers
Why is my frigidaire dryer quitting after running a few minutes. It runs fine on the no heat so the motor is alright.
Not neccessarily the cool cycle uses less power and pressure from the motor, the winedings on motor may be bad or going out? does it shut down after 20-30 minutes of running? u may also want to check ur venting and ur thermostats the cycling and the thermal cut off, if ur having an over heating problem they can and will shut off the cycle as a safety precaution
Jun 22, 2014 | Frigidaire Electric Dryer
Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Aug 03, 2009 | Maytag Dryers
NO HEAT WHEN CLOTHES ARE ADDED
Check to see if vent hose is not restricted. If it goes up inside wall, it could have lint clogging it. Most dryers regulate heat with air flow. Wet clothes can restrict flow even more if vent is clogged or pinched. Air flow is crucial to heat cycle. If the vent is resrticted, heat will rise quickly, but not cool down fast enough to allow heat thermostat to cool down and turn on heating element again. It may seem hot inside dryer but if no air flow it will increase dry time or not dry them at all before timer shuts off. If vent goes up inside wall, buy a small chimney brush and try cleaning out vent from attic if you can.
Jul 24, 2009 | Maytag MED5800TW Electric Dryer
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer continues to run.
barnardfl
look for a cool down thermostat on the fan body. this thermostat opens on cool, and is in the motor circuit, not the heater circuit as the other thermostats are. After the timer switches off the heater and motor, this thermostat keeps the motor running until the temperature drops below ~45C, drawing unheated air through the dryer. when they fail they weld closed and do not switch off
aaaa3786
If knob does not move, there is likely a stripped nylon gear in the stepper motor for the timer
timer motors cost $~14 if available in your area, and attach to the timer body by two screws
rebuilt timers can be purchased at many parts stores, labelled as almost anybrand as many are interchangeable $~40
new timers are around $~60
Oct 09, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
61 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
