Question about Home
I had a spa installed by an electrician. In wiring the spa he ran a 220 power supply to the spa. At first there was no power. I had to call him back and he figured out the breaker was bad. The water was on going to the spa. When he said to hit the power button on the TR002Y panel I did. It came on said 56 degrees then shut off. It would not come back on. He said he knew nothing about this and left. I got really frustrated by this and got the book out. It said it needed a 110 power supply not 220. I called him back and he installed the right breaker, receptacle, and plug. The steam generator still won't power up. I am wondering if the thing has a fuse that could have blown. It did not smell like it burned up. It simply just cut off with the wrong power supply was hooked up to it. Can someone tell me if we have to replace a fuse or reset it somehow?
  • trish Apr 24, 2010
    The spa is a Korral Steam Spa Model KC-8008. The book that came with this unit was poorly written. The jets on the tub part work fine. It is the TR002Y Steam Generator that is the problem. I really can't hold the electrician responsible because the part that said 110 was on a separate piece of paper my husband neglected to give him. I located the information in the packet and talked to a company that sells the generator. The electrician wants me to find out if there is a fuse before he takes the generator apart. He said if there is a fuse he would be more than happy to replace it. He has never seen a spa like this before. He has hooked up plenty and never seen this type of spa. Our spa is a European spa and the book he was looking at specified a 220 ground fault breaker. The piece of paper I found that said American installation instructions said 110/30amp service required for steam generator. I guess the TR002Y was placed in this unit here. I bought this at an auction. It was still in the crate. I have to make it work.
    So any knowledge on this generator would be an absolute plus.
    I had a spa installed that I bought at an auction. The spa is a Korral Steam Spa Model KC-8008. The book that came with this unit was poorly written. The jets on the tub part work fine. It is the TR002Y Steam Generator that is the problem. When initially hooked up directions on one set of papers said 220 GFI breaker and hookup required. Initially it did not work because the breaker was bad. The electrician came back out and replaced it. The red light on the panel in the tub came on. The water supply was on going to the tub. The panel was displaying 56 degrees and just shut off. My electrician really knew nothing about this spa so he suggested calling a spa specialist. The guy that came out knew nothing about my spa either. I got frustrated and started reading everything in the packet. I came across one sheet of paper that was labeled North American installation instructions. It stated that the unit was supposed to be wired for 110 not 220. I really can't hold the electrician responsible because the part that said 110 was on a separate piece of paper my husband neglected to give him. I located the information in the packet and talked to a company that sells the generator. They confirmed it is a 110 supply needed. The electrician feels bad because he followed the original instructions my husband gave him. The electrician wants me to find out if there is a fuse before he takes the generator apart. He said if there is a fuse he would be more than happy to replace it. He said he did not smell nothing that smelled burned and feels there may be a fuse that blew in the generator. He just doesn't want to take it apart to replace a fuse if there isn't one in there. He also said he would be more than happy to reinstall another steam generator, but we would have to buy it because my husband did not give him that piece of paper. He has never seen a spa like this before. He has hooked up plenty and never seen this type of spa. Our spa is a European spa and the book he was looking at specified a 220 ground fault breaker. The piece of paper I found that said American installation instructions said 110/30amp ground fault required for steam generator. I guess the TR002Y was placed in this unit here. I bought this at an auction. It was still in the crate. I have to make it work.
  • 155 Answers
This may not be the answer you want to hear but I have had much experience with electricians as a General Contractor. I know a thing or two about wiring. I have no idea how he accomplished this where he hooked the other hot leg to. I do know that the electronics are sensitive. My advise is do nothing get a qualified whirlpool service guy. This is the reason why, if you do anything you will void the warranty. If it comes to the understanding that it was the electrician fault and warranty will not cover you can go back onto the electrician. However, if you do anything he could say it was caused by you. I feel the problem is going to be the electricians problem. Any more info as far as trip fuses would need to know the model of the whirlpool which you can comment back with. Thanks for using Fixya. Good Luck. Jeff
Posted on Apr 24, 2010
  • 1 more comment
  • Jeff Drake
    Jeff Drake Apr 24, 2010
    Now it makes sense yes they use 220 overseas, whole different electrical system. Give me a little bit to research a little bit on this. will get back to you as quickly as possible. Thanks Jeff
  • Jeff Drake
    Good Evening again, this what I have found on the TR002Y Steam Generator. It is put out by Bathtek which is still a European company. What I know of electronics from Europe is that most times there is a switch that has to be moved to accomodate the 110 style of wiring or something changed. Unfortunately I haven't found that information yet will still look, However, like I said on my profile 2 minds are better than One so here is the web site in which the TR002Y Steam Generator can be found. You can send an email to them directly. Meanwhile I will continue to look myself. Jeff
  • Jeff Drake
    Jeff Drake Apr 26, 2010
    I have yet to find you any new answers, I have emailed the company and am waiting for a response back. Jeff
Spa is hooked to ground fault breaker but breaker will not stay on.....
ground leakage in the circuit
water , bad insulation , incorrect wiring
call an accredited electrician to check/test the circuit and system
May 28, 2017 | Pool & Spa
It is prewired for 220Volt. How to rewire it for 115 VAC
contact a licensed electrician when installing electric to pool equipment , your life and loved ones lifes could be at stake if done improperly
I will say it would be less expensive in the long run to operate the pools pump on 220 voltage even though an electrician will be needed to wire it (strictly speaking of power costs over life time of pump motor )
Jul 23, 2015 | Pool & Spa
Balboa spa user manual
Unless it's a 110 tub, you don't. If the system is designed to run on 220 the circ pump and flow pump will not function properly, the power pack may not function and the tub will never reach temp. If it is a 110 hot tub I would still suggest having a licensed electrician run the line for you. Most insurance companies will not cover any type of hot tub related claim unless installed by licensed tub tech/electrician. If you insist on wiring it yourself, the BLACK wire is the "hot" wire carrying the current. In 220 installations the RED wire is the second "hot" wire. The WHITE/GREY is the neutral wire, and the GREEN is the ground. But again, I STRONGLY recommend paying the $80-$95 bucks to have it done professionally. I hope this helps =)
Nov 03, 2013 | Pool & Spa
What is the difference between neutral and phase?
neutral is the white wires on each power phase phase is the number of hot lines to run pump 120 volt 1 phase 220 volt 2 phase 3 phase has 3 lines to it let electrician handle this
May 31, 2012 | Waterway 5 Hp 230 Volt 2 Speed Side...
Jazzi pool and spa main power connections
you dont
it requires an electrician with experience to connect it safely
call an accredited electrician and save your life
Dec 31, 2017 | Pool & Spa
Power cord was ran over by lawn mower and cut into a black and white wire from inside was unplugged at this time I need to know where does white and black wire plug back in
Is this 110 volt or 220 volt?
110 = white wire goes to the neutral side of the circuit ... or the silver color screw on the plug. The black wire goes to the brass color screw ... or the "hot" side of the plug. The green wire goes to the green screw.
220 = youwill find on the 220 20 amp plug there are two brass colored screws + a green screw for the ground.
Aug 22, 2010 | Intex '10 Saltwater System Pool...
The LED displays the letters 'dr' flashing & 'SnS' flashing what does this mean because my spa is full but will not heat.Also when the electrician came to power up the spa he's just ran it off a...
First, get a new electrician. Circuit should be a dedicated one, GFCI protected.
Next, the dr means the heater doesn't have sufficient water in it. The SnS means the sensor is out of balance. If the SnS is blinking, it just means the spa is shut down, more than likely because of the dr message...Check all your valving to make sure the heater is not isolated..
Jul 11, 2010 | Pool & Spa
120v hot tub wiring diagram! Need to wire fro 120v! there is a red, white, black & green to connect the wire from the power plug. The power cord only has black, white & green. Which is the hot and...
I would expect your tub is either 110 or 220. Currently you are set up for 110. Based on that ... you disregard the red wire.
If your tub can run on 220, you should run it on 220 as this is more economical.
You should probably have an electrician check this out and make any changes to assure proper and SAFE operation of your tub. You are using a GFI, correct?
Thanks for your interest in FixYa.com
May 15, 2010 | Pool & Spa
Want to convert a HoneySpa Venus model hot tub from 110 volts to 220 volts. Need a schematic for the tub; and the manufacturer doesn't seem able to supply one. Can you help?
Find the model of the motor ... find the model of the heater. Go to your professional pool supply place. Ask them how to rewire the motor based on the model and make of the motor you provide. Ask them about the heater ... it may already be 220 but maybe not. They can tell you almost instantly.
You will also need a 220 (double pole) probably 60 amp GFI.
You may want to consult with a licensed electrician in this case.
Apr 16, 2010 | Pool & Spa
Home Logo
345 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
