Question about Whirlpool Duet GHW9150P Front Load Washer
Drum is so out of balance baffles are being scraped off
We need to know how to adjust the drum, it is so out of balance the baffles are rubbing on the outside and are snapping off
  • Whirlpool Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Apr 26, 2010
Loud metal noise from right rear wheel Volvo v70
If they're drums could be rust on the drum rubbing on the backing plate, or a loose brake component rubbing inside the drum.
Mar 18, 2015 | 2001 Volvo V70
Hoover WDM120 scraping noise heard when drum spinning with a load in washing machine.
have come across this prob before the noise you describe sounds like an underwire from a bra or the condencer on the back of the mach some had a baffle plate fitted just where it goes onto the backof your mach on some this came loose and caused it to scrape of the back of the drum hope this helps .
Jun 07, 2011 | Hoover H120M Front Load Washer / Dryer
I left a screw in my jacket that got washed now the screw is lodged between the steel drum and plastic shell, you can hear it scraping when you spin the drum, how do i get to it and get it out
Try to remove one of the plastic baffles inside the spin basket. They are held in place by one phillips head screw. If you take that screw out you should be able to slide the baffle toward you and remove it. Sometimes, but not always, in manufacturing they move a little catch to keep the baffle from moving; in that case it will be hard to slide it. If you can get one baffle out, you will have a pretty good size opening to look for your screw.
May 20, 2011 | Kenmore 44102 Front Load Washer
My washing machine's drum is making a scraping sound when turning
There are two different types of "drum balancers" manufactured into washing machines today... One is a disk type (most washers with this have 2-6 depending on age, manufacturer, and quality), the other type is a self-balancing style. It sounds like you need to order some new drum balancers. The repair will take approxmiately 1-3 hours depending on if the it is a front or top-loading machine.
Hope this helps, James
Jan 05, 2011 | Hotpoint Washing Machines
Dryer drum is scraping against something and making a thumping noise as it spins
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Problem 1... Your scraping noise is probably coming from the drum rubbing the door as it rotates, you door seal may need replacement.
Problem 2...Your other problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 31, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Change one baffle only or do you need to replace all three?
No as long as the baffles are screwed in properly and no other damage is present it is not important at all.
Sep 30, 2009 | Kenmore Elite 45986 Front Load Washer
Candy washing machine smoke coming from inside
it is rubbing on spin cycle due to being out of balance.Rubbing wont occur when turning by hand.
Stop by your local hardware store for a packet of drum balancers.
Aug 16, 2009 | Washburn Electric Guitars Modelno. X10-B
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
523 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
