Question about Frigidaire ATF6000ES Front Load Washer
My washer is flashing EFO. It is still woking though. any suggestions??
  • 15,935 Answers
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Posted on Sep 16, 2010
Affinity washer flashing EFO
Good Morning Friend,
I understand that your Frigidaire Affinity washer, model# ATF7000E, is flashing an EFO code. I do not show an EFO code for your appliance.
I do show an EF1 code, which means the drain pump is clogged. In this instance you would unclog the drain pump.
I also show an EF2 code, which means too much soap was used. All you would do for this would be to try using less soap.
It could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Affinity ATF7000E Front Load...
While washing the letters EFO flash. what does this mean?
If your washer displays EFO it means that you are not using HE detergent. You must have used too much detergent on a particular load.You have to use He detergents to fix this issue or else not using it will ruin your washer because regular soap makes too much suds.
Thank you!
May 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Flashes efo on display halfway through cycle
May 20, 2010 | Frigidaire Affinity ATF7000E Front Load...
What does it mean when washer says efo on screen
Thank you!
May 10, 2010 | Frigidaire ATF6000ES Front Load Washer
What does efo mean
Electrolux Washer Fault Code for EFO or EF0
Drain Filter is Clogged. Resolution => Click lint filter for soap buildup or other debris. Check drain hose.
Oversudsing - A high efficiency detergent was not used.
Too much detergent was added. Resolution => Use only a high efficiency detergent. Follow manufacturer's recommendation for dosage. Amount may need to be adjusted for water temperature,
water hardness, load size and soil level.
Hot water doesn't enter washer - Hot water hose is connected to the wrong faucet. Hot water faucet is not turned on. Resolution => Connect hot water hose to hot water faucet and hot inlet on
washer. Be sure hot water faucet is fully opened. Check water heater.
Jan 03, 2009 | Crosley CW5000 Front Load Washer
I have a front loading washer and it was flashing an error code "EFO' What does that mean?
I just spoke with customer support for my Affinity. They told me it was over sudsing (sp?). from using too much soap or not using high efficiency soap. Suggested running thru a cycle without soap to clear things out.
Aug 09, 2008 | Frigidaire Affinity ATF7000E Front Load...
Flashing EFO error code
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
Jul 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
I've read in a product review that Frigidaire put out a service bulletin regarding the electronic timer circuit board in these machines. Apparently enough of these boards failed to prompt a factory response. With this in mind, you should call an appliance repair center and ask them if they're aware of this Factory Service Bulletin. In many cases like this, where a part is manufactured defective, the repair could be free to you.
Aug 03, 2007 | Frigidaire GLTF1240A Front Load Washer
Error messages EFO and E10
It is simple. The wrong soap or too much soap will caused EFO to flash. I overfilled the machine with soap by accident. It started flashing with EFO and I went nuts. What could be wrong with it now?! Too much soap or not the right kind of soap will cause this problem.
Plus, I found a sheet of paper that gives the codes.
This is better than when the strainer plug gets filled up and you have to take the machine apart to clean the little strainer.
Apr 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
49 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
