Question about Husqvarna Sewing Machines
I have a husqvarna 755Q sewing machine that makes a ''ping'' noise when I increase the stitch lenth from 2.5 to 3.0 or above that. I just want to know that it's ok
  • 135 Answers
Try changing the needle
Posted on Jun 24, 2010
My sewing machine will not make decorative stitches?
Is it an embroidery only machine. Typically embroidery is done with the needle in a fixed position while the hoop is moved around.
Jan 05, 2017 | Husqvarna Sewing Machines
Have a Husqvarna model 320 Electronic sewing machine. . I want to darn using the 3 step zig zag stitch, but unclear about lenth and width of stitches setting,
Set the stitch width as wide as it will go. Set the stitch length to a low number so the stitches do not overlap each other but lay close to each other.
Nov 13, 2016 | Sewing Machines
I have restored an old singer 27 1904 pulled it down to restore it
Not exactly sure but I believe it runs straight off the spool across an to bob
Sep 26, 2016 | Singer Sewing Machines
My Husqvarna Prisma 990 does not stitch. I've re-threaded, checked the tensions, replaced the needle, checked the feed switch, and changed the bobbin. The machine runs and acts like it is stitching, BUT...
check the needle /hook timing
the hook should be at the needle just above the eye of the needle when the needle is fully down
take it to a service centre for adjustment and service.
Jul 06, 2015 | Husqvarna Sewing Machines
How do I choose stitch 2:07 for darning on the Emerald 183 Husqvarna Viking machine
Press the Menu button below the + for stitch length adjustment to rotate through the stitch menus. When you see 2 LEDs, you should be on the correct menu. Then press button 7 in the stitch selection area. Confirm this by checking the stitch selection on the display. (Make sure that you have the C foot in place.)
I hope this helps.
Jul 25, 2014 | Husqvarna Sewing Machines
How to adjust tension for thick fabrics
Thick fabrics do not need to have a tension adjustment. The stitches will form just as nicely as on finer fabrics as long as the stitch was properly calibrated to start with.
If the sewing machine has a "pressure" adjustment, increase the pressure until the fabric is easily transported (moves easily under the presser foot).
The pressure adjustment is generally located on top of the machine right above the needle shaft. Some machine do not have this option.
What challenges are you encountering while sewing on heavy fabrics? Maybe I can be of more help with this information.
Jun 15, 2014 | Husqvarna Freesia 415
Husqvarna making squeaking noise
try changing the needle
try a different bobbin--make sure the bobbin is turned the right way
in the bobbin case
also try a different thread
make sure the top has not come off the thread take up lever
also the machine may have a timing problem and need to be
serviced
Dec 08, 2012 | Sewing Machines
Husqvarna 2000 1974, uneven stitches
Take out the bobbin case, remove the bobbin. Using laquer thinner on a Q-tip or a thin rag, clean the center "hole" of the bobbin case. Then look at the post in the machine that the bobbin slides onto. Is there thread wrapped at the back of the post? Also clean the post with your cleaner. Once the post and the hole are clean, put a little sewing machine oil on your finger and wipe the post with it and the chattering noise of your bobbin will be gone.
Take the thread off the top of your machine, put in a new needle.
Turn your top tension to Zero and lift the presser foot, this will open the tension discs of your machine. Using a needle, scrape or clean the area between the discs. (Your needle also has a flat spot on the top of the needle, that faces the rear of your machine.) Also look for any rough edges in the hole of your presser foot or the hole in your needle plate. If there are any rough edges in the metal areas that your needle goes through, you would have poor stitching. Don't forget to put your tension dial back on the red dot before you sew.
Oct 21, 2009 | Husqvarna Sewing Machines
Husqvarna rose
2 things to check first:
1. Make sure the feed dog "switch" is in the correct position. It is located under the free arm, directly under the needle plate area.
2. Make sure your stitch length knob is in a position OUTSIDE of the orange reverse stitch positions.
Nov 25, 2007 | Husqvarna Rose
Machine stops and sews in place
sews only one stitch at a time and have to wait a few seconds before it will do this
Dec 16, 2006 | Husqvarna Lily 540 and 550
Sewing Machines Logo
44 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
