Question about QPS Que! Fire CD-RW Burner
I am getting error messages saying that I have no CD-R burn drivers installed despite having burned CD's in the past...
    Novelist:
  • 142 Answers
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:
  1. Click Start , type regedit in the Start Search box, and then click regedit in the Programs list.
    If you are prompted for an administrator password or confirmation, type your password, or click Continue.
  2. Locate, and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
  3. In the right pane, right-click UpperFilters, and then click Delete.
  4. Click Yes to confirm the removal of the UpperFilters registry entry.
  5. In the right pane, right-click LowerFilters, and then click Delete.
  6. Click Yes to confirm the removal of the LowerFilters registry entry.
  7. Exit Registry Editor, and then restart the computer.
Posted on Apr 25, 2010
Pioneer dvd firmware
What OS are you using? Are you trying to install firmware on the drive? Or are you saying you need a driver? No driver is needed for Windows since that support comes built-into the OS. You will need compatible burning software in order to burn disks. Are you getting a number with the error message? If yes, what is the number?
Mar 23, 2014 | Computers & Internet
I recently purchased a Toshiba PA3761U-1DV2 external multi burner/reader. I have a Toshiba Satelite Vista SP2 32 bit. The included software won't install. However the drivers did install and
It usually better using the burn software that came with the multi burner because it will be compatible with your multi buner. Windows media player burning cannot be compatible to all the burners on the market.
Mar 07, 2013 | Toshiba PA3761U-1DV2 DVD-RAM Burner
Im trying to burn cd but my computer dont burn
Do you have a CD Burner? Does your drive say CDrw on the Cd Drawer's door? Have you looked at My Computer to see if your drive is shown and if it says CDrw? Click Start/My Computer and see if your drive is listed and if it is a CDrw drive.
Have you been able to burn CD's in the past?
What error message if any are you getting when you try to burn a cd?
What Burning Software are you using? Windows Media Player? Nero? Roxio?
Apr 22, 2012 | Computers & Internet
Whenever I try to burn a cd in my DVD ram a message shows up saying it is not accessible, Incorrect function.? What do I do? ive tried to disable and enable the drive then reboot the sys., still the same...
try running the fix-tool provided by Microsoft on this web page
http://support.microsoft.com/gp/cd_dvd_drive_problems
If that fails then my suspicion is that either
1) the drive has failed
or more likely
2) because you don't have any DVD burning software, windows can't understand the blank DVD-RW disk. Thas basic packet-burning software installed with XP CANNOT write to DVD disks.
However there is a bit more to it than that - the Microsoft CD burning software (which is a cut down Roxio product) cannot co-exist with any other packet burning software (e.g. DLA, In-CD or simuilar) so if one of those is installed you have to DISABLE the MS CD burning capability on the drive settings tab. Even worse, Internet Explorer 8 is not compatible with DLA - which is included in quite a few CD/DVD suites including many of the later Roxio versions
My advice would be
1) un-install any CD or DVD burning software on the machine
2) disable the MS CD burning
3) run that Microsoft patch
4) Install some DVD burning software but DON'T install the packet writing software part of it
Note that after installing that patch you may also have to reinstall any DVD playing software
Nov 07, 2010 | Computers & Internet
The message "50.2 Fuser Error" has appeared in the window. Despite checking all the paper routes and finding nothing the message will not go away and the printer will not work.
That fuser error says that either the overtemp fuse is burned out, or the lamp is burned out, you most likely need a new fuser for the error to go away.
Dec 22, 2009 | HP LaserJet 2840 Printer
An unknown error interupts the burning of my cd.
try slowing the speed of the drive, before u burn does it ask what speed? change it from maximum to say 25. see if this helps, if not try to update driver for ur cd drive
Jun 01, 2009 | Computers & Internet
Cd burner does not seem to be working properly
Open device manager and uninstall the DVD device driver. Reboot. The system will automatically reinstall the needed driver.
Try it now, it should work normally.
Jan 17, 2009 | HP Compaq Presario S4000V (P8655P#ABA) PC...
Burner not installed message
James, I have found in the past that many computer manufacturers only install a trial version of some software. One major manufacturer, who shall remain nameless custum built a P.C online that included a CD burner, but I found out later that even though they installed the burner, they provided no burning software. It sounds as though you have no CD burning software installed. First, from the start button, go to control panel, then to add remove software. A list will compile showing all software installed on your machine. If you do not have a CD, or DVD burning program installed and your computer came with no CD's( most today do not) that may contain that program, you will probably have to buy your own at this point. Just to clarify, do you only have a CD burner, or is it a CD burner/ DVD ROM, or do you have a DVD burner. If you have a DVD burner, then you are capable of burning both CD's and DVD's. If you need to purchase burning software I would suggest you do an internet search for Nero, This is the software that I use. It works well in addition to being easy to use.On the Nero site I have in the past purchased their OEM version, the OEM versions are usually available at very good prices. I prefer to purchase software online and have a disc mailed to me as opposed to downloading it online just so that I have a hard copy if I ever need it. If you are limited to burning CD's, just get the CD software. If the device you have installed in your computer is a DVD burner, then purchase the DVD software and you can burn on both formats.
Sep 27, 2008 | Microsoft Windows Vista Ultimate Edition
Cd burner not working
I suspect you are doing nothing wrong... It sounds to me as if ya CD is gone faulty.. However download, install try Alcohol 120% & or Nero B4 ya buy a new one.. If after ya install and use those proggies it is still the same.. as I suspect, then as I said B4 .. ya gonna haveta get a new one sry.. :(
Aug 20, 2007 | Toshiba (SD-R2412) for Satellite A10, A15,...
QPS Que! Fire CD-RW Burner Logo
98 people viewed this question
Top QPS Computers & Internet Experts
k24674
SHIVAJI YADAV
SHIVAJI YADAV
pontelemon
pontelemon
Are you a QPS Computer and Internet Expert? Answer questions, earn points and help others
