Question about Mitsubishi WD-52525 52" Rear Projection HDTV
I have a wd52628
First I am wondering what kind of chassis is this tv and second when I changed the lamp all of a sudden there is a noise coming from the same area as the the lamp. it started to just be a faint noise and now it over powers the tv. the pic is good except the color is not very good but a good pic and the sound is great. What is wrong with this as I cant stand hearing all the noise to watch tv. Please help its a wd52628. Thanks
  • 1 more comment
  • Paul Langkau
    Paul Langkau Apr 24, 2010
    its like a raddleing noise and if I put my hand over the cover where the lamp goes in it goes away a little bite but it is still there and raddles real loud. It goes away when the lamp turns off. The color on the tv is faint in some spots too. And now that you mention the fan it stops when that stops.....and it starts when the lamp powers up
  • Paul Langkau
  • John Street
    John Street May 11, 2010
    There should be NO NOISE coming from the lamp area. The lamp is worth $200. You should get a tech to look at it. Did you vacuum out any broken glass/dust/debris before installing the lamp? The noise could be a high voltage arc. This needs to be fixed. This could be a damaged fan. This should be fixed. This could be a power block about to blow the new lamp. This should be fixed.
    Guru:
  • 513 Answers
This area of the TV is a cause of some expense in rear projection.
The fan controls the temperature of the lamp. An obstruction keeps the fan from coming up to speed.
The power block controls the power the lamp uses. This helps keep the glass of the lamp from breaking breaking.
An arc is a badly mounted lamp or a lamp defect.
Dust build up can cause overheating.
Most of this area cannot be serviced by a non-technician.
Posted on Apr 25, 2010
While we were watching Sony KF60WE610 TV suddenly a loud noise came from the back of the TV,. Sound and picture were gone, and the red light started blinking. We waited 2 minutes and turn on the TV . Sound...
Tv now,have a LED light indication "LAMP" on the frame are blinking or flashing.Metallic sound are clicking noises?Yes,sound like the board that call the Ballast board it is dead.This Ballast board only job are to ignite the tv projection lamp only.U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Partstore.com,Ebay.com to buy a new Ballast board for the replacement.The tv projection lamp might have to be replacement change too,because,when the Ballast board has died and exploded the voltages and current high voltages could have more than the tv projection lamp now could take.
Jul 21, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
LG DLP Suspected Faulty Bulb... how to be sure?
First pull back off turn TV on watch Fan behind lamp more then likely it is going bad Fixed LG 9months ago and it was the Fan.If Fan Stops turning Lamp will not light.
Aug 06, 2009 | LG Televison & Video
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Red lamp light stays light
I doubt that it is the optical assy. it sounds more like a chassis problem either on the DM or the FMT board.
check out www.tv-techs.com
if it is a chassis problem it will cost about $250.00 plus shipping one way to fix the chassis
Dec 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA dlp 50"
Buzzing is usually indicating the color wheel is defective. Or it could also be the lamp fan malfunctioning as well. My quess would be the color wheel as thats a fast moving part which is prone for bearing failure.
Aug 03, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
61 RCA
Your model is an ATC336 Chassis DLP when the LED blinks rapidly 5 times every 20 seconds that is an error code for a defective lamp. Your lamp number is RCA part 269343 you can get one here with fast shipping on sale for 169.00
http://www.purelandsupply.com/GeneralSearch.aspx?search=269343
Let me know If I can assist you further.
Apr 24, 2008 | Televison & Video
Turning on problem with Panasonic Viva PT-43LC14
Sounds as you have a bad ballest. The ballest is the power supply that turns your lamp on. You can check your lamp by removing it and it should be clear and no broken pieces of glass. With the lamp removed install the cover and turn it on you should hear no noise and when the power light turns red you should see a LAMP red led blink every 5 seconds. If no noise then the lamp is bad. If you do hear noise you have a bad ballist. Hope this helps. Frank
Sep 05, 2007 | Panasonic PT-43LC14 43" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
220 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
