Question about Garden
I got spark to the spark plug and I'm getting gas to the engine and it still won't start is there a safety switch some where that i may not know a bout? Model #917377070 craftsman lawn mower 6.5hp
  • 578 Answers
First, spend 1.50 for some starting fluid at WalMart.
Spray it into the carb air filter and try to start it again.
If it fires and runs for a few seconds, you have a clogged gas filter (in the gas tank) or a bad fuel line or a dirty carb. You can try adding a small amount (1/2 ounce) of carb cleaner to the gas a see if that gets the dirt our....
Posted on Apr 24, 2010
I have a briggs and stratton 13.5 hp power engine that wont start. The engine is almost new, oil level is good and when I remove the spark plug cap and dold it near the top of the plug and pull start it I...
there may be safety switches, but if you are getting a spark, that is not the problem. After you cranked with no start, is the spark plug wet with gas? can you smell gas in the cylinder after pulling the plug? It could be that your carb float/needle valve are stuck closed. Try lightly tapping the side or the carb.
Jun 08, 2017 | Briggs & Stratton Briggs Stratton Intek V...
MY MOWER WILL TURN OVER BUT IT WILL NOT START
if you spark a little starting fluid to it does it fire?if so then fuel is the problem then is the gas older than 30 days dump it out and try fresh gas if new gas then open the carb and clean it if it does not fire on starting fluid check for spark if no spark pull the top cover from the engine and look for wiring damage unplug the coil from the engine side of the coil and check for spark if no spark then the coil is bad and if its a riding mower the carb might have a anti back fire valve that could stick closed
Apr 27, 2012 | Garden
2003 kia Sedona won't. start
If this is a sudden occurrence and nothing suspicious happened prior, you most likely lost either gas or spark to the engine. You need to check for both.
Do you hear the fuel pump in the gas tank buzz on for a couple of seconds when you turn the ignition key to ON? Unless the fuel pump turns on and puts gas under high pressure at the fuel injectors, the engine cylinders won't get gas to start. Correct fuel pressure is crucial to know if you have a fuel pump (or fuel filter) problem. If the pressure is correct, it is probably not a fuel problem but a spark problem, although there are less common instances where a fuel injector circuit may malfunction.
The ignition system not producing spark at the spark plugs is the other common problem of no starts. Buy a cheap spark tester at a parts store, plug it into one of your spark plug wires, then crank the engine over and watch for a strong blue spark. You might need a helper to do this. If you see a consistent spark, the ignition system is probably good, although you should probably check more than just one plug wire-sometimes one bad ignition coil in a coil pack will cause no starting. Good luck.
Jan 28, 2012 | 2003 Kia Sedona
1993 chevy caprice classic wagon 5.0 8 cylinder hads a problem with engine shutting off with in seconds after start ! i did check for vapor lock in gas line, had new spark plugs replace, new fule...
Think the oil pressure switch keeps the fuel pump running once started. Suggest replacing Oil pressure switch. And no it won't effect oil pressure reading when it goes bad. The switch is a safety device. When you roll it over and the oil pressure drops the switch cuts off the fuel pump. Neat huh? Need some good feedback Thanks!
Jul 21, 2011 | 1993 Chevrolet Caprice
Have spark and getting fuel won't start 2002
Have you checked all your safety switches? Kill switch, kickstand switch, neutral switch? What do the plugs look like---are they wet and smell like gas? Are you getting a nice blue spark across the electrode? Troubleshoot the basic stuff first to eliminate those possibilites.
Jul 06, 2011 | 2002 kawasaki VN 800 A Vulcan
Im a motorcycle mechanic however Ido have a little knowledge of these machines I believe ther is a safety switch under the seat & in some cases in the seat itself
Apr 24, 2010 | 2001 Harley Davidson FLSTC - FLSTCI...
NO SPARK, SPARK PLUG GOOD,COIL GOOD AND CARB. GOOD, IS THERE A SAFETY SWITCH SOMEWHERE CAUSING THIS?
Hi..my name is Keith..and to answer your question..Yes there is several safety switches that will keep your engine from starting..i would check the seat switch..the neutral safety switch and the blade engaged switch..the clutch/brake switch...if all these check good..then write me back and i will help your further
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No spark
The selonoid on bottom of carburetor shuts off gas,if bad it will not get gas,It was installed mostly do to engines back firing when shut down this seloniod shuts off gas to main jet so there is no gas in carburetor during shutdown,no gas in cylinder no backfire.
May 12, 2009 | Garden
My Sears push lawnmower wont start....no spark. I think it may be the electronic ignition module(?) It has always needed to have a cleaning between the ignition module and the opposing magnet to get it to...
Hello:
>>The Following is a Basic Instruction File I Made for Checking the Coil/Ign Coil/Magnetron/Armature on Small Engines. Any Input is Appreciated.
>>**To Check the Ign Coil; Remove the Spark Plug/s.
>>With a Good Plug, Wrap a Wire Around the Threads of the Plug and Attach the Other End of the Wire to the Engine Block. >>Remove the Blower Housing (metal engine cover). The Wire that is Connected to the Coil/Ign Module from the Shut Off Switch needs to be Removed (unplugged) from the Coil/Ign Module.
>>Now Check for Spark at the Plug.
>>If Spark, then the Shut Off Switch or the Wire is Bad.
>>If Still No Spark, then the Coil/Ign Module is Bad. If there IS Spark, then, If there are Safety Switches on this Unit and the Coil is Good; you Need to Check the Safety Switches for Being Bad and Check the Oil Guard Switch also.**
>>The Following is an Instruction File for the Safety Switch System. Any Input is Appreciated.
>>The Color Code of the Wires May be Different than those I Use as a Reference in the Instruction File.
>>**PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed.
>>**Now. On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch (Clutch/Brake) Jumper from Same Color Wire (Example: White to White) First and then Check for Fire, Now Include the Black to Black Wires if No Fire. Check the Clutch/Brake and the Blade/PTO Safety Switches First. Then Check the Oil Guard Switch (if Applicable). Check the Seat Safety Last. Usually the Seat Safety is Not in the System for Starting the Engine. Just to Ensure Someone is in the Seat when Engaging the Transaxle and/or Blades. Use a Paper Clip or a Short Wire to Make a Jumper.**
>>Use a Multimeter and Check the Continuity of the Switch. The Meter should Show when the Contacts are Closed and Open. The Meter will Swing All the Way Over when the Switch Contacts are Closed and Swing Back to the Rest Point when the Switch Contacts are Open.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Good Luck
Respectfully
jbridger (John)
May 11, 2009 | Garden
Briggs engine/ genreator
change spark plug and add small amount of starting fluid to breather pull with all settings in proper place if it is going to start it will or you have other problems
Nov 04, 2008 | Coleman Propane Forced Air Heater...
Garden Logo
120 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
