Question about Canon PIXMA MP130 All-In-One InkJet Printer
Canon printer error
My printer had a paper jam so i took the paper out and restarted the machine. It now shows an error "please wait" and it doe not do anything. Any ideas. Helen Wrexham
  • 758 Answers
I would recommend that you uninstall the device and reinstall it back..That should solve the problems you are having..
Please rate accordingly
Thank YOu
Computerrep
Posted on Mar 26, 2008
  • Jean Sintulaire Mar 28, 2008
    When you uninstall the device it should clear all the job that you have for the printer...Once all the job is clear you should try to reinstall the printer and that should solve your problems..
    Thank you
    Computerrep
Canon 3010 problem jam indecate
If the error indicator light is lit, then the Canon printer is jammed. To fix a paper jam you must remove the paper tray, disconnect the AC power adapter, wait 5 seconds, then plug the printer back in. If the jammed paper does not automatically eject, carefully remove the paper manually. To help prevent further jamming, fan the paper in the paper tray to prevent the paper sticking together.
Great people delivering a superior customer experience. Canon Printer offers a complete line of printers, scanners, all-in-one office machines and paper jammed problem. Facing the problem with Bother printer, Scanners, Call our technical expert and get quick help. Dial Canon Printer tech Support Phone Number (18777788969) and fix your problem. For more information visit us: http://printertechnicalhelp.com/Canon-printer-technicalhelp.html
Sep 02, 2016 | Canon Office Equipment & Supplies
Paper jam, followed instructions, paper tear as i removed from front of machine. paper not visible front or back. still shows paper jam. how fix please. tear approx in mid sheet?
Remove toner cartridge. You will find paper piece in there, I believe. Get ALL pieces out, put in fresh paper, restart. That usually does it.
Jun 12, 2015 | Canon imageCLASS MF4150 All-In-One Laser...
Paper jam error
could be a stuck, failed, or out of place sensor. recheck all sensors in paper path(s) carefully
Sep 19, 2013 | Kyocera Office Equipment & Supplies
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam error code with no paper jamb
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ptttq17
Jun 16, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper has jammed showing error code 0000064 and inform to restart
canon3000 err code 64 restrt machine 10 to20 copy after code please help me
Dec 16, 2008 | Canon MF8180C Color Laser MFC Printer
Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Mar 12, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Canon PIXMA MP130 All-In-One InkJet Printer Logo
124 people viewed this question
old marine
old marine
