Question about Toshiba Satellite A85-S107 Notebook
Cd/dvd stopped working checked my computer and the cd/dvd drive is not there
  • abdul vahid lakkal May 11, 2010
    can u see that in device manager? Right click on my computer and go to manage, Then click on device manager. On right side you will see CD/DVD drive. can u see ur drive their? is there any yellow mark dr?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
You may uninstall the Optical drive in the device manager and the remove upper and lower filters in the system registry.
Posted on Apr 25, 2010
D drive will not load some disc programs in to the computer
If you are saying D drive is your CD/VDVD drive? If you are installing from CD/DVD drive then suddenly stop the installation/setup/loading you must check your disc drive. To check your cd/dvd drive insert a cd or dvd cleaner and start cleaning most of the cleaner has a movie inside of the disc and run for about 10 minutes. Then try again installing/setup/loading the program to your computer. If its still the same, replace your CD/DVD drive with a new cd/dvd drive because your cd/dvd drive is need to be replace. Have a nice day
Jan 26, 2011 | Computers & Internet
The cd/dvd writing drive has stopped working on our HP computer with Vista windows. we checked the hardware on control panel and it said the drive was working. Help.
Well, that only means that the device is getting electrical power, and the "data" cable between the device and the motherboard is connected, and that Windows has loaded the correct device-driver for the device.
It does NOT mean that the LASER inside the drive is working correctly -- it's possible for the LASER to have stopped working.
Spend $40, and buy a new CD/DVD reader/writer, to replace the "dead" unit. This is cheaper than paying a technician $25 to $50 to try to trouble-shoot "hardware" problems inside the drive.
Oct 19, 2010 | HP Computers & Internet
I have a HP External USB CD/DVD R/RW drive. Stopped working.
First, try a new USB cable. Two, try a different USB port (if using a hub, directly connect to the computer). Three, check if there are any updated drivers or firmware for the drive.
(also make sure that the external drive is self-powered that the cord is undamaged and the power isn't surging or going into a brown-out. If it is one of the new bus-powered DVD drives, make sure that the computer has a good power source (not on battery for a laptop).)
Feb 27, 2010 | HP 8x External Double-Layer USB 2.0 DVD...
Cd rom dvd burner stopped working
uninstall mcafee then try the fix at this link... http://www.siliconguide.com/qa/forum/messages/71.shtml if it works then reinstall mcafee and see if all is well... if it repeats then mcafee is the problem...
Jan 03, 2010 | Computers & Internet
Dvd RW Burner stopped working after only having it for a year
Check whether the CD/DVD drive has been detected/recognised in device manager. Also check the device status in device manager. Try to install the latest drivers for CD/DVD drive will solve your problem.
Dec 15, 2009 | Gateway (1531356) DVD±RW Burner
Dell Inspiron 8600 Cd RW/DVD has stopped working
this problem occurs when the lens of the drive gets weak or broken
you can either buy a new drive or just get the lens of the old drive replaced
yes its possible to replace a cd rw/ dvd drive with a dvd rw drive
Sep 29, 2009 | Dell Inspiron 8600 Notebook
Cd drive led light flashes orange four to five times then stops
Given all the things that you ahev done, clean the drive with a CD/DVD cleaner and / or air duster. Check the device is enabled in Device Manager and it shows no errors. If it does then read the explanation. If not and it looks OK you will most likely need a new drive!
Sep 09, 2009 | Computers & Internet
Dell XPS 1300 Cd rom problem
This is a CD drive mechanical problem. All CD/DVD drives have built in error checking for mechanical failures. When you insert the CD/DVD, it tries to grab and seat the disc, then attempts to spin it up and then read it. If the grab and seat function fails for any reason, the drive will eject the tray so you can try again. You should contact Dell support and get the drive replaced. Has the drive ever worked? or did it just stop working one day?
Nov 02, 2008 | Dell Inspiron 9100 XPS Latitude D400...
Acer aspire 5315 laptop cd/dvd drive stop working like there was none
This will be one of two things, 1- a driver glitch, you will need to uninstall the drivers for the cd/dvd drive from the device manager, then reboot. The machine will find the drive and reinstall the drivers automatically. This will fix it if it's a driver problem. You can also try any updated driver utilities, or patches for the drive from Acer's support site. 2- the cd/dvd drive has failed and needs replaced. These are basically plug and play devices, they either work or they don't, so a majority of the time when the machine stops recognizing the drive, it's because the drive has malfunctioned. Unfortunately, these drives are considered sealed units and replacement parts aren't available.
Aug 30, 2008 | Acer Aspire 5315 Notebook
Dvd/cd drive not working
my dvd cd1.gif drive in my laptop1.gif isnt working at all i can hear it start when i insert a movie or disc but then it stops and when i check for the driver in my
Feb 25, 2008 | Computers & Internet
Toshiba Satellite A85-S107 Notebook Logo
115 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
