Windows xp problem
I've borrowed a Microtek ScanMaker 4 machine from a friend. I installed the hardware and software on my laptop which runs on Windows XP. HOwever, whenever I try to run the program, I get an error message: "This beta version is out of day" which I think should read "This beta version is out of date." I have also received this message: Can't run 16-bit Windows program: insufficient memory to run this application. Quite one or more windows applications and then try again."
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 156 Answers
Hi
It seems you installed an outdated (16bit Program) for the ScanMaker 4. 16Bit applications/programs and generally DOS based (Windows 3.x and 95) and will not run properly from Windows XP.
First, check http://support.microtek.com/product_dtl_2.phtml?prod_id=23 and download and install Drivers and Plugins for Windows XP.
You may need new 3rd Party Scanner/Image Applications that work in Windows XP. However, if you still want to use the 16Bit application then you will need to run the program in 16Bit Compatibility Mode. To do this, right-click the program executable or shortcut, choose propertise from the drop-down menu, go to the Compatibility Tab and put a tick in "Run this program in compatibility mode for:" From the drop down menu, choose Windows 95 or 98 and apply.
Finally, check the the User's Guide or ReadMe file(s) (if you have it) for more info. Especially, check the recommended OS for the Applications.
I might be wrong, but i think ScanMaker 4 has a SCSI interface. If this is correct, then your laptop or port replica must have a SCSI port. NB: SCSI is not the same as Printer LPT Port.
Regards
Mike
Posted on Mar 23, 2008
SOURCE:
Microtek 3840 - Drivers for Windows 7
The scanner in question is not supported under Windows 7 as it is quite aged. I've seen reports of people getting drivers for the same scanner under windows XP and running them in compatibility mode, but these are hackish at best and may or may not work.
As it stands, there is no supported driver for the Microtek 3840 under Windows 7.
May 03, 2011 | Microtek scanmaker 3840
My scanmaker 3600 doesn't work on windows 7, It worked alright on xp. do you know what driver i can use to work on windows 7?
There's no driver for Windows 7, But you still can install it so it can work by install the driver for Windows XP in "Compability Mode". here's the steps :
1. Place the applications installation file on the Desktop.
2. Right Click the applications installation file and select Properties/Compatibility Tab. Select "Windows XP"
3. Click Apply/OK.
4. Right Click the file and select the Run As Administrator option to install.
cheers
Feb 08, 2011 | Microtek ScanMaker 3600 Flatbed Scanner
I am having windows 7 installed in my PC.
The scanner is not supported by Microtek for Win7. But in Windows 7 Pro and Ultimate. Download and install the virtual XP mode (two programs are needed), then use the XP drivers and install the scanner to the "XP computer". You may need to store files on external media to transfer them between the "two" computers.
The XP drivers are here:
http://support.microtek.com/product_dtl_2.phtml?prod_id=32
I hope this helps.
Apr 10, 2010 | Microtek scanmaker 3840
Microtek scanmaker 3800 windows 7 compatible
You can download: ScanWizard 5 version 6.63 Here: ftp://microtek:[email protected]/microtek/pcfiles/drv_sw5_v6_63_ad.exe
Extract to folder on desktop. 1. Plug in your Scanner 2. Go to Control Panel (Windows 7 - 64 and 32 bit) 3. Go to Device Manager 4. Go to Imaging devices (or Other devices) 5. Find what windows have installed Right Click 6. Update Driver Software.. 7. Click - Browse my computer for driver software 8. Click - Let me pick from a list of device drivers on my computer 9. Click - Have Disk 10. Browse to your desktop or position where you extracted 6.63, point to "....drv_sw5_v6_63_ad\Disk1\Vista\AMD64\..." Pick any of INF files I picked first 11. You will see 4800 Scanner and USB 2.0 Scanner, I picked first 4800 then USB 2.0 and both works.
I managed before to do it with simple install but well, it works .. ;)
Apr 02, 2010 | Microtek ScanMaker 3800 Flatbed Scanner
I need driver for microtek scanmaker 3840
you can download it from
http://www.driverskit.com/freedownload/Scanner/Microtek/ScanMaker_3840_3830_3800_ScanWizard_5_5_93/14515.html
Feb 26, 2010 | Microtek scanmaker 3840
I have a microtek scanner model #4900 which I gave to a good friend who has the new windows 7 operating system how do I get the driver files to enable it to work on her machine?
On the Microtek web site, I only see an XP driver. Your friend could try installing a generic TWAIN compliant scanner that is included in the Windows 7 OS or try to install the XP driver using the XP SP3 compatability mode (right click on the file, choose Properties and then the Compatability tab). Those drivers are at http://support.microtek.com/downloads/drv_specific.phtml?slct_os=8&prod=14&bymdlnme=1 .
A different method is available on Win7 Pro or Ultimate. Download and install the XP mode to create a virtual computer running Windows XP. Install the scanner to this "second" computer. Your friend will probably need to save the files to external media to transfer them between the two "computers".
I hope this helps.
Feb 01, 2010 | Microtek ScanMaker 4900 Flatbed Scanner
I lost my Microtek Scanmaker CD
you can download the scanmaker from any of the following links.....
http://wareseeker.com/free-microtek-scanmaker/
http://www.zdnetasia.com/downloads/pc/swinfo/0,39043052,50002424r-39468901s,00.htm
currently the microtek website server is down..... i dunno for how long...... once its back on track.... u ll be able to download the scanmaker from the below link as well
http://support.microtek.com/static/sm3600.html
thank you
have a nice day
Jul 09, 2009 | Office Equipment & Supplies
Installer or microteck scanmaker 3840
  • I need
    Driver
Microtek ScanMaker 3840 Scanner ScanWizard 5 v6.310 Windows 98/ME/2000/XP Multilanguage
May 20, 2008 | Microtek scanmaker 3840
Microtek Scanner installation issue
If running XP SP2, then try clicking Start > right click My Computer > properties > Hardware tab > Device Manager button > expand Imaging devices > right click on your Microtek ScanMaker > uninstall > Re boot > and let XP pick up the device and let the found hardware wizard configure it.
I have seen plenty of hardware that when following the devices manufacturer's instructions for install, such problems as you're having occur and XP SP2 usually will cure it, though you may still need the device manufacturer's CD (for the driver) in your optical drive.
This link: http://support.microtek.com/downloads/bymodelname.phtml?viewtype=2&srch_in=ScanMaker+5950&frmsearch.x=10&frmsearch.y=11&frmsearch=Search&frm_rqst=2&axn=1 will allow you to select between the 5950 and 5950 Pro then on the next page you will be able to download the latest XP driver for your Scanmaker among drivers for other Operating Systems also.
I hope this helps, and Good luck.
Mar 21, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
How do I find instructions on How to download and install ScanWizard 5 software to my computer?
I found it here.. and there .. http://www.opendrivers.com/driver/233289/microtek-scanmaker-series-scanwizard-5-v6.11-windows-98-me-2000-xp-free-download.html http://kmkm.dk/scanner/MicroTek/33289/Microtek-ScanMaker-Series-ScanWizard-5-v6.11-Windows-98-ME-2000-XP.html
Dec 26, 2006 | Microtek ScanMaker V6UPL Flatbed Scanner
Open Questions:
SBCglobal MAil TecH +-*{1-855*536*5666}#[email protected] SuPPoRt TECH This SbCgLoBaL MaiL USA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the SbCgLoBaL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact SbCgLoBaL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiL USA Calling SbCgLoBaL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiL USA's phone numbers against each other. Contacting SbCgLoBaL MaiL USA in General While I********** is SbCgLoBaL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Oct 19, 2019 | Best Computers & Internet
Computers & Internet Logo
77 people viewed this question
Ekse
Alun Cox
