Monitor i have laptop,its dell,,then my son have his own pc..then after a year the pc got a lot of problems..and one day we supposed to bring it to the computer shop but he accidebtally pulled out the plug from cpu..i dont know if the monitor have the problem or the cpu..i want to test the monitor to my laptop..how can i do that..im worried i will mess up my laptop.
  • 43 Answers
Take the vga cable from the monitor that plugs into the pc then plug this into the vga output on the laptop press Fn F8 to enable the vga output or presentation mode on the laptop this should now give you an image on the monitor
Posted on Mar 23, 2008
    Brigadier General:
  • 6,966 Answers
Connecting an external monitor will not mess up the laptop.
Most laptops have a standard 15 pin VGA external monitor connector. You need to connect the cable from the monitor to the laptop. Booth the Dell and power up the monitor. Soon as the laptop has gone through its routine of booting, press Fn + F8 or F4 (or whatever it is that needs to be pressed to activate the external monitor. It is normally an F key with the small monitor icon or the words CRT/LCD).
Pressing on the two (2) F keys would cycle on laptop display, laptop display + external, external only.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE:
I have Dell inspiron 1564 (windows 7 64 bit). The monitor goes blank with a screeching noise. I have run the PSA diagnostics but it showed no problem. The laptop runs normally otherwise but this problems...
I now have the same problem with the same Dell model (1564) for the second time in less than a year from purchase. The last time it happened I called the service technician who fixed it. That makes me wonder if this may be a common defect in this dell model, which requires a technician visit every 4 months. I advise you to apply to the company and ask for solution such as providing you a different model as a substitute for the defective one.
Sep 23, 2010 | Dell Inspiron i15648634OBK 1564 Laptop...
Monitor won't come back from "sleep" setting.
Yes it can be, try it on other PC first to narrow down the problem.
Most problems in the Dell are failed transistors, poor solder works, see pictures here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you find.
Apr 03, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
My monitor picture is very dim after my son
Reloading or updating the graphics drivers might help.
Feb 24, 2010 | Dell Inspiron 6000 Notebook
Auxilliary monitor on Dell Latitude D610 laptop goes black.
motherboard and graphics adapter may need replacement
Dec 22, 2009 | Dell Latitude D600 Notebook
Dell 22" monitor goes black
Your monitor probably has bad capacitors now. Bring it to a local electronic repair shop and have the monitor tested. They can easily replace any bad capacitors.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | Dell 22" SP2208WFP Widescreen Flat Panel...
Dell E520 17" monitor not powering on
your fuse in the monitor has burnt out cheers
Apr 11, 2009 | Dell Dimension E520 PC Desktop
Laptop monitor shutting off after after a few minutes
I have exactly the same problem though I have a toshiba laptop, after 3 years of intensive use i think the lcd is gone, cos it has nothing to do with os as it did the same even when entering setup. btw i used to let it 247 on like you did !
Jan 01, 2009 | Dell Latitude D600 Notebook
Monitor keeps going dark
It sounds like a LCD backlight problem. Bring it to an authorized repair shop.
Dec 02, 2008 | Dell Latitude D600 Notebook
Open Questions:
Computers & Internet Logo
505 people viewed this question
Ekse
Alun Cox
