Question about Alcatel One Touch FIRST 20 Cordless Phone
SOS call was activated. How Deactivate it? 2
Hi All. I don't know why my telephone write on dislpay " -SOS-" and everything I push, make a call to SOS number. How can I deactivate the SOS mode?
Still no solutions for this problem.
Someone asked me what kind of Handset i have. What mean?!
The problem i posted was referred to cordless phone One Touch FIRST 20, same as picture.
I don't know if is useful to know that in the battery box there is this code:
002B85C778
Atlinks
01/33
THANK YOU AGAIN!
Push the "R" button (last button on the left side) two times.
The the "sos" should be deleted.
I also uploaded the manual (only in french). The solution ist on page 10.
Posted on Jun 14, 2008
6ya staff
SOURCE:
In trying to learn this ph I activated some talking voice that I don,t know how to deactivate
If you have an android phone you can go into the google settings and change it from there. If it's Samsung you can deactivate it through your phone settings, than it's called SVoice.
Jan 16, 2016 | Cell Phones
Hi Chester. My name is Dave Dollarhide and I live in Costa Rica. I use my Mom's stateside credit card for things like this. I have a TH-50PX80X Panasonic HD Plasma Television. It was manufactured July...
Good day!!!
2 blinking red LED lights indicate faulty 15v SOS D-Board
This are the blinking error codes.
1 blink STB 5v SENSE time out A-Board
2 blinks 15v SOS D-Board
3 blinks 3.3v SOS A-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SU-Board / SD-Board / SC-Board
(SC Energy Recovery Circuit)
7 blinks Driver SOS 2 SU-Board / SD-Board / SC-Board
(SC Floating Voltage Area)
8 blinks Driver SOS 3 SS-Board / SS2-Board
(SS Energy Recovery Circuit)
9 blinks Communication Error between A-Board / D-Board
Panel-MPU and SYS-MPU
10 blinks Sub 5v SOS / Main 3.3v SOS A-Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB-Board
try to reconnect all connectors inside your TV,if the problem persisted try to check the power supply output 15vdc while the TV is on..Let me know what is the reading of 15v output..you need a multimeter tester (range in dc)..Also trace the board where the 15vdc connected and try to disconnect the supply to it then check again if the voltage stable for 15vdc..
Thank you for using fixya..
regards,
chester
Jan 15, 2012 | Panasonic TH-42PZ700U 42 in. Plasma...
How do I deactivate my Model SL 10? I'm giving it away, but don't want my account being used.
Give sirius a call. You'll need the account password to deactivate the radio. If it's lifetime activation, then just let it stay active. The new owner will not be able to access your account, or view any information about it.
Aug 31, 2011 | Sirius Stiletto 2 Satellite Radio Receiver
My Panasonic was working fine when I shut it off last night and I turned it on today and everything has a pink tinge to it now. It seems as though I lost a color. Can someone help me address this issue...
found this tonight:
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Dec 12, 2010 | Panasonic TH-42PX60U Television
Cal do you use the call forward feature on the AASTRA Telecom 9316 CW telephone to forward calls to another coworkers telephone number.
In order to set call forwarding on this telephone, must first have the feature CFV (Call Forward Variable) on in the line. This feature can be provided by the telephone service provider.
A typical feature code for this is *72 to activate CFV and *73 to deactivate.
You can program these features on the M9316 telephone by do the following:
CFV activate
1) Press the SAVE key.
2) Then select the key where you want to program the feature.
3) Then enter *72 (optional: plus the telephone number of where you want the call to forward to).
4) Press SAVE twice.
CFV deactivate
2) Then select another key where you want to program the feature.
3) Then enter *73
Be sure and label your buttons.
To use go off hook and press the key you just programmed.
Nov 01, 2010 | Aastra Telecom Aastra M9316 CW Single line...
I need to know if the vodavi 30 button part number 3015-71 needs a lifter for a headset or not
No. It's a programming item and a code or softkey.
The user connects the modular headset to the handset jack on
the telephone leaving the handset in place. The ON/OFF
button on the Digital Telephone is used to initiate and end calls
while using the headset.
To activate Headset Mode:
Dial [634] on the dial pad,
-or-
Press preprogrammed HEADSET MODE button. LED lights
steady.
To deactivate Headset Mode:
-or-
Press the preprogrammed HEADSET MODE button. LED
extinguishes.
While Headset mode is active, the ON/OFF button
activates the headset and disables speakerphone
and intercom call announce operation at your
station.
To install the headset, see the Installation Manual.
Station must be programmed in database
programming for headset operation before the
flexible button can be programmed.
Carl
Dec 23, 2009 | Vodavi 30-BUTTONVODAV XTS Telephone
SIM LOCK
hi i locked my sim card, i went onto 02 website and went onto PUK code. it asks you to put your phone number in then comes up with the code. i put the code in and it it worked
Jun 26, 2009 | Samsung SGH-D600 Cellular Phone
Voice mail recording for my new panasonic digital phone
For voice mail service subscribers
If you subscribe to a flat-rate service
package that includes Caller ID, call
waiting, voice mail, and unlimited
local/regional/long distance calls, please
note the following:
L To use the voice mail service provided
by your service provider/telephone
company rather than the unit's
answering system, turn off the
answering system (page 30).
L To use this unit's answering system
rather than the voice mail service
provided by your service provider/
telephone company, please contact
company to deactivate your voice mail
service.
If your service provider/telephone
company cannot do this:
- Set this unit's "Ring count"
setting so that this unit's answering
system answers calls before the
voice mail service of your service
provider/telephone company does.
It is necessary to check the number
of rings required to activate the
voice mail service provided by your
company before changing this
setting.
- Change the number of rings of the
voice mail service so that the
answering system can answer the
call first. To do so, contact your
company.
Jan 13, 2018 | Panasonic KX-TG4322B Twin Cordless Phone
I'm unreachable
Hi your call divert might be active on your phone menu so i would go it and deactivate it!
Nov 01, 2007 | Vtech 5.8GHz Analog Cordless Phone
Alcatel One Touch FIRST 20 Cordless Phone Logo
433 people viewed this question
Top Alcatel Lands Phones Experts
Ekse
Thomas Perkins
Thomas Perkins
ray gallant
ray gallant
Are you an Alcatel Lands Phone Expert? Answer questions, earn points and help others
