Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Chain for 24
Replacement chain for 24" bar
    President:
  • 2,220 Answers
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Select "Husqvarna; 455; 24"; All; All; All" and make your choice. A couple of things to consider, it only returns 3/8 pitch chain, 0.325 is also available. I ordered a 24" bar for my 359, a Carlton that only takes 81 drive links (82 is normal). I saved $20 by ordering that bar, I just have to be careful when ordering chain. I prefer Stihl chain to Oregon. My Husky is maintained by Stihl mechanics and gets Stihl 2-cycle oil; please do not tell her, she may never run for me again. LOL
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
Is there a oil ajustment for the bar oiler on a homelite chain saw
Homelite XL auto oiler - YouTube
? 2:44
https://www.youtube.com/watch?v=PnNTJ3xI_wo
Mar 24, 2012 - Uploaded by 343HFD
Refurbished, carb cleaned/adjusted, new filter, fixed automaticoiler. Anyone know the nut size for the bar ...
HOW TO REPAIR CHAINSAW OILER - YouTube
? 6:38
https://www.youtube.com/watch?v=kmUkieIP-vw
Jan 20, 2012 - Uploaded by gregthegardener
lf your chain saw isn't lubing the chain it can cause serious chain ... How to Replace the Bar & Chain Oil ...
Dec 03, 2015 | Homelite Garden
What Stihl chain should actually go with this bar?
Almost all of the Stihl bars that use 3/8" pitch chain on the 3003 mount bars use .050 gauge.
Where the bar says 3/8, it should also list the gauge and number of drive links. Sometimes these are worn off though. The 25" bar should take 84 drive links. (same as most 24" bars in other brands)
Jan 17, 2015 | Stihl Garden
How to replace chain on chain saw?
you have to loosen your bar nuts. then there is a chain tentioner screw either on the front of the saw or on the side between the bar nuts. turn this screw until the chain is drooping fron bottom of bar. remove the bar nuts, cover, then the bar and chain. make sure the the cutters on the new chain face forward when installed. tighten tensioner screw until chain is snug against bar then replace cover and bar nuts. readjust chain if it is loose. lift unit from handle forcing tip of bar up. this takes away any chance of play in the bar.tighten bar nuts when satisfied that chain is tight. when properly installed you should be able to pull chain upward fron bar and the drive links should not come over the rail guide.
Oct 02, 2014 | Garden
018c oiler
ck.the oiler drive gear behind the chain sproket
May 06, 2013 | Standard Oregon Chainsaw Chain For Stihl...
I have a Poulan 295. I needed to replace the chain. It is a 20" chain. There is bar oil in the resevoir. The chain will not stay on the bar (it seems loose even when fully tightened). I replaced...
If you replaced the bar AND the chain, you'll need to make sure the chain is the correct chain for the particular bar you've used. If you're only replacing the chain, you need to make sure the chain has the same # of drive links as your old chain (maybe one or two more, if you've had some removed because of chain stretch).
On that particular model, for a 20" chain, you could have a 78 OR 80 drive link chain (drive links being the part of the chain that rides in the groove of the bar). The correct drive link count is determined by the bar you've installed and should have been made clear by whoever you purchased the bar from. Some brands use an 80 drive link chain, but MOST use the 78 drive link chain.
If the bar you purchased uses the 78 drive link chain, but you have an 80 drive link chain, then no matter how far out you adjust the bar, you may not get the chain tight enough. PartsBuggy shows a listing of which bars use the 78 drive link chains here.
Aug 29, 2011 | Poulan Pro Chain Saw 46cc 20"
No chain oil comeing through
remove chain plate, clean all check oil drain is clean. check oil tank cap, is ther air inlet clean.
Dec 07, 2010 | Standard Oregon Chainsaw Chain For Stihl...
What is the longest bar i can go on my 455 rancher saw ?
Available power and the amount of oil may both be a limiting factors. Your oiler has a 3 position adjustment (as do most intermediate level Huskies) with 20" being the longest recommended. My 359 is virtually the same and I run a 24" Carlton bar on mine with no problem. If you opt for a longer bar let the saw determine cutting speed. Come on over, my bar and chain will fit your saw, try it before you buy it. If you have an acquaintance with a 24" small mount Husky bar that is probably a good idea. I would likely not recommend a 24" bar if regularly cutting Oak or a hard wood, I do a lot of Fir.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
May 13, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a stihl chainsaw model #311y and I need to tighten the chain .Can you help me?
loosen bar nuts, with gloved hand push up on bar, and turn adjuster screw clockwise. on stihls it's either beside bar facing forward or between bar nuts.
Feb 05, 2010 | Standard Oregon Chainsaw Chain For Stihl...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
89 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
