Question about Video Cameras
Eject mechanisam will no work
Eject mechanisam will not work . Everything else seems to work but this ..it flashes C:32:11 on the screen. This happened once before and we took the battery off while the camera was powered on then we put the battery back on and the eject system worked again. This time it will not work... any ideas as to what it might be...It worked for about 3 weeks and it is not working any more...please help if you can..much appreciated.
    Guru:
  • 513 Answers
This indicates a problem with the part called the capstan motor in this Sony camcorder. Either the tape will not takeup or the tape spills out when the drive runs. You need a technician to remove the tape if you want it saved.
Posted on Apr 24, 2010
Tip
Panasonic SA AK 67 Sterio system need spare
I have one panasonic SA AK 67 sterio system five disk changer
one plastic parts brocken inthe mechanisam area i wold like replace the mechanisam with lence what is the part number i could not find it where i can purchase new mechanisam. please help me
on Jun 30, 2008 | Panasonic SC-AK24 CD Shelf System
Hi my sony CCD-TRV57E keeps ejecting the tape, and
My SONY CCD-TRV57E isn't recording or any function.seem to be working. Bty ok. In view finder I'm getting "SP C:31:22" also a symbol like and inverted coathanger with a line thru it and a + sign on top.
May 15, 2010 | Canon ZR80 Mini DV Digital Camcorder
I am a electronic tech and I had a DRCTRV950 come into my shop and I am trying to help a friend out getting this camcorder running. The problem I am having is everything seems to work right except when you...
This can occur when the heads do not spin up fast enough or the loading does not complete. Check for slipping of the loading belt. There is more load placed on the loading motor and mechanism in total when the tape is actually there. The flashing Eject indicates that the load did not complete.
Hope this helps a bit.
Dan
Oct 15, 2009 | Sony Handycam DCR-TRV950 Mini DV Digital...
Brushes won't turn
the mechanisam that makes the brushes spin are broken. take it into a shop dont fool with a roomba
Sep 11, 2009 | iRobot Roomba 560 Robotic Vacuum
KW-AVX710 Screen stays black (off) untill I hit the open button
So I decided to verify all the connections after I got frustrated with it. Everything was correct except one wire that was on the new harness I got that for my car that was labeled "12V fused" (supposedly the key on power source). I tested it with my volt meter and it did not have power at any time, even with the key on. The constant power source wire was hooked up so that's why I was able to open the face and eject CD's and DVD's but not do anything else (like when your ignition is off). So I ran a new wire from my fuse panel and everything works now. Just like my Thermodynamcis professor says "nullius in verba" (take no one's word for it), just because the wire was labeled doesn't mean it's right! Hope this helps.....
May 25, 2009 | JVC KW-AVX710 Car Video Player
Tape will not eject
I had the same problem and I switched to smaller tapes. I had been using the 120 minute tapes. It seemed like the tape would lock up after a short while with the larger tapes.
Apr 05, 2009 | Sony Handycam CCD-TRV21 Camcorder
Jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Nov 07, 2008 | JVC KD-LX111 CD Player
Cd won't eject
sounds like the c.d. has a paper label on it, yes? my stereo won't eject c.d.'s with paper labels,....reach in there with a pair of thin needle nose plyers and yank it out,.....good luck, cracklin joe,......
Jan 19, 2008 | Alpine CDE-7856 CD Player
Cannot play or eject disc
Loading gear jam or broken loading motor belt. Disasemble unit to remove disc and check operation of motor and gear assembly. Repost the results so we can better help.
Jun 09, 2007 | Sony DAV-FR10W System
Video Cameras Logo
154 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
