Question about Samsung LN26A330J LCD TV
Monitor off but power light on after power shut off
  • 80 Answers
IF IT IS THE SAME MODEL I AM THINKING OF,YOU CAN GO IN TO YOUR MENU AND IT WILL HAVE 3 DIFFERENT SETTINGS.{1.OFF,2.LIGHT ON WHEN ON STANDBY,OR LIGHT ON WHEN TV IS ON.I HAVE MINE OFF.
Posted on Apr 24, 2010
How to fi a phillips 20fp shuts off in 2 scs.
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 29, 2014 | Philips Phillips 20" Color Monitors Model...
Monitor light up then shut down itself
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 11, 2014 | Sony SDM HS93 19" LCD Monitor
1707fpt dell flashes video and green power light
i will give you some tips
1- If the power light goes from green to orange) this is almost always an issue with the computer and not the monitor
2- If the monitor power light turns off, then it is almost definitely a problem with the monitor.
there are some reasons your monitor turning on and off
01-One reason the monitor could shut off is because it is overheating.
02-If the power cord is loose and is not securely connected to the back of the monitor it will cause the monitor to turn off.
03-If the monitor is staying on, but you loose the video signal, it's very likely an issue with the video card or motherboard in the computer. This could also be an issue with the computer or video card overheating or a defect with the video card.
04-Another reason the monitor could shut off is because of a malfunction in the circuitry. There could be a short in the wiring or some other failure in the circuitry, causing the picture to go black or causing the monitor to shut off completely
05 another reason the monitor on and off is because your monitor power supply chipset is damage
hope that it will help you
Feb 15, 2014 | Dell Computers & Internet
Have signal, but no light, just one second screen can see and shut off.
Please clarify by shut off you mean power light turn off or just screen gone blank but power light remain on!
Mostly inverter(power supply) needs attention in such cases.
Feb 07, 2011 | Dell E198FP 19" LCD Monitor
Monitor powers on,light on front is green then shuts off
ur moniter crt <picture tube > is weaki. solution is costly then purchage a tft
Mar 24, 2010 | Computers & Internet
My monitor power light keeps flashing. It won't
usually this is a bad power supply. most electronic shops can repair them
Jan 10, 2010 | Acer AL1916W 19" LCD Monitor
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
Popping sound, black screen
Has it bitten the dust? Probably.
May 18, 2017 | Proview PL926WBi 19" LCD Monitor
Samsung LN26A330J LCD TV Logo
78 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
