Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
Jenn Air CCE 3401B dual Infinite Switch Kit wiring doesn't match with original - how do I match them up?
3 Suggested Answers
reg501
  • 413 Answers
SOURCE: stove top dual infinite switch
If the new switch is a substitute, should have come with instructions.
If no instructions, I would suggest matching the markings on the switch next to each terminal.eg, match terminal marking on old switch as L1 to marking on new switch as L1. The markings are industry standard and should match from old switch to new switch.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 05, 2008
  • 2468 Answers
SOURCE: Wire from circuit breaker is
depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire
Posted on Apr 29, 2010
I have a Jenn-Air radiant cooktop, two of the burners run on high no matter where the control knob is set?
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Oct 03, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
One burner no longer adjusts temp when moved from 1 to High
Oct 02, 2010 | Jenn-Air JED8430 Electric Cooktop
I need instructions for wiring in replacing a dual burner switch on a CVE3400B cooktop. The replacement switch is different from the original. Do you have a diagram for the new switch that shows how to...
We followed the instructions that came with the switch that addressed a "compound wiring" configuration. We also used the black jumper wire as shown in the instructions.
We got to this solution in a trial by error manner though, because the three of us working the problem were convinced the stovetop was wired in a "piggyback configuration" and tried that road first. It would have been helpful if the instructions had included an explanation of the switch manufacturer's interpretation of "compound" and "piggyback" configuration.
Jan 09, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Need to replace the infinite swithc
I've got the switch but i had to take off the bad one and take it to the parts store to get the replacement. Stupid me forgot to snap a photo of how the wires plug back in! Did you get your fixed and which wires are L1/L2 and which are H1/H2?
Jul 06, 2009 | Jenn-Air 47 in. Pro-Style CCGP2820P Gas...
Three of my Jenn Air burners (electric) only work on High - OLD
Hello
Welcome to Fixya
My name is Huum,
you can find the schematics, diagrams and parts here at this site . just enter the complete model number that is written on the stove sticker and access the info
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080204x00001a
Please remember to leave a rating before you leave
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Fixing Jenn-Air Custom Control
Sure, I meant to get a copy of the schematic last night so that I could send it to you with the changes. I'll get it tonight and send it to you along with the info I have now. The only thing that will be different is that you won't have independent controls of the dual element burner. For me that was fine cause my wife and I never use just the smaller burner but rather always both. The part #1009577 from repair clinic.com is an infinite switch which is already being used in the cook top for the largest burner or if not (cause I actually didn't look) for sure it is used in the JEC9536, just the wider model. This part is rated from 8.9 - 11.0 amps or 2,640 watts, when you hook the two burners together I believe it adds up to 3,000 watts so the infinite switch (the biggest I could locate) is slightly under sized. However, I felt most things especially electrical, are over engineered for safety any ways. When you remove the circuit board you will have to drill out the two slots where the two mounting screws will secure the new switch, or you can do what I did and stick a screw driver in the slots and stretch them slightly (very easy to do). You'll need to find two screws that fit the new switch for mounting ( not too long, if your not sure take one off one of the other infinite switches and match it up). I'll have to get back with you on the wiring, it is rather simple though, most of the connections are the same as the other infinite switches. The grainger.com part number 2FBT6 is just a snap action thermal switch that will replace the thermal sensor that went to the circuit board to light up the hot surface indicator. I tried to use the existing sensor but the hot surface indicator lamp stays lit, so I figured that the sensor was probably a 0-10volt or 4-20mAmp switch that the circuit board monitored and turned on the hot surface indicator accordingly. That is a simple hook up also, however, I have not installed that yet cause I did not find out about the thermal sensor not working for the hot surface indicator until after I put in the infinite switch. Tonight I will install it and let you know what wires go where along with a marked up schematic, maybe even photos if you would like.
Sep 11, 2008 | Jenn-Air 35 in. JEC9536ADS Electric...
Stove top dual infinite switch
Regards,
reg501
Jun 24, 2008 | Cooktops
Jenn-air CVGX2423
Is it clicking? No...bad switch. Yes...check ignitor gap on that burner. The gap or the wiring is bad if it doesn't work.
Jun 08, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Inop burner on new jenn-air JEC9530 elec flat cooktop
I'm having the same problem with my jec9530. The dual burner just quit working one day. I called jennair and they sent me a replacement "custom control" for free. 6 months later it quit again. I am now considering attempting to put an infinite switch (dual), part #PS786568 in its place. It is not electronic, and it looks like it is used for the jec9536 middle back dual burner. It is only $35, even if it doesn't work like the electronic one I don't care. My wife usually only uses both burners at the same time anyway.
Sep 04, 2007 | Cooktops
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
155 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
