Question about Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner
Change Region I can´t see dvd region 4 because it's stock in region 1. I try to change it but ther's a message that says I used all my opportunites. Can I do something about it, can I have a program for multiregion. Thanks for your help
No, once you used all the opportunities to change, then you have to replace the Drive itself.
Posted on Aug 05, 2008
SOURCE:
How do I change region code on Pyle pd1000a? Need region 1 and all I get is not formatted to play in this region error message. Don't know what region this thing is programmed to but need to change. Pyle...
When a DVD disc is created, it is encoded with a "Region number." The disc will only play on DVD players with the same Region number - for instance, a Region 3 disc won't play on a Region 1 player.
Region 1: U.S. and U.S. Territories, Canada
Region 2: Japan, Western Europe, Middle East, South Africa
Region 3: South Korea, Hong Kong, Taiwan, Southeast and East Asia Region 4: New Zealand, Australia, Pacific Islands, Mexico, Central/
South America
Region 5: Russia and the former Soviet Union, Africa, Indian
subcontinent, North Korea Region 6: China
The only way to get around the region codes, is to rip a DVD to your computer and remove the region code. Then burn the DVD to a DVD R. There are programs around on the net, but I'm not sure it is legal in all countries.
Google for the programs.
A DVD player sometimes allows you to change the region code once. But it not even would allow you to switch back after you changed it once.
Jul 23, 2014 | Pyle Audio Players & Recorders
I am from New Zealand . I recently played a DVD disc from the U.S. which is region 1. I had to change the region setting on the bluray drive to play it. I tried to play a region 4 disc on it, and after...
Ask the people you purchased the bluray drive to give you instruction on how to reset (usually is about 5 times and then it gets stuck in the last region used, the Blu-ray region is set in the playback software, not the drive.). You may also want to try re-install the software, which resets it. Good luck.
Mar 05, 2011 | Computers & Internet
Laptop dvd player stuck on region 1 need 4 for
Try changing the region by right clicking your DVD drive in explorer and select properties, go to hardware tab, select your DVD brand and type, click properties, go to DVD region, and change the region.. Just remember, any DVD only allowed to change the region for about 4 times, after that, you can't change the region anymore..
Dec 23, 2009 | Toshiba Satellite A135-S2276 Notebook
DVD's wont play - says wrong region but they are compatible
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
Nov 23, 2009 | HP Pavilion dv9000z Notebook
I want to change the region code on my sony slv d281p
I dont know is this work in your brand, but we dont lost nothign whit try it:
1. Open the tray
2. press the following sequence using the number keys: 98790 (this is equivalent to the code 9879 with the zero at the end representing all regions)
3. Press Close Tray - there should be a sign on the TV screen saying something like 'Region set to 0'
4. Turn off the DVD player for 5 seconds
5. Turn on the DVD player.
Hope helped.
Oct 29, 2009 | Sony SLV-D281P
Hi, I need to unlock the dvd player Sony DVP-SR200P to play all regions.thanks
THere was some problem, with the chat...I was not gettin gyour messages
1.Switch on the player
2; Pop open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
7. Pop in a DVD and enjoy!
Sep 19, 2009 | Sony DVP-SR200P DVD Player
I CANT CHANGE THE REGION ON MY DVD, although I have 1 change left
you can flash the drive with region free firmware (best option if you know what youre doing)
you can reinstall os giving you extra tries.
or you can use a program called any dvd(free)which enable you to watch any region (safe)
flash is best if youre not sure or cant find software let me know and give your dvd details(firmware)
eg freecom dvdrw 523252
Jan 26, 2009 | Dell Inspiron 1300 Notebook
Unlock dvd rom to region free
Download software like region free dvd player then check
Nov 21, 2008 | Computers & Internet
Changing the region code
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
Aug 15, 2008 | Samsung DVD-R155
Error message when reading DVD
Try changing the region setting to region free.
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys,
simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
Good Luck. Let me know if it works
Jan 09, 2008 | JVC XV-S300 DVD Player
Open Questions:
See all Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner Questions
Toshiba SD R2312 CD-RW/DVD-ROM (Combo) Burner Logo
49 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
