Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
What's the recommended oil for this engine. can't find my manual
  • 2,841 Answers
You can use 10w30 weight year round. I highly recommend you use synthetic oil in this air cooled engine and change the oil/filter every 50 hours. I think you will find it holds 1.5 quarts with filter change. Do not overfill.
Posted on Apr 24, 2010
Testimonial: "Thanks. This helps a lot."
What oil is recomended for the honda ES4500, the owners manual does not say what to use,,
Per the manual page 6 SAE 10w-40 is recommended for general,
all-temperature use
Mar 17, 2018 | Honda Motorcycles
Someone recommended that I use 20-50. Oil on my 1999 Honda .accord with 133, 000 on it
I would NOT recommend using 20w-50 oil in your Accord at all. The manufacturers state a certain multi-viscosity oil to use in all their vehicles and you should stay with that. Many cars use a 5w-30,5w-20 oil and some should use a 0w-20 oil. Modern engines have tighter tolerances on the internal moving parts of the engine than engines from the 1970's and 1980's. A 20w-50 oil is way too high a viscosity(thickness) to use in todays engines. The first number, say 5w, is the cold start viscosity of the oil so the engine can start easier and have lubrication in cold(winter) temperatures. The second number, say 30, is the viscosity of the oil when the engine warms up to normal operating temperature. The oils have viscosity modifiers in them so as the engine and oil temperatures change(cold to hot, hot to cold), the engine has the lubrication protection it needs to operate correctly. I recommend using a synthetic blend oil that is found in many of todays engines right from the factory and stay with the viscosity that the manufacturer recommends in the owners manual. If you do not have an owners manual, call the dealer service department and ask them.
Feb 20, 2015 | 1999 Honda Accord
Looking for manual for Poulan countervibe 3700 What is the oil to fuel ratio?
IAW with specifications here (40:1 - 1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil)
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/00c68f320e8e63ba88256bf80016a58c?OpenDocument
The OM for a 3700 is not loaded. Please try here:
http://www.poulanpro.com/node4033.aspx
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 1gal premium/4oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Feb 15, 2010 | Poulan Garden
I need to know a fuel oil ratio.
Regardless of what the manual says once adjusted your saw will perform better with this mix.
Do you need bar oil? Available at any Hardware or Home Center.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
Lou
Dec 27, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What is the gas ratio for a 14 inch blade
the blade length isnt important, what is the cc of the engine different size engines take different mixes.
Dec 26, 2009 | Homelite Garden
2003 suburban 2500 8.1 liter oil calls for 5w 30 Ive been told to use heavier oil as it gets older? What do you recomend?
Follow the recommendations in the owner's manual or service manual - usually 10w-40 for summer and 5w-30 for winter roughly. Oil that is too viscous makes the engine work harder than necessary. If you want to provide extra "cushion" for tired engine parts, add a bottle of STP oil treatment. This stuff is the best thing for an older engine, as it takes up some of the gap between slightly sloppy tolerances, and it makes the oil adhere to engine parts much better than oil alone. Highly recommended, and doesn't change the oil viscosity characteristics significantly (even though it looks like it would!).
Nov 25, 2009 | 2003 Chevrolet Suburban 2500
What is the fuel/oil mix ration for a 345 Husqvarna Chainsaw?
Page 19 of a 2007 Operator's Manual 50:1
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
Lou
Nov 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Craftsman 16'' 36cc's oil to fuel mixture, and bar oil requirements
Your Craftsman is probably a Poulan, for the past few years Poulan has recommended a 40:1 ratio 1 gal premium/3.2 oz quality 2-cycle engine oil. I'd thin down even a little more 50:1 (1 gal premium/2.6 oz quality 2-cycle engine
Fuel/Oil Mixture
For the bar every home center and hardware sells bar oil. It is 30 weight non-detergent oil with a few additives to help it adhere where lubrication is needed. HTH
Lou
Nov 16, 2009 | Garden
Pb1000fuel to oil mix ratio for echo
New Echo manuals say "50:1 for all engines regardless of what is printed in manual."
Fuel/Oil Mixture
Lou
Nov 09, 2009 | Echo Garden
What is the gas/oil mix for a mccullach chain saw?
to be safe without operator's manual or signage on the machine;
32:1
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 08, 2009 | McCulloch Garden
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
511 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Daryl Gleaton
obsteiner
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
