Question about Boating
Suzuki 50 HP outboard motor keep overheating. change impellor but it was in good shap removed the thermostat and had a large amount of water comming out of it. But when I plug the water return hose the *** stream stops the water drains from the head as I can see it once I removed the thermostate and 2 minutes later the overheat alarm sounds. Sometimes it self fixes after a while sometime it does not...The thermostate checks fine new impellor flushed the system and there seems to be no blockage. Same result in the water and with the earmuffs. It just seems like something is rerouting the water but where?
    Top Expert:
  • 44,232 Answers
Sounds like a blown head gasket to me
Posted on Apr 25, 2010
  • kedeaux Oct 22, 2010
    having same trouble on 115hp four stroke...changed water pump, flushed it, replaced themostat...got is pissing good now but still running hot....did you have any luck on fixin yours....please if you know what it was, I'm about to go crazy tryin to figure out, would you post me back
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Where are the serial numbers located on a 1985 Suzuki 115 hp outboard motor??? have looked everywhere
The serial numbers are on the transom bracket where your engine bolts to the back of your boat !
If no numbers then remove the gearbox and take the impellor and its housing to a dealer and they should be able to match them !
Feb 23, 2015 | Suzuki Boating
I ran my Suzuki 85dt with the baffles on and it over heated. now it won't run. Any suggestions on how to fix this ?
what do you mean by not having the baffles on ??
If you ran the engine without water feed to the waterpump then you will have melted the impellor and overheated the pistons and might have damaged the bores etc !?
Check the compressions and they need to be no less than 100psi each, the impellor and housing and the pipe up to the engine must be checked ! You can run the engine without the gearbox fitted by connecting the water hose to the pipe once all checked ! Any more info u need contact me !
Jan 11, 2015 | Suzuki Impeller, Outboards, 85 HP
What indicates bad reed valves?
check the impellor ! which outboard motor do you have ?
Sep 14, 2014 | Seloc Mercury Outboard Engine Repair...
Change the water pump on a 90 hp Johnson outboard
tilt engine and remove all bolts that hold gearbox to leg , put box in vice and remove impellor house and remove impellor , check all holes and seals below housing for damage etc , if impellor has broken up then check water down pipe is clear , you can run engine with box off and put hose to down pipe and turn water on and run engine for 20min and see if engine cools b4 you fit box so you know no blockages etc ! as you fit impellor rotate clockwise as you push down on housing , bolt up and fit box and as you do turn flywheel to engauge driveshaft ! Bobs your uncle ....
Dec 11, 2013 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to Change the impeller on Suzuki 140 outboard motor
Suzukis are normally a mission to work on especially if it is a two stroke,so I suggest you get a workshop manual.all gearbox bolts must be undone,the gear linkage is under the bottom carb,this is the tricky part,you have to loosen a nut at bottom of gear arm where gearcable fits,then push in with screw driver,this releases gear change shaft.the biggest problem is trying to see what you are doing.good luck
Oct 08, 2013 | Suzuki Outboards - Zinc 115-140Hp Outboa
2000 Mercury 115 ELPTO impeller replacement. The Quicksilver replacement kit comes with various washers / face seal. The water pump housing didn't have a seal on top of the old one. Am I supposed to use...
if you mean a large flat sided 'O' ring then this is to help keep water in the impellor housing !? some housings have gaskets between the base plate and housing , check the impellor in the housing and see if it stands proud as then you need the gasket ! compare with the old one as it mite have been forgotten !! check the seal and tube for the water pipe also ok!
Sep 23, 2013 | MERCURY / QUICKSILVER Mercury/Quicksilver...
Water pump
The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
May 14, 2013 | Seloc Mercury Outboard Engine Repair...
Gear box oil leak
Here is a website where a manual for you outboard may be purchased.  Outboard Marine went out of buisness in 2000 and thus no parts of origial manufacture are support is available . Therir are secondary markets .    THe Lower case splits in half and their is a seal around the prop shiftm which is pressed in. The seal between the cases are cut o-rings which are placed and glued into place with gasket seal.
The water pump is located where the case splits a little bit higher. You must open the little port on the side and take out one of the screws to the connecting shift linkage to split the case. After splitting the case the drive shaft and water pickup tube(s) wil come out of the powwer head or the tubs may stick into the power head which is ok. Place the lower skag into a vice and remove the 4 or 5 screws to the water pump housing. Remove and replace impellor and impellor plate if available. If part(pieces) of the rubber impellor is missing flush out the tubes and the power head to remove them.   When reinstalling the lower unit use a flash light to make sure that the tubes return  to the proper place in the power head and the shift lever is resecured. If you need more assistance, just write back. I was an Outboard motor mechanic for five years about the time of your motor.
Dec 23, 2008 | Boating
Boating Logo
994 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
