Question about RCA WHP140 Consumer Headphones
Cannot get power to the unit the light indicating power is out
Been awhile but the headphones are almost new but now when I plug in the power cord no light appears on the unit. any suggestion. Headset seems to work I hear noise but since the main unit is in op. I cannot receive anything.
    Problem Solver:
  • 5 Answers
I have the same model as you. I have two transmitters and three headphones actually. Please see below:
Plug in the transmitting unit into a good working power outlet. Make sure you have the audio connected to a loud source. Turn on the source device producing the loud audio to be transmitted to your headphones. Now see if the transmitting unit's LED light is on. Check headphones for audio. (May have to tune in the headphones and adjust its volume as well).
I recommend that the source of your audio have its built-in speakers off, while still providing audio out to your transmitting unit, via an external audio output. Check your source manual or look for audio jacks on the front or back. There may be a setting to turn this on and for the main built-in speakers to be turned off as well.
If this does not work, unplug the transmitting unit, and then plug it back in again, after waiting for about 10 seconds - all while audio is being provided to the unit. It should come on.
Posted on Sep 05, 2010
Haier window unit reset plug not resetting
check the house power board circuit breaker if the light indicator is not working
Jul 25, 2016 | Haier Heating & Cooling
Headset will not re-set according to instructions. Indicator light is half red, half blue. What should I do?
I had the same issue with green light always on and not turning off. Call button plus volume up button did not work when the unit was not plugged in. When I plugged the unit in to charge, the volume up and call button (together) did reset the unit.
Oct 14, 2015 | AUVIO Bluetooth Headphones
How do I turn on my new HP 6550B?
I'm assuming you have already tried the power button with the power cord plugged in. Have you recently took your laptop apart for any reason. Sometimes when people put their laptops back together the power button doesn't get lined up correctly.
If you haven't taken the laptop apart, then try a few things:
- Remove the battery plug only the power cord in and try
- Remove the battery and power cord wait a few minutes, then plug back in the power cord and try
- If you have a spare battery, plug the spare in and try
Please rate if this helps
Mar 11, 2011 | HP Computers & Internet
I have a Wurlitzer Funmaker organ that has no sound. Is there a reset or fuse I should be looking for to get this organ working again? I removed the back Panel and need some suggestions the light on the...
Contact Morelock's Organ Service, Rienzi, MS, United States Phone 601-462-7611. Provide them with the complete model number and expect to pay for a service manual if they have one. Start at the end of the power cord and work towards the amplifier section. You will want to establish that the power supply is working correctly. The light is only an indication that the power cord is getting power to the power switch. If the power supply is providing the correct voltages to the other circuit sections of the organ then you will have to trouble shoot each one separately. Check to make sure the speaker is functional. If it has a headphone jack test it also as it may cut the sound to the speaker out if headphones are plugged in. If it is faulty, sound may not get to the headphones or the speaker. You will also need tools. At least a volt/ohm meter.Remember not to work on the circuits with the power on unless you absolutely know how to do this safely. There are lethal voltages in the power supply.
Dec 18, 2010 | Music
Wii console will not turn on. The indicator light is out
Try unplug the AC adapter from power cord then wait 30 min and plug it again.If not help you may need new AC adapter.Check in online stores, there is many types.
Nov 17, 2009 | Nintendo Wii Console
IBM X226 server
i have two x-series server but in one server with one power cords it is showing green light but in case of another server it is comming yellow light.
Nov 24, 2008 | IBM xSeries 226 Server
No sound from speakers.
Hi...
On some stereo gear the headphone jack interrupts the speaker connection when the headphones are in. you "might" have something broken in the headphone jack which is keeping the speakers from turning on.
Is there a MUTE switch on the unit?
Or an "External speaker off" thingy in the menu?
Sep 07, 2008 | JVC TH-M303 System
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
RCA wireless headphones
Hey, my rca whp141 is incredibly quiet. Go ahead and turn the volume up on the TV.
If that doesn't work make sure
  • The headphones and headset are on the same channel (like 1).
  • the transmitter is on and working (Power: GREEN LIGHT)
  • the headset is on and working (GREEN LIGHT)
  • the headset is receiving a signal (St: GREEN LIGHT).
Hope this helps.
Jan 08, 2008 | RCA WHP141 Consumer Headphones
RCA WHP140 Consumer Headphones Logo
256 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
