Question about Farmall International Tractor 140 Radiator
Have a IH-140 (1977 - 12volt) that is missing /skipping
Have a IH-140 (1977 - 12volt) that is missing when accelerating. I have changed points, plugs, Distributor Cap, rotor button. Also disassembled carburator - cleaned jets to no avail. Runs as if it is fuel related - but unable to tell for certain. suggestions / tips ???
3 Suggested Answers
  • 15 Answers
SOURCE: slow acceleration low on power
have you checked fuel filters? make sure that fuel shutoff valve is fully open, and that your fuel is clean/water-free,and hasn't cold-weather gelled
Posted on Feb 09, 2010
whpete44
  • 484 Answers
SOURCE: I have a propane Farmall
To keep that from happening, consider cutting and fitting cardboard to slip up under the hood and notch it to where it slides into the frame. I still do that with sheets of 1/4" plastic for the tractors that sit outside. This sheds rainwater from the generators, carbs and distributors. It also keeps the carbs from icing up in cold weather.
Posted on Mar 12, 2015
Why does it struggle to accelerate beyond 40 mph?
Does it do it hot or cold or both ? Does it skip or miss or buck ?
Jun 15, 2015 | Cars & Trucks
My expedition skips on low acceleration and stops when accelerated hard why
What you have is one of two things. You have a sparkplug that is bad and or a cop (coil on plug) that is bad. A good way to figure this out is to go to autozone and have them do a code check. Sometimes a " check engine" light will come on and sometimes it wont. My check engine light never came on. It was missing but after aceleration or high rpm the miss would go away. I changed both the cop and spark plug and problem fixed. By the way coil on plugs are expensive. I ordered mine on the internet and saved over 75%. Best wishes and hope this solves your problem.
Mar 18, 2015 | 1999 Ford Expedition
Why does my 1998 sebring idle fine but sputter badly under load.
Does it use spark plug wires or individual ignition coils for the each plug?. My 98 intrepid uses coils and occasionally I have to change them out cause it would start to miss when normal temperature was achieved. If it uses wires, try replacing them, along with the spark plugs.
Jun 21, 2012 | 1998 Chrysler Sebring
On 1995 saab engine skipping and hesitation when hot
POSSIBLE CAUSE FOR MISSING AND HESITATION BAD COIL - FAULTY SPARK PLUGS AND WIRES -WEAK FUEL PUMP.CHANGE FUEL FILTER AND CHECK FUEL PRESSURE SHOULD BE 43 PSI. CLEAN FUEL INJECTORS BY FILLING UP FUEL TANK PUT A BOTTLE OF SEAFOAM IN FUEL TANK CLEAN OUT THE INJECTORS.IF ALL LOOKS GOOD.OTHER POSSIBLE CAUSES TO MISSING ENGINE COULD BE INTAKE MANIFOLD VACUUM LEAK OR HOSES LOW ENGINE COMPRESSION.HAVE EXHAUST SYSTEM CHECK FOR RESTRICTION BECAUSE YOUR TURBOCHARGER NOT GOING TO GIVE YOU MUCH POWER ON ACCELERATION.
Aug 30, 2010 | 1995 Saab 9000
It skips when u hit 48 to57 miles an hour please help ive replaced the wires to the fule filter please help Ive also replaced the egr valve and the distibuter
Sir,
When your car seems to skip at what ever speed all you have to do is to check the Plugs and Plugs wires they must be missing the current that is why your Ride is skiping. all you have to do is to start the are and accelerate it without in gear. it will give a **** if missing.then the problem will be confirmed and you would be required to change it plug wire and plugs both.
Oct 25, 2009 | 1996 GMC Sierra
Engine is skipping when accelerating
You only have 4 so better just do a tune up and change the plug and wires, but one at a time so you don't get them crossed when re-installing the new plugs and wire.
Use Platinum plugs since there good for 100,000 miles which mean less maintenance, and double check that the spark plug boots set to the plugs when re-installed.
Run some fuel injector cleaner through the gas tank for about a week to to clean out your fuel system and hope fully the skipping stops.
If your going to get all the goodys at Auto Zone, have them scan the car for any DTC codes since it's free and see if there are other issues that is causing the skipping like a bad signal from the MAP sensor ECT.
Good luck and keep me posted.
May 26, 2009 | 1997 Saturn SL
2004 F150 6 cyl - engine misses
yes , if it is sparking to ground or from the coil , but if it is comming off the wires down by the coil then its the wires (maybe laying on a hot point of the engine)
but also check the wires all the way to the coil to see if they maybe sparking somewhere along the way
Apr 30, 2009 | 2004 Ford F150
Farmall International Tractor 140 Radiator Logo
Top Farmall Garden Experts
Dennis Key
Dennis Key
john h
Colin Stickland
Colin Stickland
Are you a Farmall Garden Expert? Answer questions, earn points and help others
