Question about Amana ARGS7650 Electric Kitchen Range
My spark module is probably out, but I don't know how to open up the range to look at it/replace it. How is this done?
    President:
  • 1,015 Answers
Most newer ranges with sealed burner cooktops can be a little bit tricky to open. People have a tendency to try and lift the cooktop up like on the older ranges and end up damaging the range and causing a gas leak. The first thing to do is to unplug the range of course. Then start by removing the rear panel of the range. From there you can get a visual feel of what you are up against. With the back panel removed you should be able to see into the top part of the range. Most newer sealed burner cooktops require you to disconnect the screws holding the burner tubes to the bottom of the cooktop. If you do not remove these screws you will break the tubes when you lift the cooktop. Most of the time the screws are removable from the top at the burner heads. Once these screws are removed you should be able to lift the cooktop up. From there the ignition wiring and spark module should be available now for servicing.
Posted on Apr 24, 2010
Is there any aftermarket spark module available for a kitchenaid KGCS-1340P
Contact a local small appliance repair shop they will know this info and can supply the parts if available.
Sep 28, 2016 | KitchenAid Kitchen Ranges
Finding the right ignitor spark part for my gas range.
Go to the Sears parts sort online, if parts are available then you will find it there.
Jun 07, 2016 | Kenmore Kitchen Ranges
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
Do I have a bad spark modulator or a bad electrode?
Yes, it does sound like you have a bad spark module. But it could be a dirty spark electrode, allowing most of the voltage follow the "dirty path" to ground instead of going through the air. Make sure the electrode (the insulator) part is clean and dry. If you still have a weak spark (or one that goes out when the gas is turned on), they you probably have a bad spark module. If you want to know for sure, try swapping 2 spark wires. Remember that when 1 ignitor sparks, they all (are supposed to) spark.
Nov 07, 2014 | Kitchen Ranges
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
Ge profile gas range. one burner with no clicking and no ignition
You may have a bad burner switch. If you turn one of the other burner switches to make the spark modules spark look and see if the electrode is sparking at the bad burner. Most of the spark modules send a spark to all 4 burners when activated. If it sparks when another burner is activated open the valve and see if the burner will ignite. If so you probably have a bad burner switch.
Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
HOW TO REPLACE SPARK MODULE ON KITCHEN AIDE KDDT207AWH0
It's very simple to replace. Pull the stove away from the wall so you can access the back components.
UNPLUG THE STOVE FROM THE WALL OUTLET.
The spark module is located on that surface below the stove top. Carefully note the position of the old module and label the wires so you can put them in the new module correctly. There should be 2 or 3 screws that are holding the old igniter module in place. Remove the screws, install the new module EXACTLY as the old one had been, and connect your wires. DONE.
Oct 08, 2009 | Kitchen Ranges
Range igniter acting strange
You most likely have a defective spark module. This is a device that transforms standard household current (120 volts) down to about a 12 volt spark to ignite the gas. You should probably call someone who is experienced in this field.
Oct 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Amana ARGS7650 Electric Kitchen Range Logo
279 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De GO PATS
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
