Question about Food Mixers
Panasonic super mixer grinder MX-AC300 is not switching on
  • sureshnag Apr 24, 2010
    Thanks for the reply. I have opened it and checked the wires but nothing seem to be broken. I do not have a electric tester, so I am not sure if there is any problem with the power.
  • Food Mixers Master
  • 4,924 Answers
There are not much things that could get wrong with this one...if you are handy enough ..open it and check the wires...it is probably just a loose one ...or broke one..
the actual circuit is direct ..and it just has a loop to the switch ..so ...if you take a control lamp ..or a measurement instrument ..you will be able to see where the power is interrupted ..my guess if there are not any visible..wires loose...it is the switch..or the external cable broke.....but , there can be the motor itself also ...and in this case there is nothing to be done ..and worth...
just open it ..and check the wires with a instrument for electric current presence.. ..if the current is present until the motor's contacts..it means that the motor is out ..
Posted on Apr 24, 2010
  • Catalin Turcu
    Catalin Turcu Apr 24, 2010
    juat use a light ball...wired...from a lamp or anything like...get one wire on the null at the entry ..(this one is not usually wired through the switch)...you can even tie it near the motor...and with the other end ...check each segment ...at the entry first ..to see if the juice gets in from the plug...than before ..and wfter the switch...this way see if the switch is ok ..and final at the motor...if the light will work ...this means tha current is ok ...and the motor is out ...In this case the price ..may be too big to worth repair...so ..unless you really care (sentimental value) for this mixer...it is the time to get another one if t proves that the motor is out ...or get a motor second hand from one that is broke at the cover or electrical...
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
Need help getting food grinder attachment troubleshooting cant get mine to operate
When you use an attachment the mixer will still stir. You need to remove the beater when using an attachment.
Mar 04, 2015 | KitchenAid K45SS Classic Stand Mixer
The switch doesn't work on my grinder. got new one but terminals are different. is there a schematic for min0022 or 40744 grinder?
Best you contact the manufacturer so you do not burn out the motor by mistakenly attaching to the wrong posts.
Mar 14, 2014 | Vollrath 40744 22 Meat Grinder 1.5 HP 110V...
I brought an MX-AC300 PANASONIC mixer grinder from india to usa.its not working.it's not start even once.can any one help me out on this .i used voltage coverter also.
did u check it( i mean whether it was working) in india if not look in to the warranty period and find out what u can do.. i have bought the same mixer and i'm going to take it to finland in a couple of months.. at present in india its working fine.. and one more qn is it the first time that it's not working.. or it stopped working.. coz too much of rotating might even harmed the mixer.. remember for this mixer it should not go more than 3 min..
Mar 29, 2010 | Food Mixers
What is the red switch for on Kenwood Chef A901?
If the attachments that you are talking about are the dough hook and the whip, then the red lever is not used to put them in or take them out. The red lever releases the plastic housing on the end of the mixer, which then exposes the mounting hole for the major attachments such as the grinder, sausage maker, etc. You push the red plastic lever, then gently pull off the plastic end of the mixer. It should come off with absolutely no force. Then insert your food grinder or other attachment with the red lever held back. Once the cog on the grinder is aligned with the fitting inside the hole, release the red lever so that the recessed hole on the grinder will become engaged. The Kitchenaid classic stand mixer and the Viking stand mixer have essentially the same set up.
Jul 19, 2009 | Kenwood KM800 Major Classic Stand Mixer
Panasonic MX-216E - work when you shake it or tap some times..
I used to live in Mtn. View on Bryant St. next to the P.G.&E office, great town.
I have had appliances go as long as twenty years and never had the brushes go out, but it sounds kie that is your problem alright, this is very unusual I would contact Panasonic and see what they will do for you there is usually a one year parts warranty on small appliances, call them you have nothing to lose. I would call this a factory defect.
Feb 28, 2009 | Food Mixers
My Super Grinder needs repairs
the blade of the jar got jamed, you have to remove the jar shaft and lubricat with any oil and refix it back
Feb 02, 2009 | Food Mixers
Kitchen Aid switching from mixer mode to grinder
There is no switch. When you have the accesory in the front, the beater section still moves. I suggest that you remove the beater so that there is less possibility for someone to get hurt.
Nov 07, 2008 | KitchenAid KSM150PS Artisan Series Stand...
MX-AC300 Mixer Grinder Got from India 2 months back Not working.Tried Reset Button too.
There is a great guy on Gerrard street in Toronto, who can fix mixer grinders and has parts also like breaker/reset switch etc.
The store is called Appliances 220, Ph # 416-778-9908.
Hope this helps.
Sep 24, 2008 | Food Mixers
Food Mixers Logo
371 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
