Question about Troy-Bilt Pony Garden Tiller
Disassemble Troy-Bilt Econo-Horse Transmission (1991 Manufacture)
I have the transmission mostly disassembled, however, I do not see how to get the drive wheels shaft out in order to replace the drive gear.
  • 23 Answers
If you do not have a manual you can get it free at troybilt.com.
Posted on Aug 10, 2010
I am trying to find a drive belt idler replacement for a troy bilt econo horse model tiller
Sorry we do not sell parts nor do we have parts locator services here.
Aug 22, 2017 | Troy Garden
How do i replace a transmission control solenoid and where is it located?
Which control solenoid ? There are a few ,1-2 shift , TCC solenoid ,3-4 shift ,PWM solenoid .
Remove the case side cover. Refer to Case Side Cover Replacement (W/ Gasket) .
Removal Procedure
Tools Required J 28467-360 Engine Support Fixture
  1. Disconnect the negative battery cable. Refer to
  2. Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
    in General Information.
  3. Remove the park/neutral position switch. Refer to PNP Switch Replacement
  4. Install the J 28467-360
  5. Raise the vehicle. Support the vehicle. Refer to Vehicle Lifting and Jacking in General Information.
  6. Remove the left front tire and wheel assembly. Refer to Wheel Removal in Suspension.
  7. Remove the inner splash shield.
  8. Remove the tie rod end from the knuckle assembly. Refer to Strut Assembly in Suspension.
  9. Remove the stabilizer shaft link from the lower control arm. Refer to Control Arm in Suspension.
  10. Remove the ball joint from the steering knuckle. Refer to Ball Joint in Suspension.
  11. Remove the drive axle from the transmission. Refer to Drive Axle in Driveline/Axle.
  12. Remove the pinch bolt from the steering gear intermediate shaft. Refer to Intermediate Steering Shaft in Suspension.
  13. Caution: Failure to disconnect the intermediate shaft from the rack and pinion steering gear stub shaft can result in damage to the steering gear or to the intermediate shaft. This damage may cause loss of steering control, which could result in an accident and possible personal injury.
  14. Remove the intermediate shaft from the steering gear. Refer to Intermediate Steering Shaft in Suspension.
  15. Position a transmission jack under the transmission oil pan. Raise the jack until lit supports the transmission.
  16. Remove the three frame-to-body bolts on the left side.
  17. Lower the transmission jack and the transmission in order to gain access to the case side cover.
  18. Remove the oil cooler pipes at the case. Refer to Automatic Transmission Oil Cooler Pipes Replacement
This is a monumental task , suggest you take your vehicle to AAMCO or some other transmission shop .
May 09, 2016 | 1996 Oldsmobile 88
Where is location of shift solenoid a located on 05 cobalt?
The shift solenoid valves are two identical, electronic exhaust valves that control upshifts and downshifts in all forward gear ranges. These valves are normally open. These shift solenoid valves work together in a combination of ON and OFF sequences in order to control the positions of the 1-2, 2-3, and 3-4 shift valve trains. The TCM monitors numerous inputs to determine the appropriate solenoid state combination and transmission gear for the vehicle operating conditions.
Remove the transmission side cover. Refer to Control Valve Body Cover Replacement . Remove the 1-2 shift solenoid retainer clip (304), the 1-2 shift solenoid (305) with O-ring (303), the 1-2 shift valve (302), and the 1-2 shift valve spring (301).
Remove the PNP switch. Refer to Park/Neutral Position Switch Replacement . Remove the transmission upper side cover bolts. Install the engine support fixture. Refer to Engine Support Fixture in Engine Mechanical. Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information. Remove the left front tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels. Remove the left inner fender liner. Refer to Front Fender Liner Replacement in Body Front End. Remove the wheel drive shaft from the transmission. Refer to Wheel Drive Shaft Replacement in Wheel Drive Shafts. Remove the power steering gear mounting bolts. Refer to Steering Gear Replacement in Power Steering. Remove the frame. Refer to Frame Replacement in Frame and Underbody.
This is a tough repair an needs special tools to do it . your best bet is take it to AAMCO
Dec 04, 2015 | 2005 Chevrolet Cobalt
How do I remove a wheel?
It looks like you would have to cut the nuts off to get the wheel off . From you picture I cannot see any other way Will not be easy .But you will after be able to put better nuts on .
Apr 24, 2017 | Troy Garden
How do I remove a tire from a Troy-bilt Econo-horse?
should be some sort of keeper pin that holds the hub or rim on the shaft. pull the pin and slide the wheel off
Aug 16, 2014 | Garden
Econo-horse tillerser.#e023842
You can order them from your local MTD dealer.
Oct 27, 2012 | Troy-Bilt Pony Garden Tiller
CAN I USE A 4 WHEEL DRIVE TRANSMISSION ON A 2 WHEEL DRIVE TRANSMISSION IF I CHANGE THE TAIL SHAFT
if its the exact same transmission, BUT you have to completely disassemble trans to remove snap ring that holds shaft in
May 20, 2011 | 1995 Jeep Grand Cherokee
Troy-Bilt Pony Garden Tiller Logo
315 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
