Question about Hunter 20479 The Stratford II Ceiling Fan
The Stratford II ceiling fan is in my guest bedroom and has only been used about 20 hours. After running for awhile, a clicking sound starts and the faster the fan runs the closer the clicks going from loud on slow, less obvious on medium and then on high one cannot hear it. Called an electrician and he said it sounds like a bearing problem. How could that be on a fan used so little? Any suggestions before I pay an electrician to come out and look at it? Hopefully, Hunter will stand behind their product and replace it.
    Novelist:
  • 145 Answers
I know that some fans can be oiled. You may want to look into that for your particular fan.
Posted on Apr 28, 2010
Ceiling fan lights flicker in bedroom with 23watt cfl bulbs
Sounds like an older unit that has either a dimmer or electronic switch. You need to use dimmable CFL lamps.
Nov 07, 2013 | Hunter Dryers
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
Fan chain pulled out from Fan Body. How do you fix that
rmove the cover ... you will find the loose end inside. Get a chain at your local hardware or electric supply store.
Sep 16, 2010 | Hunter 20761 52'' The Stratford II Brushed...
After installation the whole fan wobbles. it is standard installation
The most important thing about installing a ceiling fan is to use the proper ceiling box, one that is approved and very firmly fastened to the ceiling joists. If this is not done and the fan is only attached to an existing ceiling box, it may end up being out of balance and wobbling, not to mention being very dangerous.
Sep 08, 2010 | Hunter 20479 The Stratford II Ceiling Fan
The fan chain does not pull smoothly ,had to use string
if its an old fan the switch may be worn out an electrician can replace it most places like home depot offer some kinda replacement part for not much money. replace it yourself if you can do it safely remember electricity kill
Mar 30, 2010 | Hunter 20479 The Stratford II Ceiling Fan
Lightning causes ceiling fan to make clicking noise
sounds like surge shorting
call in an electrician to check the installation of the unit
Aug 06, 2017 | Hunter 20761 52'' The Stratford II Brushed...
Fan won't turn on, dont know where switch is
I looked up the owners manual for your fan at the following site: http://www.hunterfan.com/search.aspx?search=20763
Click on the pdf file labeled owner's.This manual indicates there should be a pull chain for turning on and off the fan. Maybe the chain has broken off up inside the fan. You can follow the instructions in this manual to take the fan apart and replace the pull chain.
May 30, 2009 | Hunter 20763 52'' The Stratford II Ceiling...
Simultaneous fans
USE A DIFFERENT DIP CODE TO THE SECOND RECEIVER AND REMOTE
Jun 01, 2008 | Hunter 21617 Palermo Brushed Nickel...
Hunter 20479 The Stratford II Ceiling Fan Logo
144 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
