Question about Nikon Cameras
I need an operating manual for a Pennsylvania 5600 weighing scale
I just obtained a used Pennsylvania 5600 weighing scale. I need an operating manual.
robocop
  • 90 Answers
SOURCE: need manual to reset scale to weigh properly
Either do a search for that particular scale brand & model, which should take you to the company, whom should have a manual on-line or go back under search and type in "users manuals". There should be several manual websites that come up. Just don't click on the websites that require money for their manuals, when you can get them for free at other sites.
Posted on Jan 22, 2009
zlim44
  • 10 Answers
SOURCE: Hanson weigh scales I have no manual HXM150
just go to the website and down load the manual pdf form. it should be there!
Have fun!
Posted on Aug 27, 2009
Testimonial: "My first time to ask for help and it was totally correct. Thanks."
  • 10 Answers
SOURCE: Instruction manual
I would at this point return to the place that you bought the scale or some place that sells the same one you have and buy it and then photo copy manual. Then take your reciept and the scale and go get your money bac! Good luck.
Posted on Nov 24, 2009
  • 279 Answers
SOURCE: New Scale out of box will not weigh correctly
Take a 5 pound bag of sugar, flour or what have you. Put it on the scale. If it is off, turn the scale so that you can check every possible place for an adjustment. Adjust and go for it!!! Good luck...Lee
Posted on Jan 17, 2010
SOURCE: My digi sm-300P digital weighing scale needs tob e
Hi, have you solved your sm300 problem? I can calibrate for you. :)
Posted on Feb 20, 2011
How to measure 250gm dried herbs
If I needed to do that I would use a kitchen weighing scale and if the weight accuracy required was on the near-enough side I wouldn't care if the scales were old as I would weigh out 10 ounces.
If reasonable accuracy was required I would use a balance type kitchen scales with a 250gm weight.
If greater accuracy than that was needed I would ask at my local post office...
If still greater accuracy is needed you would first need a humidity controlled environment and about 24 hours for the herbs to stabilise before weighing...
Feb 24, 2017 | Health & Beauty
I have a DigitZ DZ3-600 and when I turn it on the word FULL in the display screen . What can I do to clear this and start using it?
My search is telling me that this is a scale. Is this correct? If so - this is the manual. \'FULL\' is not an error, but this is the correct model. If this is not a scale, please write again and provide more information:
The manual is short and PASTED after link to same here:
http://digitzscales.com/index.php?option=com_content&view=frontpage
Digitz DZ3-600 Manual
I. Operation
1. Place the scale on a flat, level surface and press the ON/OFF key to turn the scale on.
2. Once the start-up process completes and the scale goes to zero you are ready to weigh.
3. Place the quantity to be weighed onto the weighing platform.
4. Wait a couple seconds for the display to stabilize before taking a weight reading.
II. Changing the Unit of Measure
1. Press the MODE key to change the scales displayed unit of measure.
2. If the scale is turned off then back on, it will default to the last unit used.
• DZ3-100 Units: g (gram) oz (ounce) ct (carat) gn (grain)
• DZ3-600 Units: g (gram) oz (ounce) ozt (troy ounce) dwt (pennyweight)
III. Using the Tare Feature
You can use this scale\'s tare feature to subtract the weight of an empty container or vessel for net weight determination. NOTE: The weight of the container will subtract from the available capacity.
1. Place the empty container or vessel on the weighing platform.
2. Press the TARE key once. The display will then reset to zero. If the container is removed, it\'s weight will be displayed as a negative number.
3. You may now fill the container with the quantity to be weighed. The display will show the net weight of the contents.
4. To return to normal weight display (gross weight), remove any items from the weighing platform and
press the TARE key again to re-zero the scale.
IV. Calibration / Adjustment
1. Turn the scale on by pressing the ON/OFF key.
2. Wait for the display to show "0.0g" or "0.00g" then press and hold the MODE key until the display shows "CAL", then release.
3. Press the MODE key again. The display will flash "CAL" followed by the required calibration weight.
4. Place the required calibration weight on the center of the platform. The display will show "PASS" then return to normal weighing mode. Calibration is complete! You may now turn the scale off.
V. Error Codes
1. OUTZ - Zero range has shifted. Perform calibration adjustment. If the problem persists, the load cell may be permanently damaged due to overloading.
2. 88888 - Maximum capacity exceeded. Remove the extra weight to avoid damaging the load cell.
3. L - Batteries are low. Replace the batteries.
VI. Specifications
DZ3-100 DZ3-600
Max. Capacity 100g 600g
Readability 0.01g 0.1g
Min. Weight 0.03g 0.2g
Power Two (2) AAA Batteries
Dimensions 3.0 x 5.0 x 0.8 in.
Platform Dimensions 2.5 x 3.0 in.
For warranty and support, please email
warranty@digitzscales.com
Aug 20, 2014 | Office Equipment & Supplies
Spring scale can be used to weigh it?
Spring scale shouldn't to weigh heavy items, it may easily malfunction. But it can be weigh some small items.
Dec 30, 2012 | Health & Beauty
Need manual for weigh of life scale
I have the instruction manual for the Weigh of Life scale. I can mail you a copy for only $5 (PayPal), as I have to go get copies made.
spspirk@gmail.com
Mar 26, 2011 | Digi Health & Beauty
Tells different wieght each time
Does it tell you a different weight each time you weigh yourself in the same few times? Or day by day?
If its consecutive uses that give you different weights, if you're within 0.2kg, I wouldn't be surprised if the scale can't do better.
Otherwise, weigh yourself each day at the same time, and take an average of 3 weighings for the 'best' weighing.
Mar 02, 2011 | Taylor Body Fat Analyzer & Scale, Model...
Gives me diffrent weights even though I am weighing myself within seconds of time, and in the same spot on the floor.
I've found I have to weigh myself, step off, weigh myself with something in my something heavy in my hands, then weigh myself again. The 3rd weight you get will be your correct weight. If you needed the manual, I have uploaded in into photobucket...although it doesn't really address this issue.
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Amy
Jan 07, 2011 | Taylor 5568 Fat Scale Stainless Steel ()
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
Scale is not weighing correctly. Weighs correct
The scale must be on a hard, level surface. Make sure there is absolutely no dirt on any of the pivot points. Calibrate it with a KNOWN 25 pound weight.
Jan 04, 2010 | Health-O-Meter Health o meter 402KLWH...
I need a manual for a Berkley fs50 scale
Operating Instructions1
A. Powering-on the scale
1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
B. Normal Weighing
1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
C. Switching between unit weights
1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
D. Taring Weights
1. Weigh a bag or container till its weight is steadily displayed on the screen.
2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
E. Holding a weight
1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
F. Storing weights into memory
1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
G. Resetting the memory
1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
H. Powering-off manually
1. Press and hold the POWER button for 6 seconds.
Dec 09, 2009 | Berkley Twist Lock Rod Rack
Cameras Logo
249 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
