Question about HP Pavilion F1703 17" LCD Monitor
I have to push the on/off button multiple times before it stays on
  • 11,361 Answers
This model has bad solder works on the four inductor on the inverter board, please see my pictures here, make sure to remove old solder first and clean the inductor wires real well before soldering.
http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/
If you Google 'HP F1703 problems', you will get a lot of hit, it was so bad that HP had the recall on this model.
Posted on Apr 24, 2010
My garage door will not stay closed it hits the ground and then starts back up again. If I push the purple button on the box it will work one time but then the next it won't work again?
You need to adjust the stop for the down position switch. Get the manual, and look for the adjustment process. What you want to do is get it to stop a few inches above the slab, then slowly tweak it back down. This takes some patience and multiple tries to get it right.
Jan 20, 2018 | Building Materials
Power button does not work
it might be that it only needs sprayed with a shot of electric contact cleaner .
Dec 05, 2017 | Cuisinart Coffee Makers & Espresso...
Lg wm2240cw won't turn on
Replace power button. Easy. Inexpensive. Check out appliancepartspros.com or repairclinic.com.
Dec 16, 2013 | LG Washing Machines
2008 Lexus ES350 won't start after multiple times
You will need the dealer to look at his, diagnosis of this problem takes special equipment and skills.
Oct 22, 2012 | Cars & Trucks
Have to push power button multiple times to start
Well it looks the contact of your power switch is either loose or dirty inside. If you do not have any background on dismantling your unit it would be wiser to just send it to a proffesional technician.
Sep 27, 2012 | ASUS K50IJ-C1 Notebook
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
TV will not start easily. Akai LCT2721AD
You only have to unplug it for 30 seconds. Also, make sure it does not have a DVD in it when you turn it off as the TV will try to default to the DVD all the time. Resetting the power (I use a surge protector) allows it to turn back on normally. Based on the comments I've seen this TV has terrible sound with DVD, doesn't want to turn on, and is hard to mount on a wall.
Nov 18, 2009 | Televison & Video
Device Selection menu stays on constantly and flickers...
sounds like a bad selector switch from the onboard card that has the console controls. my hitachi did something similar, and it turned out to be the board that the buttons are on
Mar 01, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Original XBOX CD tray ejects multiple times before staying put
I had The Same Problem Theres Nothing You Can Do. Call Microsoft And Ask For A New One.
Jun 12, 2008 | Microsoft Xbox Console
Sony Trinitron KV32FS16==> Need to push pwr button multiple times
after it fails how many times does the red LED blink? check the board very closely for any cracked solder. and then check the main regulators. also look to see if you have any physically bad capacitors, they might look like they are exploding on the top.
Feb 03, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
HP Pavilion F1703 17" LCD Monitor Logo
119 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
