Question about RCA Televison & Video
When turn on it turn it self off right a way - RCA Televison & Video
    President:
  • 1,768 Answers
There is a power supply issue here. the main-board is malfunctioning . this may be the rectifier circuit or a failing capacitor in the power on circuit. You will need to have the unit serviced.
Posted on Apr 24, 2010
Epson Pro 7800 Maintenance Request 0040
Hi Frank,
Please supply a detailed description of the problem. Give as much details leading up to the problem as you can so that I may understand what's happening.
I'll be waiting for your response.
Randy
Feb 07, 2012 | Epson Stylus Pro 9800 InkJet Printer
The reset power flasher is continually on! How do I remove? Dean
Issue All lights on the product control panel flash and a 'Reset Power ' message displays on the product control panel. Solution one: Turn the product off and then on Follow these steps in the order presented to turn the product off, and then on again. Step one: Turn the product off and then on
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the product.
Step two: Print a self-test report
  1. Load clean, unused, plain white paper into the input tray.
  2. Press the Setup button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  4. Press the Right Arrow button (c01185072.jpg ) to select Self-test Report , and then press OK . The self-test report prints.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Reset the product Follow these steps in the order presented to reset the product. Step one: Reset the product
  1. Press the Power button (c01602202.gif ) to turn on the product.
  2. With the product turned on , disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
  2. Press the Setup button (? ).
  3. Press the Right Arrow button (c01185072.jpg ) to select Print Report , and then press OK . The Print Report menu displays.
Solution three: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
Aug 16, 2011 | HP Officejet 6310 All-In-One InkJet...
Hi, I am trying to use the self timer function on my Nikon D90 but it doesn't seem to work. I have checked on many sites how to use it, but whenever I press the self timer button and turn the roll left...
The button for this is on the right, the second one from the rear and it has multiple squares on it for a symbol. Pressing and holding this button down then turning the rear dial should change the shutter release function. It cycles through single shot, multiple shots low and high speed, and then self timer. You set the actual parameters of the self-timer from the custom setting menu.
Dec 27, 2010 | Nikon D90 Digital Camera with 18-105mm...
I went to use the auto clean on my oven....turned the knob to "auto clean" then turned the oven door latch to the right to lock it. i found out the auto clean took 4 hours (don't have time to do it today)...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 08, 2010 | Hotpoint RB787 Electric Kitchen Range
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Maintenance request 0040
Maintenance request code:
The pump counter is near end of life, replace the cleaner kit ASAP.
This is what 0040 means.
May 03, 2010 | Epson Stylus Pro 9800 InkJet Printer
Oven shuts off when the door opens
Turn breaker off for 5 mins. then turn back on, this will clear the memery and take it out of self clean.
Please rate solution
Sep 05, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self timer for the nikon n55
Press the self-timer button just to the right of the LCD panel and confirm that the self-timer icon appears. Press the shutter release halfway to focus and meter. Press the shutter the rest of the way to activate.To cancel, either turn the camera off or press the self-timer button until the self-timer icon disappears.
You can get a manual at http://www.butkus.org/chinon/nikon.htm
Jul 13, 2009 | Nikon Photography
Camera self- diagnostic doesn't work
I had this exact problem when I had not used my camera for some time. For me the solution was to take out the flash card, and turn on the camera while pressing the flash button. This allowed me to run the self diagnostic test (which were ok by the way), and then after turning the camera off and on again it worked!
Dec 23, 2008 | HP Photosmart R817 Digital Camera
Televison & Video Logo
24 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
