Question about LG DLE5955 Dryer
Flowsense has four bars all the time even with vent disconnected
Dryer lg dle5955w
  • 1,557 Answers
Buy anti static balls
Posted on Apr 24, 2010
LG DLGX2502W gas dryer: inside the drum on the back wall where there is a grid w/holes, that had been burnt. I cleaned all the lint vents. The sensiflow shows no bars. dryer works. is it safe?
The gas burners are about 18" from that grid. The orange u see is the burner flame. The grid looks burned because of the heat from the flame. Try taking a shop vacuum to the grid and see if you can suck any lint from the burner chamber. If you get a lot, then it might be worth taking the dryer front off and cleaning it out. I doubt you have any safety worries. It is surprising how much lint gets inside of a dryer.
Jan 08, 2017 | LG DLGX2502W Front Load Gas SteamDryer,...
Lg dle5001w flowsense
Replace the timer switch, check the wires to it and to the heating element!
Dec 25, 2012 | LG DLE5001W Dryer
My LG Tromm DLE5955W dryer has great airflow and heating but about 2 months after I bought it, it now takes 2 hours to dry a load of clothes. I have vaccumed it out and replaced the vent house already with...
You have a problem with the exhaust vent in the house walls. Try this. Disconnect the dryer vent hose from the back of the dryer and see how well it dries a load of laundry. If it comes out alright, then you know that the vent in the house is clogged and will need to be professionally cleaned out. Good luck
Jun 19, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My two or three year old LG DLE5955W dryer is making a grinding/squeaking noise and from what I have read is most likely the worn rollers. How do you gain access to them and is it something for a do it...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 09, 2010 | LG DLE5955 Dryer
My lg dle5955w works but does not dry clothes why
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 26, 2010 | LG DLE5955 Dryer
Dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Jun 23, 2009 | LG DLE5955 Dryer
Dryer flow sensor shows 4 bars
lint trap holder has got some lint overflow caught down inside it ,past lint screen , I use a piece of small pool pump hose taped to the end of a normal vacuum to suck it out
May 08, 2009 | LG DLE5955 Dryer
Hi, I hooked up my LG DLE5955W dryer and it powers up fine but I have no heat. The outlet I had for my old dryer was different than the one required for the LG. I went to home depot and got the correc
The following link explains how to properly wire a three or four prong 220VAC appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link provided, and make sure you have the power cord wired correctly at the terminal block in the back of the dryer. NOTE: If this is a new installation, you are required to be using a four-prong outlet with 4-prong power cord. If you have any questions, please let me know. I hope this helps solve your problem.
May 03, 2009 | LG DLE5955 Dryer
LG DRYER 5955 - No heat; 4 bars in test phase; NO blockage!
some dryers have what is called a thermo fuse if it overheats due to bad venting the thermofuse opens and need to be replace it whit about 1:lonk mounted on the back of the dryer cost aprox 6.00 thanks from gilles
Mar 15, 2009 | Dryers
LG DLE5955 Dryer Logo
1,755 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
