Question about Equinox (210120)
Coolant running into the engine with oil
Coolant mixed with oil engine
  • 2,418 Answers
Stop do not drive it, have it towed back to the dealer ASAP.
Posted on Apr 24, 2010
Intruder VS 400. Why does water come from inside engine and oil runs into cooling system?
If coolant is mixed with oil and oil mixed with coolant then probably head gasket blown!
Mar 18, 2016 | Suzuki Motorcycles
Engine oil mixing into coolant
The only place, oil and water share a gasket is the cylinder head gasket, oil and water galleries run through the engine block and head via the head gasket. The cylinder pressure will be OK, it's the oil pressure that's putting the oil in the coolant, the gasket has gone between the water and oil galleries or there is an internal crack (unlikely). A coolant pressure test should show it up.
Jan 23, 2014 | 2012 Kia Sorento Base 4dr SUV 2.4L 4-cyl....
Kia sportage engine oil mix with coolant in radiator
if NO coolant in engine oil in block but ONLY in radiator- you have a internal leak in radiator- replace it BEFORE you get mix in engine...
Dec 22, 2013 | Cars & Trucks
I have a 2001 Ford windstar, I was told while having my oil changed that there was oil in my coolant, yet when my we removed the coolant from the reservoir and waited for it to separate it never did, which...
In my opinion, if you drained the coolant and there was NO OIL in it or any evidence ( an oily film in the reservoir), you were the poor victim of a dishonest oil change facility.
Just watch your coolant and oil level daily for the next week or so. If any milky residue appears on the inside of the cap where you add oil, or any oil film builds up on the coolant reservoir, then you might have a problem. Most likely a head gasket has failed.
when oil mixes with coolant it sill stay suspended for a long time. Water and oil don't mix but coolant and oil will due to the chemical properties of the coolant and it can take days to seperate.
Sep 23, 2011 | 2001 Ford Windstar
Low coolant light keep coming on chev garage replaceed waterpump gave it back not fixed then heater core gave it back not fixed then radiator which i refused to pay for drove it out of the shop and the low...
You may very well have ruined this engine by continuing to drive it with coolant mixing with the oil. Have a compressions test run to verify the condition of the rings. The oil pump may also be failing.
Jul 12, 2011 | 2000 GMC Sierra
I have oil in my coolant on my 1991 ford ranger
It is not good because there is crack on your engine making oil and coolant mixed. Please find the leak and get it fixed.
Jan 27, 2011 | Ford Ranger Cars & Trucks
Engine oil is mixing with coolant
You need to find it, and not run it, as coolant in the oil destroys things fast. Pressure test your coolant system to find a leak. You might be looking at head gasket, or even water pump seal area to start.
Jun 22, 2010 | 2005 Honda CRF 250 R
There is oil in the radiator
could becoming from ur oil cooler lines that go into rad,,,could have internal crack in rad,,,pull dip stick out & ck to see if motor oil is low or a grayish color,,if ok ck trans fluid to see if is low,,have to find out what kind of oil residua is in the over flow jug
May 08, 2010 | 1998 Chevrolet Astro
Broken Gasket?
Head gasket has failed allowing oil and coolant to mix together. Don't drive it until repaired,
Feb 05, 2009 | 1998 Acura RL
Equinox (210120) Logo
80 people viewed this question
Top Equinox Computers & Internet Experts
David Payne
David Payne
Are you an Equinox Computer and Internet Expert? Answer questions, earn points and help others
