Question about Dishwashers
Soap door in Kenmore dish washer doesn't open
  • Dishwashers Master
  • 43,501 Answers
Hoover HD83 soap dispenser problem
My best guess would be a stick dispenser door. I believe this because if the timer was not working properly then the door would not open at all. I would decalsify the washer and if that doesn't work I would pull the door apart to see if there is somthing stuck in the dispenser that is jamming it up
Sep 06, 2012 | Hoover 24 in. HD83M Free-standing...
Dishwasher won't access soap tray
Check if the dish rack is reversed. If it is, it'll block the dispenser from opening.
If that is not the case - you may have problems with soap dispencer solenoid or with control board. Unplug the d/w. Disassemble the door, and find the solenoid contacts on the dispenser. Check for continuity. No continuity - replace dispenser.If dispenser is ok, check wiring for continuity. Otherwise it's the board.
Jun 01, 2010 | Dishwashers
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Liduide soap
Hi mansim,
I'm Harvey the Master Plumber.
Your question is: how to use liquid dish soap in the kenmore dishwasher?and which place in dishwasher?
I think it prudent we are first clear on terminology. Based on your discription of your "dish soap", please be certain it says "dishwasher soap". If it doesn't say "dishwasher" on it then it's not meant for your dishwasher.
For a standard american dishwasher the soap goes into a small cmpartment in the door. Just open door fully and you will see the rectangular box on the left. Soap in, then close box. The dishwasher will open it on the second cycle.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 15, 2008 | Kenmore 15522 Built-in Dishwasher
Dishwasher does not clean. soap door does not open every time.
Well the 2nd part of your question is probably the the reason it doesn't clean. If the soap door doesn't open then the dishes will probably not be cleaned. So.. I would focus on why the door doesn't open first.. is it sticking from old soap residue? If so, clean the dispenser with white vinegar and cycle it a few times without detergent and use the hottest/sanitary setting.. Then make sure you are using an approved dishwashing detergent for yuour wash cycle. Add some detergent to the dispenser and try cycling it without any dishes .. does the door open? If no, then you need to resolve that first.. If it does open, try running a cycle with about 1/2 the normal dish load and see if the door opened and the dishes came out clean.. Routinely, check and clean the drain filter so you aren't redistributing the food sediment from the previous load all over the next load of dishes.. Hope that helps..
Sep 06, 2008 | Kenmore 24 in. 16009 Built-in Dishwasher
I just bought a used Kenmore standalone dishwasher and ran it for the first time. The dishes on the top did not get clean and the soap did not come out of the closed soup dish. at one point I took a shower...
The inlet filter is probably clogged. Try letting it fill up. Open the door to stop it right after it starts to wash Pour a gallon or two of hot water in and see it it works better Stop and do this everytime it goes to fill up. If the door opens , soap is used and dishes are clean ,clean the filter in the fill valve and possibly replace it. or the whole valve. (around $25) The soap door may be a seperate problem. I don't remember if Kenmore uses a spring or a small heat element to open the soap dispenser. Try cleaning it really well, shut the dispenser, open the door and turn the timer very , very slowly and watch to see if the dispenser opens. (WIth the door open the dishwasher will not run, but leave it plugged in.) It should open sometime during the cycle.
Jun 29, 2008 | Dishwashers
Despenser cup - Kenmore dish washer
hi
the dispenser will always open when the washer goes through it's regular cycle. I would recommend to only use powdered soap, that is what the washer was designed to work best with.
Mar 20, 2008 | Miele 24 in. G892SCU Plus Built-in...
Have the Kenmore Limited Edition dishwasher, model # 665.15892100. When dishwasher is running, you can hear the soap container flip open. However, @ end of washer's completion, and main door is opened, the...
check the wash arms to see if food has not cloged the holes stopping water getting through
if these are clean the machine may not have enough water entering machine
also check how you stack machine
Feb 02, 2008 | Dishwashers
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
