Question about APC Heating & Cooling
I want to know how to wire my pullout switch #dpu222r to my main electical panel, do you have a wiring diagram? It is a cutler- hammer # dpu222r
  • 59 Answers
SHOULD HAVE 4 LUGS  2 LABELED  LINE   AND 2 LABELED  LOAD. THE 2 LINE IS 230 FROM BREAKER   THE 2 LOAD IS 230 TO CONDENSER. SHOULD HAVE 2 GREEN GROUND WIRES THAT MOUNT TO HOUSING.
Posted on Apr 24, 2010
Testimonial: "That was very helpfull, I wasn't sure where to attach leads from main breaker- you've answered my question, thank you much Al. "
Hi, I have the Cutler Hammer fusible ac disconnect 30 amp, my question is with the 10-3 wire from the fuse panel to the pullout do you only use the Black White and Ground and lay back the Red? Also, can...
If you use a white wire to carry a 120 Volt line it would have to be taped with either black or red tape both at the breaker box and your fuseable disconnect so the solution is to use the black and the red wire into your curcut breaker, the white and the bare ground both tie into the grounding post at the circut box and at the fuseable cut off, Yes the fuses are neccisary per code.. to eliminate a short or fault from traveling all the way back to the breaker box.. often times found inside the building the fusible pullout is attached to. check your local codes and regulations for more specific details.
Aug 09, 2010 | Cutler Hammer Fusible AC Disconnect Switch...
Breaker malfunction- Breaker won't restore power to the circuit
To do this safely you should call an electrician. No way I can give you complete instructions that will be sure to be safe because I can't see exactly what the situation is that you have. But the basic steps include: turning off the main, understanding that you are about to expose the feed lugs TO the main which are still LIVE (and giving them a wide berth!), carefully removing the cover, CONFIRMING that everything else in the box is NOT LIVE (use a non-contact voltage detector - $15 or less), removing the wire from the old breaker, pulling the old breaker out, plugging the new breaker in, connecting the wire to the new breaker (nice and tight), replacing the cover and then turning the main back on.
Jul 27, 2010 | Cutler Hammer Eaton Electical #BD3030...
Main breaker is kicking out
Please call an electrician. There are 3 possibilities---- 1. The sum of the branches are occasionally spiking higher than 200 amps. (If you add up all of the branch ratings you will find that their combined capacity is much higher than 200 Amps in total) In this case you need to find a way to level the load or add capacity by adding a second breaker box -- you can't do this yourself because you need help from the utility company. 2. There is something shorting out inside your breaker box. (unlikely) 3. There is a problem with the main and you need to replace it. But DO NOT ATTEMPT TO DO THIS YOURSELF. In all three cases you need help from an electrician.
Jun 18, 2010 | Cutler Hammer Eaton Electical #BD3030...
I purchased a 60-Amp Cutler-Hammer Fusible Pullout Air Conditioner Disconnect to replace my older (over 20 years) one for my AC/Heating unit inside the house. Looking for a wiring diagram as I have 2-wires...
The two wires coming from the breaker box go to the terminals marked "LINE". The two wires going to your AC unit go to the terminals marked "LOAD".
Hope you find this to be very helpful. :-)
Mar 22, 2010 | Heating & Cooling
Wire diagram for fusible pullout a/c disconnect.
THERE IS ONLY THE WIRES GOING IN AND THE WIRE GOING OUT THAT IS HOW THIS WORKS
Jan 07, 2010 | Cutler Hammer Fusible AC Disconnect Switch...
CAN A EHD1020 CIRCUIT BREAKER (CUTLER HAMMER) BE USED IN A 120/240 APPLICATION? BREAKER IS IN A SFDN100 ENCLOSURE (CUTLER HAMMER)
For 240 if it is a single pole breaker then no. You need a double pole breaker or 2 single breakers , one above the other, connect the red wire to one and the black wire to the other. this way you are drawing from both legs. hope this helps you...
Sep 15, 2009 | Cutler Hammer Eaton Electical #BD3030...
I have a c25 relay I'm wiring that is controled
I am a Master Electrician, I provide DIY services via email. You can pay via paypal. email me at buffalonymann@yahoo.com and I'll give you the link to my website where you can set up the account
Sep 04, 2009 | Cutler Hammer Eaton Electical #BD3030...
Heating & Cooling Logo
467 people viewed this question
Top APC Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you an APC Heating and Cooling Expert? Answer questions, earn points and help others
