Question about Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher
Quiet partner 1 top rack does not get clean at all
This two year old quiet partner 1 seems to run through all the stations water comes out etc. but the top rack does not seem to get clean at all. I have taken the hose type deal that delivers the water above and below the top rack and it does not appear to be clogged in any way.
    President:
  • 949 Answers
I would suspect you have debris in the pump that is causing a pressure drop so the water is not spraying well in the upper arm.
Try this procedure to clean out the sump. Let me know if it helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
Posted on Apr 25, 2010
Testimonial: "Very helpful, the link with step by step instructions was fabulous!!! Thank you so much, I was almost ready to go buy a new dishwasher."
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Our Whirlpool Quiet Partner III cleans the bottom rack fine, but the top rack does not seem to have any water pressure and thereby does not clean. Any solutions?
two things that you need to check one is the water level in the machine when it has completed it fill cycle.low water level will cause this issue with imporper cleaning.
make sure the spray arm is not clogged in any way.
the other is simply replace the main wash motor
Mar 09, 2010 | Dishwashers
Whirlpool dishwasher quiet partner 1 top arm is not rotating?
I have same problem, anybody know how to fix this?
Feb 10, 2010 | Whirlpool Dishwashers
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
Whirlpool dishwasher top spinner and top rack spinner is not putting out water or very little and not spinning. I have taken apart and cleaned everything including the sump / chopper, can't find any...
First, confirm that the holes are not blocked on these arms. (I did not want to assume you have done this.)
Then check the impeller on top of the motor stem for being loose or worn/damaged - to rule the impeller out. If it is fine, then the motor is failing and too weak to drive the spray arms.
To answer your question, I think the answer is "They don't make them like they used too!"
Sep 12, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
I have the Whirlpool Quiet (??) Partner II. My
Have this same problem with my Whirlpool DU1145XTBA. Found out that when you start the unit, it fills with water. If the water does not rise above the filter mesh in the bottom center of the unit then the pump doesn't have enough water to supply pressure to the upper sprayer. Had to replace the Flow Meter. It tells the unit how much water to supply to the unit.
Apr 12, 2009 | Dishwashers
Whirlpool Gold dishwasher
Either:
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
Vlad
First Choice Appliance
Mar 21, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
No water or rotation to upper rack
if its not letting in enough water then this can happen.check water connections or a motor fault.
Jan 21, 2008 | Whirlpool 24 in. ADP5962 Free-standing...
Whirlpool 24 in. DU1055XTPS Stainless Steel Built-in Dishwasher Logo
1,082 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
