Question about Dometic Heating & Cooling
I have a new Dometic RV Air Conditioner Model 57915.751JO (13.5 BTU). It cools just fine but it only runs for 2-3 minutes, then shuts down for a few minutes, then recycles again. It should run until it reaches the temperature setting on the thermostat. It just keeps recycling. There is no visible power setting switch that I'm aware of.
  • 2,418 Answers
This is a symptom of the system being low on freon. The system will have a low press switch, and as the the suction press drops the switch will brake and stop the compressor, then as the press rises it will start up again. Needs more freon, r134 I believe.
Posted on Apr 24, 2010
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
Constant cycling
do you use a inverter.. or any protection circuit>
if so remove it and connect it directly
Apr 05, 2008 | Dometic Rooftop RV Air Conditioner
Why does the Dometic 15000 BTU RV AC Unit cycle on and off in short bursts?
I had the same problem with my 2013 Alpine! I took it to a Keystone dealer and of course it wouldn't do it for them, so I contacted Dometic 574-294-2511 and asked for Al McGuire! (GREAT GUY) He is the guru of Dometic! I live 50 miles from the nearest dealer and he sent a new pc board AND a new wall thermostat to an appliance repair shop at no cost! "I" replaced them ( 5 minute job) and it has been working fine. I do keep my fingers crossed because the thermostat is terrible to program.
May 29, 2014 | Dometic Rooftop RV Air Conditioner
My duo therm 13.5 btu rv air conditioner started making a popping sound and dimming the lights like it's trying to cycle to shut off. Well then it started triping the circuit breaker so I changed out the 2...
The best guess is that you have a bad thermostat. When the compressor shuts off it has to stay off for a long enough period of time for the low pressure high pressure to equalize. If it turns the compressor off and back on immediately it can't start against the heavy load created by these unequal pressures. If it will start every time after sitting for 10 minutes the thermostat is making it short cycle.
May 26, 2014 | Dometic Rooftop RV Air Conditioner
My duro therm 15000 btu air conditioner runs fine until set temp is reached. The unit then starts to cycle on and off about every 2 minutes.
Service your indoor and out door. Due to over dusty, sometimes, this type of malfunction may happen. Thanks.
Oct 16, 2011 | Dometic Rooftop RV Air Conditioner
I have a dometic rv unit 15000 btu what is the amp draw?
For an RV 15000 BTU air conditioner the size being maximum for 115 volts ac you will need to have a independent circuit breaker for it only and rated at 20 amps. The average amps depends on serveral factors like actual supply voltage somtimes 110 to 120 volts and wire size and length feeding the air conditioner. To answer your question the average Amps will be near 13 Amps. Click Here=>
Dometic RV Air Conditioner Installation Manual and Specifications
Click here for a photo of the Electrical Spects.=>
Dometic_RV_Air_Conditioner_Electrical_Specifications
If you have any questions I will be here to answer them for you, Thanks, Sea Breeze
Aug 19, 2011 | Dometic Rooftop RV Air Conditioner
I have an RV with a duo therm rooftop air conditioner... when i turn the air on.. the compressor will run for a few minutes.. it blows cold air and then the compressor shuts down. Low freon??
Quite possibly low on refrigerant. Sounds like a pressure switch is shutting the comp. down after it pumps down for a few minutes. Someone will have to check the refrigerant with guages if you don't have any of your own. There should be ports to connect a set of guages near the compressor under the cover.
Apr 13, 2011 | Dometic Rooftop RV Air Conditioner
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
44 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
