Question about Nokia 1600 Cellular Phone
Urgent the led light is not working
  • puspa Mar 25, 2008
    Insert SIM: please suggest
Hi sir
Posted on Apr 28, 2009
    President:
  • 1,017 Answers
For puspa
Never touch the connections on the SIM card or the phone. Clean the connections gently using surgical spirits. That should do the trick.
On rare occasions the SIM card needs replacing, your network service provider can give you a new one, sometimes it's free.
Posted on Mar 26, 2008
SOURCE:
Yellow led engine light illuminated..why
it lights up because the CPU has recorded a fault that needs urgent attention. stop check oil and coolant levels. have a fault code reading done and fix the fault. To continue driving will eventually place the engine in low power mode or will cause big dollar repairs.
Dec 26, 2013 | 2006 Mini Cooper
The dashboard show the engine led ligh on and the message shown service is urgent and also the emmission system require to repair. what is happeening and how to clear off the message and led light?
its very simple go ahead change your oil after that turn off the car then put it back the key to ignition but before that press the single pin from the cluster or the speedometer and dont remove it just leave your hand until u start then it will automatically shut down the led or the light..
Jan 26, 2011 | Volvo S80 Cars & Trucks
Sansui sy 20 eye tv- when power on/off only red led works, green led not working
Please give me sansui sy 20 eye service menu code...pls urgent
Jan 24, 2011 | Televison & Video
Everything was working fine, then one day I switch...
Try to check your CPU unit it maybe have a power when you turn it on. Or just check their power suppy at the back when it works. If you check that all and it works normal just check inside your computer and try to see the Power LED (Light Emiting Diode) of the motherboard if have a light. Because if it is have a light your motherboard is good and if it is no light in the Power LED of the motherboard that was damage. But if your motherboard does not have installed Power LED try to check the CPU Fan it maybe works properly it because the CPU Fan was conncected in the motherboard if did not works the motherboard is also damage and need to replace. But if the CPU Fan was working properly, try to hold the CPU Heatsink if it is very hot the damage is your micro processor.
May 20, 2010 | Intel D945GCNL Motherboard
Dlink DIR-625 Doesnt work. Power light blinks when plugged in
hi.. all,
i am facing the same issue.. my new DIR-615 , when plugged with power cord ... make the power led blink continuously... and hence so, no network is accessible neither wifi works in simple terms noting works, no combination of power cord with network cable with computer works.
i have even tried resetting using the reset button.. but still the power button keeps blinking.
and yes it was working in past, its a brand new product(3 months old).
Please help and its urgent..
thanks a lot for your help..
Regards
Dharmendra
Nov 25, 2009 | D-Link DIR-625 (790069292637) Wireless...
My Compaq 7400 laptop was working fine but put aside to use another computer. Started it up - no front LED indicator lights - sudden shutdowns - battery apparently not charging. New battery - charging -...
If the notebook has been almecenated with battery's in place, check battery holders for sulphite (Light blue dust-like substance) in the connection points.
Using a sand paper, remove this substance. DO NOT ALLOW IT TO GET INTO YOUR MOUTH. That should work, but if the sulfite extended to the inside of the unit, then you may have to dismantle, clean and reassembly the notebook.
Nov 20, 2009 | Compaq Armada 7400 Notebook
CREATIVE SPEAKERS NOT WORKING!!!
creative speakers not working.even though power button on the led not glowing. today morning properly worked but suddenly not working light not glowing. send me solution to my mail [email protected] tan q
Jan 10, 2009 | Creative Labs Audio Players & Recorders
Nokia 1600 Cellular Phone Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
