Question about Kenmore Elite 45986 Front Load Washer
When spining the washer makes a grinding sound
  • Kenmore Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Apr 26, 2010
Bosch 500 next ers washer has a bad grinding noise when spining it's getting very loud
Clothes load may be out of balance, try to rebalance load, may take multiple tries. My bet, it doesn't make this noise if just water in the tub and spin out. However, if it makes this noise with just water in the tub, you may need serviceman to look at it. How old is the machine? Service may cost more than a lightly used replacement.
Mar 04, 2015 | Bosch Washing Machines
Washer makes loud grinding noise during agitation and does not agitate - it is a maytag atlantis.... fix or replace?
I suspect the thrust bearing kit is bad. This comes with great instructions and is easily replaced. I would recommend changing this before replacing the machine. You are not out much if it does not work, but I am confident you will get it going by replacing this! This is a VERY common problem with these washers and the new kit has been redesigned.
Kelly
Mar 21, 2011 | Maytag Atlantis MAV9750A Top Load Washer
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on appliancepartspro.com
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Grinding sound
Hi Garvis, I see two possible issues with this machine. Either the pump bearing is out or a coin and or the gear case is failing.
Here is a good pic of the base;
Number 4 is your pump which is accesible by a panel on the back of your washer. I would pop this cover off and run the washer while examining with a flashlight watching out for the gear case in the center. Feel the pump for vibration matching the noise and check the movement of the tub to help locate the noise.
Oct 04, 2008 | Admiral AAV7000A
Roper washing machine
roper washer made a buzzing sound when spining
Mar 30, 2008 | Roper RAX4233PQ Top Load Washer
Spin cycle doesn't work with loud noise
yea sounds like a bad motor coupling ( this machine equivelent to a belt).
Mar 06, 2008 | Whirlpool LSR7333 Top Load Washer
Kenmore 90 Series, washer Model 24924200
probably a sticky or broken bearing clutch, call a repairman. Probably be under 100k dollars to repair.
Jan 29, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
48 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
