Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Freezer works, lower section not working
I have a whirl pool top freezer unit. Freezer compt works ok, but has ice build up, lower section not working.
Model no ET8GtMXKQoo
Ser no VSM3314582
Built 08-02
    Scholar:
  • 126 Answers
YOUR FAN IN THE FREEZER MAY HAVE FAILED.
Posted on Apr 24, 2010
Water is dripping into fridge compartment from section separating fridge and freezer compartments, otherwise, both seem to be working fine. unit was new in 2001, model ET21PK.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
My fridge is leaking inside. I have a top freezer model and the leaking is happening in the lower fridge compartment in the rear, from above.
The defrost problem.The unit is not defrosting on time.--------
. First try manual defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. -------------
If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Kenmore Top Freezer Refrigerator
Freezer only works on bottom
The evaporator has most likely built up with ice on it. this usually makes the fresh food section go out first. the best coarse of action is to remove freezer panel and make sure return air or vents are not blocked with ice..if these vents are blocked no ff section locate the vents that allow air to flow down and open...good luck..bruce denton
Jun 07, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
May 13, 2009 | Refrigerators
No cooling in refrigerator
air passage from freezer to the lower door maybe blocked with ice build-up
May 06, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Whirlpool gold side by side freezer not freezing but fridge is running
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Oct 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore elite - top freezer
if there is ice build up at the back wall of the freezer section, then you have a problem with your defrost cycle. the freezer would not be very cold for the ice maker to work.
it's either your timer, defrost heater or your bi-metal.
tnx 4 using fixya,
drcool
Sep 30, 2008 | Kenmore Refrigerators
Confused /
Ok the freezer section works the refrig section think of the refrigerator as a large cooler with an inlet and outlet hole cold air is blown into the refrig from the freezer via the fan motor in the freezer the really cold air comes in the top of the refrig and drops to the bottom of the refrig then it is sucked back into the freezer thru a vent hole in the bottom of the refrigerator ..GOT IT?? Now when a unit has a defrost problem there is an ice or frost build up in the freezer on the coil (bad heater,bad bi metal, bad timer can cause this) the ice builds and builds to the point where it blocks the air flow across the coil hence the air can not get to the refrigerator section making it warmer but the freezer section will work ok .. I hope this makes sense...Hint : A sign of this is a lg frost buildup on the back wall of the freezer.
Nov 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
206 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
