Question about Maytag PAV2300 Top Load Washer
Washer has a burning smell and will not drain
  • 27 Answers
The burning you smell is probably your belt. if you change the belt and it still has this problem then your transmition has failed. This is a very comon problem with maytag washers.
Posted on Apr 24, 2010
Kenmore stackable washer will not drain burning smell
THE DRIVE BELT HAS BURNT UP AND NEEDS REPLACED
Aug 14, 2014 | Kenmore Washing Machines
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Intermittent Draining and Burning Smell
The water will not run in the machine.It will for a few second then stops. What could be the problem?
Aug 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
It does not drain at all? and it makes a weird noise and it smells like burning rubber how do i fix it? some one told me that it might be the pump.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Some part of the motor burned out that's why you can smell burning rubber. Check some faulty parts.
Mar 27, 2010 | Maytag MAV2755AWW Dependable Clean Top...
Agitator spins slowly and wont drain water-slight burning smell when operating
Hi, Th smell is most likely the belt. If the washer is not draining, the pump could be locked up and this will cause the belt to smell.
The pump is located underneath rear right corner. If you set the drain hose itno abucket and get the water out. you can tip the washer back and see if the pump is froze. I see you posted this premium but I didn't get to it in time cause I was asnwering this.
Hope it helps
Vic
Jun 21, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Wahser stopped after wash cycle, burning smell
Hi, it is possible that something got into the pump and stopped it from turning. Let the drain hose down so that it drains into a bucket or a floor drain if possible.
If water does not drain then it is deffinetly plugged. Once you get the water out of the washer, tip it against the wall and try to remove the pump off the motor. There are two clips that hold the pump on. You will also need to remove the hoses.
With the pump off, you can set the washer back down and try to run the spin cycle. If the motor runs, it must be the pump.
Please let me know if I can assist you further.
Thanks
Vic
May 23, 2009 | Roper RAS6233KQ Top Load Washer
Burned belt?
Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
Jan 23, 2009 | Maytag SAV5710 Top Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Maytag PAV2300 Top Load Washer Logo
566 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
