Question about Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery
Fridge was working OK this morning, came home and teh fridge is completely not working - no compressor, no lights. Check the house breakers and all OK. Even plug into another outlet and still does not power-up
    Scholar:
  • 126 Answers
SOUNDS LIKE AN ELECTRONIC CONTROL BOARD ISSUE. SOME TIMES UNPLUGGING THE REFRIGERATOR FOR ONE MINUTE AND THEN PLUG IT BACK IN WILL WORK 20 PERCENT OF THE TIME. IT MAY WORK FOR ONE HOUR TO SEVERL YEARS IF THIS WORKS. THIS IS COMMON WITH FRIGIDAIRE PRODUCTS.
Posted on Apr 24, 2010
I have Whirlpool fridge FF450 Elite. Though the fridge cooling is normal, after the night working find in the early morning all magic light flickering though the fridge compressor is working. The freezing...
seems to me by the frost that the inside fan is not blowing air across the cooling radiator (evaporator), due to ice build up impeding air flow or the fan motor stalls or not working a t all. Defrost timer should also be checked if the air flows thru inside the fridge.
Jan 06, 2015 | Whirlpool Refrigerators
Compressor wont start up fan in freezer stays on
        • Pull the fridge out from the wall and check to make sure it is plugged in.
        • Unplug the fridge and plug in a spare appliance to see if the outlet is working. Check the circuit breaker to the house see If the outlet is not working to see if there are any fuses that are flipped.Inspect the electrical cord for the refrigerator for damage, such as from a mouse or pet chewing on it.
    • Open the fridge to see if the light turns on. The power to the unit is fine if the light turns on, which means something else is the cause of the starting issue.
    • Turn up the thermostat on the inside of the fridge if it is set to a low setting. Turn it all the way up and listen for the condenser motor to start. Have the unit serviced by a professional if it does not May be internal problem with component
Dec 13, 2013 | Freezers
Subzero r601 compressor not turning on
Check the relay on the compressor. Pull it off and shake it. If it rattles, it is bad.
Dec 07, 2012 | Refrigerators
LG Refrigerator side by side suddenly not working at all other than interior lights.
If you're lucky, it's just the capacitor on the motor. Have it checked, but be prepared to need a new compressor.
Mar 10, 2012 | Refrigerators
Just bought a used 1987 Real-Lite truck camper. The roof air unit is Dometic as well as the LP/AC refrigerator. When turned to "cool" the air conditioner really draws down, dims the lights, and eventually...
To start with, if it's plugged in to a 15 amp breaker, and extension cord, the compressor starting up may just be enough to trip the breaker. It will draw close to 15 amps on start-up of compressor, and if there is a light extension cord used to plug it in, that only makes it worse. Make sure you shut all other breakers off in panel except AC, and try it. If you have water heater on hydro, fridge on hydro, and then try to start AC compressor, you'll be way over the 15 amps, especially if it's a light extension cord.
Keep in mind, in order for fridge to work, you need 12 volts DC (Battery) power going to back of fridge. If the controls aren't lighting up at top, you've most likely got no 12 Volt DC power going to fridge. Check all fuses as well.
Jun 02, 2010 | Dometic Rooftop RV Air Conditioner
The refrigerator trips the circuit.
possible failed start /run capacitor for the motorm
call a technician for a proper diagnosis
Oct 06, 2017 | GE Refrigerators
About 1:00 am this morning our fridge tripped the circuit breaker, it ha never done this before. I reset the breaker and it tripped 5 mins later. I left it unplugged for the rest of the night. I plugged it...
It sounds to me, either you have a bad circuit breaker (the breaker itself); or you have a bad motor or compressor in the fridge. If possible try plugging the fridge into a different outlet. (If you use an extension cord to do this, make sure it is a thick gauge, in order to not cause an increase in amps through the smaller cord.) This should tell you rather quickly if the problem is with the breaker or the fridge. If it does turn out to be the fridge, you will probably find it is cheaper to replace a fan rather than the fridge, but the compressor (including installation) would probably cost more than a new fridge. (depending on how "fancy" it is)
Hope this helps
Sep 29, 2009 | Refrigerators
Fridge freezer shorting out electrics
The cause of this situation could simply be an overloaded circuit. Homes are built with dedicated circuit for fridge only now because of this. If you notice power outage in other rooms or other appliances in kitchen then the circuit affected,I.E. other outlets affected need the load lightened. If it is a dedicated circuit then could be faulty breaker or possibly altered wiring could be cause.These have to be ruled out before you will know for sure. If it isn,t dedicated outlet for fridge only, just plugging in a light could overload loaded circuit.
Apr 21, 2009 | Refrigerators
Fridge keeps tripping electricity
I assume by "earth leakage" you mean it is on a GFI circuit? Some older GFI outlets are sensitive to and do not work well with motors or other inductive loads like your refridgerator compressor. As for the compressor feeling hot, this is usually normal.
If this is a GFI outlet, try replacing it with new unit. If it is a GFI breaker, try replacing that.
Dec 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Neither Freezer nor refrig is cooling
Pull the compressor side cover off. Pry off the square box. This is your compressor start relay. Check for continuity. It's probably blown. If ok check for voltage to the compressor.
Jun 07, 2007 | Amana ASD 2624 Side by Side Refrigerator
Open Questions:
I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defros I have a frost free fridge freezer zanussi (electrolux) znb323s. A week ago I discovered the fridge part was not cooling but the freezer part seemed fine. I emptied the fridge and turned off to defrost. The top part of the freezer was heavily encased in ice (evaporate coils I think). After perusing the web for advice I removed the the front vent, the back wall and dropped the coil panel to access the fan. The fan had obviously not been working for some time cos it was covered in ice. I defrosted the whole fridge for 2 days. Turned it back on and the freezer part seems fine although v cold. The fridge seems not to be cooling again. The compressor seems to be constantly running. Current temps are fridge 12, freezer -25, ambient 16. I haven't got anything in the freezer yet. Thermostat set on 1 (1-6 setting). How is the fridge cooled? When I removed the evap panel I could not see how cold air gets to the fridge. There aren't any holes in the fridge so I am assuming the back panel should be cooled. If the thermostat is u/s would the compressor still run? Does the thermostat control any duct vv from freezer to fridge back panel? I attempted to remove some of the insulation from the fridge rear but was worried about cutting anything under it so abandoned that. Wife now giving me grief. Pse help. Andy
Mar 02, 2017 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
See all Electrolux Icon 22.6 cu. ft. Counter-Depth Questions
Electrolux Icon 22.6 cu. ft. Counter-Depth Refrigerator Free Delivery Logo
167 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
