Question about Olympus Stylus 770 SW Digital Camera
How do you turn the flash off??
I have an Olympus 770 sw. How do you turn the flash off it??
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Press cursor-right (marked with a lightning bolt) then select "Flash off."
Posted on Oct 07, 2013
  • 919 Answers
SOURCE: cannot print pictures with dates
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Posted on Dec 22, 2008
jerryg50
  • 1667 Answers
SOURCE: olympus C-770 camera not turning on
The switch may be going defective, or the circuit board that it is sitting on is defective. This would require factory level service. They will most likely change the switch assembly to get the camera working properly.
Jerry G.
Posted on Apr 26, 2009
BillB-SA
  • 2761 Answers
SOURCE: olympus 770 sw lens cover not closing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
SOURCE: Every time I turn on my olympus 770 SW, WRITE PROTECT comes up
Write protect
Posted on Nov 01, 2009
Tnsiouxfalls
  • 617 Answers
SOURCE: Olympus 770 SW WRITE PROTECT
http://www.olympusamerica.com/files/Stylus%20770%20SW%20Instruction%20Manual.pdf
Page 56 of this manual explains what to do.
Posted on Jan 25, 2010
Blurry area on photos taken with Olympus Stylus 770 SW. Does not matter if taken with flash or not, indoors or out. Blurred area is about the size of a US 25 cent piece when viewed in Picasa, usually in...
Have a look at the lens, is there something stuck to it or dirty. If so needs cleaning. I'd try a damp cotton bud. Don't get water in the camera. Use several buds if required. Be Gentle.
Jan 02, 2011 | Olympus Stylus 770 SW Digital Camera
I have an Olympus 790. When I tried to use it last week, it wouldn't turn on. I also have a new Olympus 770 that I have never used. Today I turned it on and it worked fine. Then I took the memory chip...
Either the software in both cameras need be updated. EIther by online software update program or the manufacture will do it for $50 a camera.
Otherwise, some SD cards to have conflicts with some camer'a software for some reason. Sometimes using the wrong sd card in a camera will result in memory flash and causing the camera to be in need of software update. Once updated you should be good and should work with all sd cards from now on.
Oct 10, 2009 | Olympus Stylus 770 SW Digital Camera
My olympus stylus 770 SW digital camera pictures during day time are so bright..what should i do?
Lower the ISO sensitivity to around 200 or 400.
That's like film speed... the lower the ISO the less sensitive it is to light.
[Menu]
[Sensitivity]
(down arrow) to 200 or 400...
What is is set on? 3200??
Sep 30, 2009 | Olympus Stylus 770 SW Digital Camera
Won't turn on
sent it to the manufacturer for repair
Feb 17, 2009 | Olympus Stylus 770 SW Digital Camera
Olympus 770 sw display info
i am not sure if you can do this. I just press the middle ok button to get rid of the information.
Mar 09, 2008 | Olympus Stylus 770 SW Digital Camera
REpair
Folk here only suggest ways for you to fix it.
you start by getting a very small phillips screwdriver
or a tech .
Feb 29, 2008 | Olympus Stylus 770 SW Digital Camera
Olympus Stylus 770 SW Digital Camera Logo
59 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
