Question about Bulldog Pushmatic 31115 P115 15 Amp Circuit Breaker
I need to buy a 20/20 Amp Bulldog breaker for a dryer and any installation tipes
    Guru:
  • 351 Answers
Most electrical dryers are 220 volt. They usually require at least a two pole 30 amp circuit with #10 wire. The breakers you need can be found at most hardware and buidling type stores, Ace , Home depot, Lowes.
Yes they would have the 20/20 breaker also.
Please Vote !!
Posted on May 15, 2010
How do i know when 220 circuit breakers are bad
Always match breaker and wire size:
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Feel if breaker is getting warm.
Listen for crackling sound.
Breaker is tripping.
Move wires to another same-size circuit breaker and see if problem continues.
Check watt or amp load on breaker.
For example water heater label shows 4500 watt non-simultaneous.
4500 watts divided by 240 volts = 18.75 amps.
You might think 20 amp breaker was good in this case.
However electricians use 80% safe maximum.
20 amp breaker x 80% safe max = 16 amps.
Water heater is 18.75 amps, so install 30 amp breaker.
30 amp breaker uses 10 gauge wire.
This means wire to breaker will run cool and not get hot, so breaker lasts longer, and there is more efficiency.
Using 80% safe maximum rule protects home, reduces heat wear on breakers and breaker box so everything lasts longer.
Nov 18, 2012 | Dryers
I have a Kenmore Series 70 Dryer and it keeps blowing the main breaker on the electricity panel - the main fuse is 20 amps do i have a dryer or fuse issue ?
Your dryer needs at least a 30 amp breaker to operate correctly. Changing to a 30 amp breaker should solve your problem. Hope this helps
Sep 01, 2011 | Dryers
I have three bulldog pushmatic circuit breakers that will not push back in? Are they gone or can they be reset.
Either they are bad, or are "tripping" If they won't push in when removed, then they are bad. Not unusual. You can still buy them. Look online or Box stores
Jun 17, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
Bulldog breaker dead. Reset button depressed, but would not reset to on position, button remained depressed inward
These breakers do fail. Sometimes you can get them to reset by repeatedly pushing the breaker, but you would probably only get lucky once. These breakers are still available as replacements, and are at big box stores. These breakers bolt in, however. You should only attempt to replace the breaker if you have a main breaker that you can open to remove voltage from the rest of the panel. Even in a 240V residential panel there is a serious arc fault flash potential. If you have any doubts about replacing it yourself, consult someone with experience.
Mar 25, 2010 | Bulldog Pushmatic 31115 P115 15 Amp...
Federal Pacific Breaker and whirlpool appliances
You have the wrong breaker You need to buy a breaker that pulls power on each side of the bus if it is not a single pole double trow switch it will not work on the box. It needs to get power from both buss bars. Go to a electrical warehouse to get the right one.
Jan 04, 2010 | Kitchen Ranges
240v circuit wiring to run my new Dayton Heater (3Vu34A)
On the 40 amp breaker, you should be using 8-3 w/ground. 10-3 w/ground will work on the 30 amp breaker. 12-3 w/ground is used for 20 amp circuits. Your new heater should have the electrical requirements listed in the user/installation information.
Jan 29, 2009 | Dayton 3VU34 Heater
What size breaker do I need for a 240 volt electric clothes dryer
check on the wiring diagram. You may be looking at 2-15 amp or 2-20 amp breakers.
Nov 12, 2008 | Fahrenheat Electric Convector Baseboard...
Fridgeidaire clothes dryer
I will try this again i don't think i posted it properly.
On the power cord where it connectes to the dryer make sure the red and black wire goes to the outside screws (L1& L2) the white goes in the middle and the green goes to the dryer cabinet.
If you have the red or black going to the middle one it will trip the breaker.
Oct 06, 2008 | Whirlpool LER5636P Electric Dryer
Dryer and breaker
you have a week breaker or a breaker that is to small you need a 40 amp breaker 20 on each side (two breakers locked into one) or worse you have a short in the dryer. If dryer runs for a little bit and then shuts down its the breaker.if it throws breaker as soon as you plug it in or start it then the short is in your dryer good luck
Dec 29, 2007 | Maytag HYE3658AY Electric Dryer
Bulldog Pushmatic  31115 P115 15 Amp Circuit Breaker Logo
224 people viewed this question
Top Bulldog Electrical Supplies Experts
Steve
Gene Haynes
Are you a Bulldog Electrical Supply Expert? Answer questions, earn points and help others
